how to control the speed of bldc hub motor from the arduino...?
abbas jamali   1 µW
Post by abbas jamali » Jul 18 2019 1:50am
Tommm   100 kW
Re: cyclone controller help- 3 speed wiring
Post by Tommm » Jul 18 2019 3:41am
abbas jamali wrote:
Jul 18 2019 1:50am
Use a controller and then control the speed by sending singal to the throttle signal wire.
You will need an arduino with an analog output of 0-5v.
abbas jamali   1 µW
Post by abbas jamali » Jul 18 2019 11:32pm
thank you sir,
send the circuit diagram and coding
john61ct   100 GW
Post by john61ct » Jul 19 2019 1:43am
and some fresh squeezed orange juice with my breakfast, chop chop
E-HP   1 MW
Post by E-HP » Jul 19 2019 9:35am
abbas jamali wrote:
Jul 18 2019 11:32pm
thank you sir,
abbas jamali , I noticed that you've been attempting to get help by inserting questions into existing threads that sometimes don't pertain to the subject of those threads, with very little context. You have to provide useful information in order to receive useful advice. The best way to do that is to start a new thread with a subject specific to what you want advice on. This guide should help: viewtopic.php?f=3&t=66302
“how to control the speed of bldc hub motor from the arduino...?”
Re: Known to Work Brushless Motor/Controller Wiring Diagrams
“how to build speed controller for bldc hub motor 36 V 250 W with arduino nano ?”
“thank you sir,
send the circuit diagram and coding”
Re: How to select motor and gear ratio for mid-drive?
“hello sir,
which motor is best for electric bicycle can you suggest me name with company detail.”
Re: Rear Hub or Mid Drive for general XC riding?
“which motor is best for electric bicycles ..? geared hub motor or mid drive motor ..?”
Re: Battery Voltage and Motor choices
“i want to run a bicycle up to 36 km so which motor is suitable for this range”
