E-S LMX 64 Bike Owners
bzhwindtalker   1 MW
Re: E-S LMX 64 Bike Owners
Post by bzhwindtalker » Feb 23 2021 7:38am
You may want to check if halls are fine under the debug menus, there are individual hall status.
Joe   10 W
Post by Joe » Feb 23 2021 9:47am
Cowardlyduck wrote:
Feb 23 2021 5:45am
bzhwindtalker wrote:
Feb 23 2021 3:13am
Unfortunately not possible for streel legal ones due to the homologation, only 14-118T is possible.
However we are also testing polychain GT carbon for hopefully longer life.
Best regards, Adam
Thanks for chiming in!
Ok, fair enough on the homologation.
I still have one 15T left if anyone wants it...after that I guess it will still be possible to get them made as one off's, but that won't be cheap!
I am interested in the carbon belt. Let us know when they are available for ordering!
Something that's come up for me recently is my motor seems to be stuttering under heavy load. I vaguely recall this being an issue for someone else previously, but can't recall the solution. It only stutters briefly once or twice during acceleration. I've played around with the acceleration limits, battery lvc, and a few other settings, but can't seem to fix it.
I tried running another motor auto setup, but that just resulted in the whole motor no longer working, so I reverted. Any ideas?
Cheers
Do another auto setup with the battery full. I’ve had a couple of mis attempts with auto setup. The battery was at 75%. At 100% it worked correctly. Also make sure your best config is loaded before starting.
My rule of thumb.
Everyone should be respected.
Mihei777   10 mW
Post by Mihei777 » Feb 23 2021 10:07am
Feb 23 2021 3:13am
Best regards, Adam
Hi. I’ve been using polychain now 240km and no any marks of damage (optibelt hp last 150km in my use). It was firstly little loud, but now its getting softer and sound like other belts. My Testing temperature been -10- -20C
croydon   100 mW
Post by croydon » Feb 23 2021 5:06pm
Cowardlyduck wrote:
Feb 23 2021 5:45am
Feb 23 2021 3:13am
Best regards, Adam
Cheers
i already order 3 polychain carbon belt for cheap price in usa 1 guy sel out the belts in his stock need to go away, it is not the same belt then ore friend have (poly chain carbon v is the old generation , i order the newer generation of this carbon belt , lucky to buy for cheap 35 dollar for one belt :D .
about the stuttering does it happen in flux weakening ?
15T is awsome on my bike i test for the first time with my new setup , it is awsome.
Cowardlyduck   100 MW
Post by Cowardlyduck » Feb 24 2021 3:33am
Thanks for all the replies!
Yes the 15T works great and I think it's the best balance between speed/torque.
I will try redoing the auto setup as suggested. I really hope it's not a dead hall. I've replaced them in hub motors before, is it as much of a PITA for these motors or even possible?
Cheers
ebikegarage.com.au - My website
Ebike Garage - My YouTube Ebike ramblings.
Cowardlyducks - Videos - Ride videos
BikeE recumbent commuter - 9C, 6Fet Grinfineon, internal 17AH, 52V, + on-board solar.
Custom made 18650/21700 battery packs - Australia only
Mihei777   10 mW
Post by Mihei777 » Feb 24 2021 11:40am
croydon wrote:
Feb 23 2021 5:06pm
Cowardlyduck wrote:
Feb 23 2021 5:45am
Feb 23 2021 3:13am
Best regards, Adam
Cheers
You got belt nice price.. mine was cutted in Italy plus transport so it came expensive.
My belt is new generation also, 25% more load and antistatic (carbon volt). I am confident that this is good belt for this use, but lets see in reality.
Snow and ice is making problems, its stack between belt and sprocket and tensionpulley, then belt flies out from there. Ok its not big suprise but just mentioning
bzhwindtalker   1 MW
Post by bzhwindtalker » Feb 25 2021 2:03am
Also got one carbon volt from gates france for testing.
Not fitted yet, I lend my bike for photos :shock:
Cowardlyduck   100 MW
Post by Cowardlyduck » Feb 26 2021 5:02am
Thanks again for the suggestions on re-trying auto-detect on the motor. I tried a few more times and eventually it managed to get it right.
Bit of a worry it takes so many tries, but at least it's working again now. :)
Cheers
Rix   100 GW
Post by Rix » Feb 26 2021 10:36am
Cowardlyduck wrote:
Feb 26 2021 5:02am
Cheers
I know its like comparing apples to watermelons, but I had to run 3 auto detect cycles on my Adapto to get a combo of settings that allowed the motor to perform really well with out heating things up.
Cowardlyduck   100 MW
Post by Cowardlyduck » Feb 26 2021 5:06pm
Rix wrote:
Feb 26 2021 10:36am
I would say the next best customisable, feature rich controller after Adaptto is the Nucular, so not so dissimilar really...although I could never get my Adaptto's running perfect, in the end close enough was good enough. :D
At least (for now) the Nucular still has active support. :)
Cheers
scrambler   1 kW
Post by scrambler » Feb 26 2021 6:46pm
I was having a looks at the latest Valkyrie Boxxbike, 12/14kW, 1600Wh integrated battery, Dual power train but with Motor and pedaling axis aligned with swingarm axis...
Lots of good stuff.
One drawback is the pedal assist is cadence based.
Anyone had a chance to try one and compare with the LMX64?
To LMX, may be time to look into a refresh of the LMX64 frame with a larger integrated battery, possibly in 2 parts modular to offer the flexibility between light weight or high capacity.
Simonten   1 W
1 W
Post by Simonten » Feb 27 2021 5:21pm
Boxxbike is 10kgs heavier. That is noticable, i feel lmx has a sweet spot of power vs weight, if any thing its over powered for my needs
scrambler   1 kW
Post by scrambler » Feb 27 2021 6:56pm
Agreed that it is a slightly different category, more power and therefore a bit more weight, and there is value in both segment.
But some of the technological choices made on the Boxxbike could be welcome in the LMX64, like having a frame that can handle more battery more easily, the concentric drivetrain swing arm axis....
These could be done without compromising the current LMX positioning.
Grantmac   10 kW
Post by Grantmac » Feb 27 2021 8:12pm
Lightweight motorcycle with pedals vs powerful ebike.
I actually wouldn't want a concentric drive, especially not shared with the pedals. You lose the ability to control squat.
scrambler   1 kW
Post by scrambler » Feb 27 2021 8:51pm
Grantmac wrote:
Feb 27 2021 8:12pm
Can you elaborate on what you lose control over ?
Grantmac   10 kW
Post by Grantmac » Feb 28 2021 12:03am
A concentric drive won't have any anti-squat behavior during acceleration which reduces traction, especially on rough ground.
bzhwindtalker   1 MW
Post by bzhwindtalker » Mar 01 2021 10:46am
Yes concentric drive without linkage has terrible pedaling performance.
TorEddy   100 W
Post by TorEddy » Mar 01 2021 1:58pm
Would this also apply if you have a primary reduction from motor to a jackshaft in the swingarm pivot, and a secondary reduction from the jackshaft to the rear wheel? This solution could achieve the same total reduction using larger cogs on both stages. using a primary timing belt and a secondary chain drive would result in less noise and more reduction abilities..
I find it hard to see if this would have the same ani-squat behavior and terrible pedaling performance.
My 3rd Ride - LMX64 : :mrgreen:
My 2nd Ride - BBSHD NS Bikes : viewtopic.php?f=28&t=73264&p=1106366#p1106366
My 1st Ride - LR GNG Commencal : http://endless-sphere.com/forums/viewto ... dy#p728668
http://www.tomaso.no
Grantmac   10 kW
Post by Grantmac » Mar 01 2021 3:07pm
In that situation you would have anti squat for the pedals but not the motor. Probably better to run the jack shaft on the left side pedal shaft.
scrambler   1 kW
Post by scrambler » Mar 01 2021 4:17pm
I think "terrible pedaling performance" is subjective.
There are a lot of talk on the subject, and how important the effect is, really depends on the type of usage and the other parameters of the bike.
I myself know that for my usage, the incidence is minor, and the other benefits outweigh it :)
Simonten   1 W
1 W
Post by Simonten » Mar 03 2021 9:58pm
For me any more power than the LMX 64 for peddling is redundant.
I like to feel like I am peddling which is why i took the throttle off my bike so its only pedal assist.
I wished that mode 1 had a speed limit of about 35K instead of 28k. I mainly use power level 1 unless i want to fly up a fire road.
I have to use level 3 down hill because of the speed limit cut off. Not because i need the extra power.
dsc995   1 µW
Post by dsc995 » Mar 04 2021 1:55am
I wonder if you could hack around this by changing the tire size in the computer? You would have to do some math to translate riding metrics or just use your phone gps for metrics
SlowCo   1 MW
Post by SlowCo » Mar 04 2021 5:30am
Simonten wrote:
Mar 03 2021 9:58pm
Isn't it possible to program the assist levels like with a Bafang BBS unit? There you can set the speed limits to 100% in all assist levels and have increasing current limits per assist level like this:
Bafang programming table.png (152.94 KiB) Viewed 88 times
Merlin   10 MW
Post by Merlin » Mar 04 2021 7:04am
Simonten wrote:
Mar 03 2021 9:58pm
you can change the speed limit simply with the program wire.
dsc995   1 µW
Post by dsc995 » Mar 04 2021 9:26am
Depends if they have the nuclar or the silixcon. Afaik the silixcon is not user programmable.
