My battery is 52volt will i need a 48 volt bms or a 52 volt bms?
Glens carzy ebike   1 mW
Post by Glens carzy ebike » Aug 07 2019 7:46pm
Matador   10 kW
Re: My battery is 52volt will i need a 48 volt bms or a 52 volt bms?
Post by Matador » Aug 07 2019 8:23pm
A 14S BMS is necessary. Some 14S BMS can be used in 13S configuration.
john61ct   1 MW
Post by john61ct » Aug 08 2019 2:24am
14S x 3.7V = 51.8V nominal
14S x 4.2V = 58.8V max charging voltage
Is that what you are calling a "48V" bank?
Matador   10 kW
Post by Matador » Aug 08 2019 8:43pm
I think he meant 52V as a rounded figure for 51.8V nominal, thus 14S setup. Cause even hot of the charger a 13S setup is not close to that 52V figure (54.6V hot). Of course we assume Li-Ion but not LiFePO4... Given lack of detail specs.
Matador
john61ct   1 MW
Post by john61ct » Aug 08 2019 9:06pm
yep why I'm asking.
answer may well be
"dunno"
