What hub motor is this
alix47   1 W
1 W
Post by alix47 » May 12 2019 6:49pm
Hi everyone I wanted to know if anyone knows what this motor is the seller said its 36v 200w rear hub motor not the brand thank you
dogman dan   100 GW
Re: What hub motor is this
Post by dogman dan » May 13 2019 6:51am
Picture of the whole motor might help. We could then tell by the look of it if its a geared motor or direct drive.
But its clearly a small motor, looks like 200w rated. If only two wires come out of it, then its brushed. If three large power wires come out, its a brushless.
alix47   1 W
1 W
Post by alix47 » May 13 2019 4:24pm
Can't show more pics as not received the motor yet and I know it's brushless as been in the ebike scene for about 5 years now just wanted to know if its a bafang as got one which looks the same
alix47   1 W
1 W
Post by alix47 » May 17 2019 5:10pm
Here is another photo the problem is it won't move forward or backwards I sprayed some wd40 on the outside bearing now it is moving forward but not backwards the case is a screw on type and don't know how to take the cover off to service it. It looks like a tongxin motor
markz   100 GW
Post by markz » May 18 2019 12:07am
Hmmmm outside bearing wont be an issue, though I had one go on me last year, would just squeel. I bet the gears inside are f'd. But you may luck out and it just be a bearing or two.
