How many throttles have you damaged?
markz   100 GW
Post by markz » Jul 25 2019 8:27pm
Whether the wire colors were wrong, or some mystery controller, or just not thinking, or physical damage to the controller?
I have wired the throttle wrong and damaged about 3 or 4 throttles. Todays, was a mystery ebay purchase which had an on/off button for ignition, High/Med/Low battery indicator and the throttle all in one. The green wire in that had power for the led indicator, but the throttle signal was white.
flat tire   1 MW
Re: How many throttles have you damaged?
Post by flat tire » Jul 25 2019 8:34pm
I haven't damaged any like that, but I've crashed a lot and physically damaged the ends of 5 or 6 dominos.
docw009   100 kW
Post by docw009 » Jul 25 2019 8:47pm
Have not damaged any from electrical mishaps, but all were standard 3 wire units. If playing around with a model that brings in battery power to a start button, yes, you would probably smoke it if you miswired any of the low voltage throttle circuits to the battery,
e-beach   1 GW
1 GW
Location: Any Los Angeles area beach I am at. Or Santa Monica or possibly the south bay beaches.
Post by e-beach » Jul 25 2019 8:51pm
8 or 10 in like 7 years. I tend to release the throttle, I found, by slipping my thumb away from the throttle and it snaps back into the off position. Over time that also breaks the inside of the throttle.... :oops:
I have never gone so far as to wire one improperly even though the new throttles I get never have the right connectors. I just test the throttle on the bench and wire it to the existing connector.
:D :bolt:
Favorite Quotes:
"This is L.A., sugar. There is no 'over the top." Chris Erskine
"At a certain point the entropy wins." Maria Helena Braga
Current Build: ProFlex 757 Expert full suspension. Yescomusa 36v 800w Rear DD, upgraded 10AWG solid core through axle phase wires. 15ah Headway, 1000+ cycles, 80% DOD 30A Tronsung controller.
Past: Trek 4500 Yescomusa 36v 800w front DD.
Liahona, Yescomusa 36v 800w generic front DD.
1992 Trek 800, Yescomusa 800w 36v front DD.
amberwolf   100 GW
Post by amberwolf » Jul 26 2019 12:30am
Broke two thumb tabs off throttles, both by being near or at max throttle and then hitting some road damage that pushed my thumb harder against it than the plastic could stand. Both were also at least several years old at that point, exposed to teh harsh Phoenix sun and weather most of that time.
I don't think I've had any electrically damaged.
I have, however, read a number of times of people with the battery meters built into the throttles having the throttle (and sometimes the controller) fried simply by getting the throttle (or the connection to controlelr) wet, because the battery voltage can then leak into the hall power or signal lines, and there's no protection against that on anything connected to those.
larsb   1 MW
Post by larsb » Jul 26 2019 1:49am
Damaged one domino from strapping cable too tight to the frame. Short circuit and Runawaaaay throttle after a year or so :D
Scary
boytitan   100 W
Post by boytitan » Jul 29 2019 10:09pm
I no longer use thumb throttles I break them to much from force of hand.
