qs 1000w builds
devo1223   100 W
qs 1000w builds
Post by devo1223 » Apr 07 2019 9:04pm
Ok I think there are maybe three us now so let's start our own thread. QS 1000w middrive builds. I just bought mine, waiting for it to arrive.
It's pretty wide, I don't think it will fit between my crankarms so I plan on placing the motor away from the pedals a bit.
Also, last time a checked with them they will only supply the motor with the pulley wheel, not a 219 sprocket so I need to make an adaptor.
Vector lite stuffed with 30Qs
Mxus 3k turbo 3t in 17in moto rim
viewtopic.php?f=3&t=92531&p=1353484&hil ... e#p1353484
eee291   100 kW
Re: qs 1000w builds
Post by eee291 » Apr 08 2019 12:24am
Hey, that's my hand! :lol:
devo1223   100 W
Re: qs 1000w builds
Post by devo1223 » Apr 08 2019 1:02am
I admire your work. I'm going to copy it unless you have an extra one laying around you will send me...
larsb   1 MW
Re: qs 1000w builds
Post by larsb » Apr 08 2019 1:05am
It's strange, they now have the sprocket as a standard option for the 3000w. Thought they had developed an interface that they could apply to all the motors.
maitilupas   100 W
Re: qs 1000w builds
Post by maitilupas » Apr 08 2019 5:47am
yes costs about more 15 dolars for a 428
Skaiwerd   100 W
Re: qs 1000w builds
Post by Skaiwerd » Apr 08 2019 8:23am
Cool
Things are moving fast with this motor. I see it attached to a swingarm soon. I’ll keep an eye on the adapter progress in case I want to ditch the belt for my 1st stage of reduction. Need a bigger rear chainring cyclone has a 90 tooth doesn’t give enough reduction for a single stage. So easy to ditch one idea for another.
Grantmac   10 kW
Re: qs 1000w builds
Post by Grantmac » Apr 08 2019 10:26am
7~8:1 should be a fine reduction ratio for this motor on 26" wheels and a 40mph top speed. That is possible with a single stage of 219.
devo1223   100 W
Re: qs 1000w builds
Post by devo1223 » Apr 08 2019 11:28am
maitilupas wrote:
Apr 08 2019 5:47am
Who are you ordering from? I can't even get them to install a temp sensor on aliexpress
larsb   1 MW
Re: qs 1000w builds
Post by larsb » Apr 08 2019 11:34am
maitilupas   100 W
Re: qs 1000w builds
Post by maitilupas » Apr 08 2019 11:46am
yes qs company in aliexpress they will provide you the sprocket
https://www.aliexpress.com/store/4393030
maitilupas   100 W
Re: qs 1000w builds
Post by maitilupas » Apr 08 2019 11:49am
devo1223   100 W
Re: qs 1000w builds
Post by devo1223 » Apr 08 2019 12:31pm
yeah but you ordered the 3000w. The 1000w isn't even offered on your link. It doesn't seem they are offering the same support with the 1000w. I messaged them again to see if they would do 428.... :roll:
eee291   100 kW
Re: qs 1000w builds
Post by eee291 » Apr 08 2019 1:46pm
Whoa, I didn't know they made a sprocket that was made after the stock axle...nice!
I'm gonna have to get this in case mine breaks.
devo1223 wrote:
Apr 08 2019 12:31pm
It depends, if the axle has the same measurements as the 3000 version you can just buy the sprocket and have a mechanic pull off the existing pulley.
Skaiwerd   100 W
Re: qs 1000w builds
Post by Skaiwerd » Apr 08 2019 8:22pm
The 1000w does not have a tapered shaft.
eee291   100 kW
Re: qs 1000w builds
Post by eee291 » Apr 09 2019 1:38am
Having a straight shaft actually makes it easier then.
All you would need is a machinist.
https://www.ebay.co.uk/itm/13t-428-Pitc ... %7Ciid%3A1
crossbreak   100 MW
Re: qs 1000w builds
Post by crossbreak » Apr 09 2019 6:16am
Skaiwerd wrote:
Apr 08 2019 8:23am
[...]Need a bigger rear chainring cyclone has a 90 tooth doesn’t give enough reduction for a single stage. So easy to ditch one idea for another.
Why not use a custom lazer cut one? I mean there is plenty of space, a 400mm or 16 inch dia #219 one with ~160t to 12t would be a 13:1 reduction. I dont know how fast this thing wants to spin, but i think that is in the range of the OEM swing arm with belt reduction, that was i think 5 to one but with a quite small wheel
At least this sounds much simpler + lightweight to me than an additional reduction stage if it is not really necessary
crossbreak   100 MW
Re: qs 1000w builds
Post by crossbreak » Apr 09 2019 6:29am
Skaiwerd wrote:
Apr 08 2019 8:22pm
can you pls provide the dimensions so i can make a CAD model of the #219 that can be lazercut?
Skaiwerd   100 W
Re: qs 1000w builds
Post by Skaiwerd » Apr 09 2019 7:06am
The motor shaft is 17mm in diameter with a 5mm key down the side. The shaft is about 18mm in length.
Unconfirmed. Please test print with a 3d printer before sending your file out for cutting. Don’t know if nominal or actual etc. I’m not responsible basically. Please confirm on the motor you receive.
Grantmac   10 kW
Re: qs 1000w builds
Post by Grantmac » Apr 09 2019 10:55am
They quoted me as 3000rpm@72v and 3500rpm with FW. That seems like a very small FW gain for an IPM (which they confirmed this is).
But that calculates out to needing perhaps 7-8:1 for a 40mph ebike on 26" wheels.
devo1223   100 W
Re: qs 1000w builds
Post by devo1223 » Apr 09 2019 10:57am
No luck with the sprocket from QS. My motor is coming with the pulley and maybe a sprocket later that will probably be tapered and not fit. A CAD model for the 219 sprocket would be awesome!
The struggle is real, fellas
devo1223   100 W
Re: qs 1000w builds
Post by devo1223 » Apr 09 2019 11:22am
I guess with a little filing this would work. I think 15mm is standard for 219, I wonder why QS uses 17mm
Skaiwerd   100 W
Re: qs 1000w builds
Post by Skaiwerd » Apr 09 2019 11:25am
If you can take a picture of the one you want in the correct tooth count, but incorrect center mount I may be able to help with a cad file. Please make sure there is a tape measure or ruler in the picture, I prefer metric. A lot to ask but this is how I work. I’ll double check the diameter size when I get home.
Old photo
Skaiwerd   100 W
Re: qs 1000w builds
Post by Skaiwerd » Apr 15 2019 11:19am
From another es post.
http://www.gizmology.net/sprockets.htm
Basically instructions for designing your own sprocket.
What’s desired? Chain type and tooth count for the sprocket?
devo1223   100 W
Re: qs 1000w builds
Post by devo1223 » Apr 15 2019 5:18pm
#219 with 12 teeth would be great. Here's my progress so far. My motor should be here next week. My wooden mockup in its place for now.
so far 3 (600 x 450).jpg (89.71 KiB) Viewed 2960 times
Skaiwerd   100 W
Re: qs 1000w builds
Post by Skaiwerd » Apr 26 2019 6:30am
My day job has me faced with an additional 2 hours added to my commute daily. I’m sure there’s a teary eye somewhere for me, ha ha. So... back burner for the 219 chain sprocket cad work. If someone can do the outline of the sprocket in cad I could get the ball rolling faster. Dxf file. I have to focus on my own project. Wheels are in and I need to make this type of mount. Don’t want to mess with my disc brake mount position etc so attaching directly to the hub seems more doable. This is an advanced method from the 2 stroke guys that’s an upgrade to the rag joint mount. I can buy a mount and adaptor totaling $70 bit it would still need work as it’s not for 32 spoke wheels which is what I have. Going to look up a referral of a water jet cutter nearby. Ok tapping holes on a curved surface looks difficult. Might have to modify something like the last picture.
