E-S LMX 64 Bike Owners
Simonten   1 W
1 W
Re: E-S LMX 64 Bike Owners
Post by Simonten » Mar 31 2021 5:02pm
Is the polycarbon belt the same weight and noise reduction as the HP belt?
I am interested to see how much mileage I get out of my belt since I dont have a throttle
hkj   10 W
Post by hkj » Apr 04 2021 10:05am
New roller and belt installed. It was shipped with 4 spacers but I ended up only using three of them. Not sure what the idea is since no instructions came with the roller. Not using the new expensive belt. For now, I'll use the regular one last time.
scrambler   1 kW
Post by scrambler » Apr 05 2021 1:06pm
Does anyone know if the e-brakes on the LMX are "Openers" (normally closed), or "Closers" (normally open)?
I am wondering what works best with the Silixcon controller, or if the controller has inputs for either.
ringring   1 mW
Post by ringring » Apr 05 2021 4:11pm
Driving - NC. JWPF 4pin female plug, red pin4 + 5V to blue pin2 brake signal. Others: black pin1 is isolated ground for throttle, green pin3 is throttle signal.
scrambler   1 kW
Post by scrambler » Apr 05 2021 4:32pm
ringring wrote:
Apr 05 2021 4:11pm
Thanks,
I assume by NC you mean Normally Closed when riding, and open circuits when braking.
Can you elaborate on what you mean by JWPF and the actual wiring.
If this is an interrupt circuit (open when braking), I assume we either need to interrupt a harness wire to go through the brake sensor, or the harness already has one output wire to go to one of the brake connector, and one input wire to receive the other wire from the brake.
Either way if you can provide more details, that would be great.
Also, do you know by any chance if the Silixcon could also work with a Normally open lever (make connection on braking), as these are more convenient to connect brake lights.
Thanks again, appreciate your time.
Cowardlyduck   1.21 GW
1.21 GW
Post by Cowardlyduck » Apr 06 2021 7:12am
Received and fitted my new belt/roller today. Haven't ridden it yet though as I'm still waiting on a new rear tyre.
It looks to me like there isn't much room with the larger roller. Is the roller compatible with the first style roller arm?
Cheers
ebikegarage.com.au - My website
Ebike Garage - My YouTube Ebike ramblings.
Cowardlyducks - Videos - Ride videos
BikeE recumbent commuter - 9C, 6Fet Grinfineon, internal 17AH, 52V, + on-board solar.
Custom made 18650/21700 battery packs - Australia only
ringring   1 mW
Post by ringring » Apr 06 2021 8:55am
@scrambler
Yes, NC - normally closed while driving.
JWPF - is a type of connector manufactured by J.S.T. Mfg. Co., Ltd. Are used by silixcon. The controller has several of them. There is a 4-pin JWPF female connector for throttle and brake cut-off: 1 black isolated ground, 2 blue brake signals, 3 green throttle signals, red + 5V.
The LMX does not use the brake cut-off function. To drive the bike pin4, the red wire (+ 5V) is permanently connected to the blue wire on pin2 (brake signal). Pins 1, 3, 4 are for the throttle.
Take off the motor, below is controler silixcon and connectors. Find the 4pin connector - black, blue, green, red wires. Disconnect the connector, strip the insulation of the male connector, pin4 is connected to pin2. If you disconnect the connection from pin2 to pin4, the motor will not work.
In my LMX64 I made NC brakes and connected to pin2 and pin4.
I don't know if it can work with a normally open lever. It may be necessary to program the controller to NO.
scrambler   1 kW
Post by scrambler » Apr 06 2021 11:43am
Thank you @ringring for taking the time of a detailed explanation.
Is there a manual for the Silixcon that has this kind of information, or did you just figured it out or gather it around?
ringring   1 mW
Post by ringring » Apr 06 2021 3:09pm
scrambler   1 kW
Post by scrambler » Apr 06 2021 3:20pm
Thanks, but the link appears to be invalid (error 400)
ringring   1 mW
Post by ringring » Apr 06 2021 3:25pm
Hmm, something wrong, I can't link the complete link. If you want I will send a private message with pdf instruction. Or search for silixcon.com, then download then customer documentation then datasheets and select the SC model
scrambler   1 kW
Post by scrambler » Apr 06 2021 4:35pm
ringring wrote:
Apr 06 2021 3:25pm
Thanks, I had actually been on the Silixcon site download section but for some reason had missed that specific one :)
1.21 GW
Post by Cowardlyduck » Apr 07 2021 7:20am
Ok, had a crack at fitting the rear wheel with the new belt/pulley and nothing's lining up. :oops:
Not sure what I'm doing wrong, but I removed/reinstalled the whole assembly about 5 times with different spacers washers each time trying to line it up. Finally when I thought I had it all lined up...nope, rubs and makes a horrible noise.
What is the trick here? Should I flip the pulley so the flange is on the other side? Maybe the gen 1 pulley arm or rear sprocket don't have the same spacing...should I space the rear sprocket differently?
Open to any suggestions...even if that's just to keep trying. :)
Cheers
bzhwindtalker   1 MW
Post by bzhwindtalker » Apr 07 2021 10:22am
Move the tensionner M8 nut to the other side (bolt turns 180°), and also the pulley flange to the other side.
1.21 GW
Post by Cowardlyduck » Apr 08 2021 7:14am
bzhwindtalker wrote:
Apr 07 2021 10:22am
Thanks Adam!
I switched over the whole tensioner arm as well, but I think I need to swap it back now as I've reached the limit for adjustment and it's still not pushed over enough.
This is after another 3-4 complete reinstallations...super painful!
Getting much closer though, so I'll try a few more adjustments.
Cheers
Freakyfuego1   1 µW
Post by Freakyfuego1 » Apr 11 2021 11:42am
I am about to receive my belt kit. Do you know what tool to use in order to remove the brake disc center lock?
Thanks for your help
hkj   10 W
Post by hkj » Apr 11 2021 2:26pm
You want something called a hook key if I'm not mistaken.
They come in various sizes and construction and is usually a pain in the ass to use.
