Three pin plug type?
Bigwheel   100 W
Post by Bigwheel » Jul 25 2019 8:00pm
This is the plug my 2170 battery uses for charging. I can't find out what type in a search. Need one to set up a charge cord for my Satiator and don't want to cut the one off the 4a stock charger....
Thanks in advance!
markz   100 GW
Re: Three pin plug type?
Post by markz » Jul 25 2019 8:08pm
See if you can find it on this website
https://www.ebikes.ca/shop/electric-bic ... rder=price
Perhaps this is the connector you need
XLR to Anderson Powerpole Adapter with 3-pin TRS Cable for Connecting Satiator to PC
One side (assuming its the silver side) is the XLR Nuetrik NC3FXX Connector (Id assume the F means Female, google images seems to confirm but do double check)
TRS Jack is for communication so snip that side off.
XLR Nuetrik NC3FXX
https://www.markertek.com/product/nc3fx ... black-gold
^Just some random site off of Google Images
Bigwheel   100 W
Post by Bigwheel » Jul 25 2019 8:18pm
I emailed Justin first because their 72v 2170 battery looked to have the same type plug. He said that there are 4-5 different ones out competing to take over the pin plug market and theirs is a bit different. Thus here I am.
E-HP   10 kW
Post by E-HP » Jul 25 2019 9:40pm
Bigwheel wrote:
Jul 25 2019 8:00pm
Thanks in advance!
I need help seeing the proportions. Maybe a picture of it on a table next to a dime or something. Looks kind of small for a charging cable, but maybe it's actually bigger.
amberwolf   100 GW
Post by amberwolf » Jul 26 2019 12:33am
Looks essentially the same size (including pins) as the 3-pin connector on the Satiator body itself.
markz   100 GW
Post by markz » Jul 26 2019 12:50pm
From the manual for the 5A version, in PDF form
https://www.ebikes.ca/downloads/?file=Satiator_Manual
7.1.2 Mechanical
DC Output Connector 10A MULTICOMP/SINGATRON 2CT3002-W03400
DC Output Cable 1m with 3-Pin Neutrik XLR, (1=DC+, 2=DC-, 3=Signal)
A quick online search
https://uk.farnell.com/multicomp/2ct300 ... dp/1860686
Its PDF File - http://www.farnell.com/datasheets/2828108.pdf
Farnell also has warehouses/stores in the USA.
Which flavor do you want?
https://uk.farnell.com/w/c/cable-wire-c ... rt=P_PRICE
Normal Style
https://uk.farnell.com/multicomp/2cm300 ... dp/1860751
https://uk.farnell.com/multicomp/2ct300 ... dp/1860700
90 degree style
https://uk.farnell.com/multicomp/2ct301 ... dp/1860711
E-HP   10 kW
Post by E-HP » Jul 26 2019 3:13pm
The upper right ones look to have similar indexing:
Bigwheel   100 W
Post by Bigwheel » Jul 26 2019 6:50pm
None so far will work. Note the flat part on the outer round. Thanks for trying!
markz   100 GW
Post by markz » Jul 27 2019 12:39pm
Could be the pictures they use are generic pics, perhaps its just the 3 pin m/f thats flattened at that spot.
E-HP   10 kW
Post by E-HP » Jul 27 2019 1:49pm
Bigwheel wrote:
Jul 26 2019 6:50pm
Looks like the female side can accept the outer flat part or if it were round.
