Brainpower Controller with LCD E10 Error
UnicycleSanta   1 µW
Post by UnicycleSanta » Jul 27 2019 6:43pm
Good afternoon everyone,
I have a Brainpower motor controller with LCD (LH-100) all wired up and I am getting an error code E10 as well as no throttle power. I have tried everything and the internet has not served me well in finding a result.
amberwolf   100 GW
Re: Brainpower Controller with LCD E10 Error
Post by amberwolf » Jul 27 2019 11:02pm
Did the system ever work, or is this the first test?
I don't know where a manual can be found for it, but Xunlida appears to be the manufacturer. There is a thread
viewtopic.php?f=2&t=96736
about this controller series that reports some info, but doens't mention the specific code you're getting.
UnicycleSanta   1 µW
Post by UnicycleSanta » Jul 28 2019 12:29am
This is the first test, I wonder if I should get a replacement unit and test it out.
Lh100Error10   1 µW
Post by Lh100Error10 » Jul 29 2019 2:23am
UnicycleSanta wrote:
Jul 27 2019 6:43pm
I installed the controller (LH-100 LCD and brainpower controller kit) yesterday and also got error 10 after turning it on, the throttle doesn't respond either.. did you find a solution?
I read online it means that either the LCD/LCD cable/controller is faulty.. or possibly wrong wire connection
I bought it from AliExpress, did you too?
Lh100Error10   1 µW
Post by Lh100Error10 » Aug 02 2019 10:58am
:cry: :cry: ?? Anyone?
amberwolf   100 GW
Post by amberwolf » Aug 02 2019 10:20pm
if you look up the OP's other posts, you'll find he posted this same thing with more detail in another thread, and there's replies there with more info for you.
