Help me develop the perfect throttle
DasDouble   100 kW
Post by DasDouble » Aug 08 2019 4:02am
My current job right now from my boss is to develop the perfect eBike throttle (120mm wide, full wrist). Do you have any small or big wishes you always wanted to have in a 5V eBike throttle? Like a super-smooth spring-momentum or something similar?
Cheers, Elias
Mechatronics-Engineering Student
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
MJSfoto1956   10 kW
Re: Help me develop the perfect throttle
Post by MJSfoto1956 » Aug 08 2019 6:58am
You might want to study what these guys are doing:
https://www.motionpro.com/c/rev2-throttle
Trump lied. People died. His supporters high-fived.
Слишком мало, слишком поздно
DasDouble   100 kW
Post by DasDouble » Aug 08 2019 7:58am
MJSfoto1956 wrote:
Aug 08 2019 6:58am
Thanks, but all they are doing is installing a variabel range for the throttle which is already possible via Kelly Controler and much more + the linearity of its response
-Built own ebike: ✔
E-HP   100 kW
Post by E-HP » Aug 08 2019 9:05am
DasDouble wrote:
Aug 08 2019 7:58am
What's your list look like so far?
cycborg   1 kW
Post by cycborg » Aug 08 2019 9:13am
Bi-directional for regen
pwd   1 kW
Post by pwd » Aug 08 2019 9:21am
adjustable min and max positions
Commuter/Street Build viewtopic.php?f=6&t=98286:
Rocky Mountain Element
Magic Pie 4 front + Leafmotor 1500 rear w/ WCEC 18fet
Samsung 40T 14S7P
Offroad Build viewtopic.php?f=6&t=102195:
2019 Rocky Mountain Blizzard 20
Cyclone "3kw" 13T motor to 36T chain ring then 32T chain ring to 11T-46T Cassette
em3ev 14S5P 30Q or 14S6P 25R pack
NCC1941   10 W
Post by NCC1941 » Aug 08 2019 10:22am
cycborg wrote:
Aug 08 2019 9:13am
I'll enthusiastically second this.
"The Kitchen Sink" - 2016 Surly ECR 29", 2WD Grin All-Axle + 9C RH212, 2x Phaserunner, 52v50Ah EM3ev (Rolling WIP)
"Novara Barrow eBike" - 2016 Novara Barrow Bike, Luna BBS02, 52v28Ah EM3ev (Retired)
MJSfoto1956   10 kW
Post by MJSfoto1956 » Aug 08 2019 10:30am
DasDouble wrote:
Aug 08 2019 7:58am
I think that misses one key point: the "feel" of this type of throttle.
Mapping things in software only gets you so far in that regard.
M
john61ct   100 GW
Post by john61ct » Aug 08 2019 11:22am
Ability to "click" for slow & precise adjustment while cruising?
donn   10 kW
Post by donn » Aug 08 2019 12:45pm
john61ct wrote:
Aug 08 2019 11:22am
Interesting, I believe I'd go for that.
AHicks   1 kW
Post by AHicks » Aug 08 2019 1:26pm
Make sure it's possible to control the strength of the click, or disable completely. Otherwise there are going to be occasions where it's impossible to attain the speed you're after. E.G. when riding with somebody else, when following slower traffic, etc.
Grantmac   10 kW
Post by Grantmac » Aug 08 2019 1:47pm
cycborg wrote:
Aug 08 2019 9:13am
This, plus durable and stealthy.
john61ct   100 GW
Post by john61ct » Aug 08 2019 3:10pm
AHicks wrote:Make sure it's possible to control the strength of the click, or disable completely. Otherwise there are going to be occasions where it's impossible to attain the speed you're after. E.G. when riding with somebody else, when following slower traffic, etc.
No idea about that, my conception is, lets say from 0 to WOT 100% there are 50 gradients. They don't need to be equal, probably want finer controls between 30% and 80% than top and bottom.
The "clicking" feedback should not make the throttling any slower than if it were continuous greyscale.
But the "intensity" or even disabling of the feature is a "would be nice" 8-D
Drunkskunk   100 GW
Post by Drunkskunk » Aug 08 2019 4:15pm
NCC1941 wrote:
Aug 08 2019 10:22am
cycborg wrote:
Aug 08 2019 9:13am
An enthusiastically third from me. it would need to have a shorter range of travel, though, so you can modulate it while braking at the same time. 90 degree maybe?
john61ct wrote:
Aug 08 2019 11:22am
As long as this could be turned off, I see a good use for an indexing throttle, but it would drive me insane if I wasn't trying to set cruise. Throttles should be silky smooth.
I'd want a half grip option. I manhandle bicycles too much off road, and I want to be able to apply arm torque directly to the bar without twisting the throttle.
flat tire   1 MW
Post by flat tire » Aug 08 2019 4:39pm
Don't make it bidirectional, don't make it adjustable. You could put in a click at the end for safety or regen like domino but that's not important to me. Make it full length, all metal, well built, really smooth. Probably also best to not use a pot since they wear out.
Variable regen is best done elsewhere with another control.
I would pay at least like $250 if you make a throttle that is obviously better than domino.
AHicks   1 kW
Post by AHicks » Aug 08 2019 7:55pm
I prefer thumb throttles, but I really like the idea of variable regen. Maybe have a throttle on the right, and regen on the left?
Bigwheel   100 W
Post by Bigwheel » Aug 08 2019 8:06pm
Might work for riding on the street but I don't ever see a hand grip type throttle ever being useful for off-road. A thumb throttle works because it is out of the way and using a grip shifter with a half grip and detents does seem to work fine for me at least as it only will move when I want it to. My drop bar road bikes use a thumb throttle and I don't see any way of course to use a full grip throttle for those type of bars. But good luck with your project.
amberwolf   100 GW
Post by amberwolf » Aug 08 2019 8:25pm
All metal construction for durability. No plastic crap.
Design to have grip portion removable, leaving the mounting ring for the grip exposed, so one can turn it into a thumb (or half grip) throttle if desired. (since it's unlikely they'd go for making those versions, and they'd sell more of them if people can use them for other than full-grip without using a hacksaw). Easy to justify because grips can become damaged in laydowns/etc. and being able to replace just that part or at least take it off easily to rework or re-cover it would be very useful.
Waterproof. Pot the insides to seal them.
Adjustable "range", to adjust the feel of the throttle for the particular application. This can be done with a couple of tiny trimpots for the top and bottom range, simply wired in series with the 5v and ground lines to the sensor (or pot) inside. A couple of rubber caps (like the Meanwell HLG series uses) can fill the access holes to these for weatherproofing.
Vectrix-like regen capability, so you reverse twist from the "off" position to brake. This will have a completely separate sensor and output, with it's own trimpots to adjust it's range/feel.
Note that it is necessary to have the trimpots, as not all controllers have ability to adjust their input ranges, and certain situations, especially mounting positions, may require a different feel or movement range. WOuld also make it usable by someone with limited wrist/etc motoin range, where a regular unadjustable throttle would not be.
There's a bunch of threads in this list
search.php?keywords=throttle&terms=all& ... mit=Search
that discuss problems with various throttles, and solutions, that will help you, but you'll have to look thru them to find the information.
john61ct   100 GW
Post by john61ct » Aug 08 2019 8:39pm
Search URL failed for me
googly version
https://www.google.com/search?q=site%3A ... F+throttle
donn   10 kW
Post by donn » Aug 08 2019 8:46pm
I'm happy with a thumb throttle, but started with a half grip. Also used to ride a motorcycle, nice old '80s clunker with dell'Orto carburetors. The throttle on that old motorcycle was way better than the ebike throttle. I didn't do any real comparisons, and the motorcycle is gone, but you go out and try it yourself. I think just about any motorcycle would do, but I'd try for an old one, with carburetors and a tall first gear.
amberwolf   100 GW
Post by amberwolf » Aug 08 2019 9:01pm
john61ct wrote:
Aug 08 2019 8:39pm
Dunno why, unless there's something blocked on your system? Or if you are copy/pasting the visible portion instead of clicking it?
URL (not all of it always shows in a post due to PHPBB parsing) is:
Code: Select all
https://endless-sphere.com/forums/search.php?keywords=throttle&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
it should come up with:
Search found 1093 matches: throttle
amberwolf   100 GW
Post by amberwolf » Aug 08 2019 9:03pm
donn wrote:
Aug 08 2019 8:46pm
Primarily that's because most ebike systems use a speed (PWM) throttle, not a current (torque) throttle, which is more or less what you get on an ICE. So the response is very different, especially as you get into higher power bikes.
john61ct   100 GW
Post by john61ct » Aug 08 2019 9:19pm
amberwolf wrote: Dunno why
might be Tapatalk
response is
donn   10 kW
Post by donn » Aug 08 2019 9:36pm
amberwolf wrote:
Aug 08 2019 9:03pm
Could be. Sure a lot smoother up front, I mean heaven help me if I'd had to coordinate that ebike initial surge-on with a clutch, but it also seemed like I had to rotate the ebike throttle an awful far way for a middling speed output.
DasDouble   100 kW
Post by DasDouble » Aug 09 2019 1:34am
donn wrote:
Aug 08 2019 9:36pm
amberwolf wrote:
Aug 08 2019 9:03pm
As far as I understood it on the german videos about it, it says "45km/h" which makes it a 50ccm scooter-like vehicle with a small number plate =>> legal, not illegal
-Built own ebike: ✔
