Bike was perfect after all this and was shown to French motocycle Federation today in order to promote racing series with the bike. The MC club ordered two after the test
[youtube]B9Gxs9uNiCI[/youtube]
Hi Adambzhwindtalker wrote: ↑Jan 18 2021 3:23pmLatest blog.
Bike was perfect after all this and was shown to French motocycle Federation today in order to promote racing series with the bike. The MC club ordered two after the test![]()
What‘s in the box under the frame?
Hmm, how much difference does it make? I believe I have the 6f.
Hi Guys. Can someone or Merlin say something to my battery project for lmx161. I mean that i dont have bike yet but i am preparing battery before getting box. I am planning to fit in 16S9P these 21700 cells. I am gonna use hot glue and following base Is there something what i should know before putting glue? So i gonna make 2 sets like this and bend after 8 serial. Do you think it can fit in?Merlin wrote: ↑Jan 06 2021 12:36pm35E are the weakest you can buy. the voltage drop is so high on 8A that you hit LVC at 50% of your battery capacity.
if you compare the size, calculate the space you can fill with 18650 and then with 21700.
the energy density may be not the killer deal. but the space given for the battery will do the trick.
best example is the LMX 161H battery.
there are 18650 inside. but the battery space is 15cm wide.
18650 are to small for the case dimensions AND 21700 are too big. that frocking 1mm does the trick and you can use 20700 Sanyos and fit 180 cells inside. Unfortunately it looks like they are EOL production you cant find 20700 anymore(4.25Ah)
18s10p -> 2.75Kwh
18s9p -> 2.9kwh BUT the cover will not fit anymore. so you have to go 18s8p -> 2.6kwh
Thanks for your reply.
You know what....it might. I didn't think to check that.
Oh well...I guess I could have done that, but I kind of like my DC-DC a bit more since it has a pot and I have actually set it to 13.5V. This helps compensate for the voltage drop over the long run down to the fans and makes the LED a bit brighter.scrambler wrote: ↑Jan 29 2021 7:39pmLooks like they do
"system supply 12V, and 5V"
the system cable connector seems to have a 12V out
https://drive.google.com/file/d/1KkEgWc ... sjpUQ/view
They also have an upcoming Light controller circuit called ulight
https://nucular.tech/
I think you wont be able to use Polychain as it has different tooth profile and if you would use it with 15T pulley it will crack in no time (>22T is recommended)
yes, a lower profile bolt is part of the kit. I'm guessing yours is missing it?Simonten wrote: ↑Feb 05 2021 1:26amBelt Drive installation
Hi Guys
My belt kit arrived today. I am not the most mechanically minded person in the world.
I did build my bike on my own but I can not figure how to get the belt kit installed
The suspension swing arm bolt sticks out and blocks free passage of the belt.
Is a new lower profile swing arm bolt needed.?
Cheers
Simon
