Hi There,
Finally winter is here and so the time for me to go back to my battery project for my LMX64 M frame.
I finally decided to go for a 14s7P with Sanyo cells (10A 3350mAh)
The main reason is that with my supplied 14s5P with Samsung 35E cells (3500mAh / 8A), I have only 40A continuous output and on a steep hill it isn't enough to keep me going at 45km/h and so at the end of the hill I finish at 25km/h which is Meeehhh.
with a 7P and sanyo cells I will be able to pull 70A without a problem. Other Bonus I will have more range going from 17AH to 23Ah.
Currently after a 25km ride my battery is almost empty.
As you can see on the pictures I went for a battery in 2 parts to be able to install it in the frame.
I could go to 14S8P (even more) but I wanted to keep the standard battery mount (when I go to town I keep the standard battery with the locking mechanism)
It's only the beginning but I have the winter to make it right
- lmx1.jpg (268.65 KiB) Viewed 727 times
- lmx3.jpg (160.04 KiB) Viewed 727 times
- lmx2.jpg (232.22 KiB) Viewed 727 times
Ordered so far:
Supports on aliexpress
Battery connector to use on the existing battery support (Not sure yet if I will use it)
https://www.greenbikekit.com/jumbo-shar ... -pins.html
or
Aliexpress
Anderson connector + 10AWG wire: amazon
Cells / heatshrink and nickel strips from nkon.nl:
- lmx4.jpg (44.73 KiB) Viewed 665 times
BMS choice: Smart ANT BMS 7s-16S 80/150A version on Ebay
picture for illustration purpose.
