26" Rim Suggestions
avoleoo   10 W
26" Rim Suggestions
Post by avoleoo » Jun 05 2019 8:01am
Can anyone please suggest a strong 26" 36H 32mm - 35mm rim for an ebike ( MAC Motor ) ? Not expensive, does not have to be the lightest.
Thank you.
cal3thousand   1.21 GW
1.21 GW
Re: 26" Rim Suggestions
Post by cal3thousand » Jun 05 2019 12:53pm
avoleoo wrote:
Jun 05 2019 8:01am
Thank you.
You'll find Alex rims as a great balance between price and strength. I use them almost exclusively for ebikes.
Alex DX32 is a good one for those purposes. Seems like they are getting harder to find tho
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
oldwahoo54   10 W
Post by oldwahoo54 » Jun 05 2019 8:07pm
I just re-built my original wheel from em3ev using a Rhyno Lite XL, 26", 36 hole. Seems fine but I don't have many miles on it. It is 24mm inner, 29mm outer. Running a Schwalbe Big Apple on it. I have a Mac 10t.
wturber   10 MW
Post by wturber » Jun 06 2019 12:28pm
avoleoo wrote:
Jun 05 2019 8:01am
Thank you.
It isn't quite as wide as you are looking for, but may be worth looking at.
https://www.velocityusa.com/product/rim ... hanger-559
"Commuter - DC Booster"
viewtopic.php?f=2&t=90369
Tommm   100 kW
Post by Tommm » Jun 06 2019 1:56pm
sun ringle duroc
avoleoo   10 W
Post by avoleoo » Jun 06 2019 2:57pm
Thank you guys a lot, I found what i needed.
