Help needed : DIY display for a TRANZX M07 motor
dadwarf
Hi,
I bought an almost complete e-bike (ARCADE ENJOY) with a mid drive motor (TRANZX M07 36v 250w) without display and battery !
I thought it will be easy to guess the communication protocol and build a display with an Arduino. But in the entire web i found no clue and the motor itself is perfectly quiet !
What i know :
- It uses i2c protocol to communicate with the display and the batterie.
- It uses a CYPRESS PSoC 1 (CY8C27443-24PVXI) microcontroller.
- It works with 36v.
- All pins designations (from the PCB).
- The original display is the TRANZX DP10.
- The battery i2c slave address is 0x0b (from this post)
- When i put 36v there is nothing on 5v, sda, scl pins, but if i put 5v on ISSP 5v pin a led flicks.
Photos :
PCBs front
PCBs back
External connector
The PSoc 1 programmer from CYPRESS cost 50€. the ISSP proprietary protocol has been ported to Arduino (hssp) but it looks uneasy to make a PSoC dump.
The motor probably act as master in i2c communication so i don't know how to make it talk first !
Yes i could buy a DP10 but it cost ~200€ and my goal is to build a display myself.
Even if make a fake battery with a Raspberry acting as i2c slave it won't help me with the display !
If someone could give me a clue to start with that motor i would be very happy !
