TSDZ2 48V VLCD6 issues
tomkut   100 µW
100 µW
Post by tomkut » Aug 30 2019 3:59pm
I wonder if anyone could help me with the following issues identified on the kit (from pswpower):
1) the speed display shows random numbers or 99 at speed <11 km/h
2) the motor does not work at speed < approximately 11 km/h
3) the odometer and trip counter, both display incorrect distance, higher than actual
4) I cannot access the power select setting on the VLCD6 by pressing all three buttons
wpenner   100 W
Re: TSDZ2 48V VLCD6 issues
Post by wpenner » Aug 31 2019 10:04am
tomkut wrote:
Aug 30 2019 3:59pm
4) I cannot access the power select setting on the VLCD6 by pressing all three buttons.
The magnet has to line up with the flat part of the speed sensor, not the round pivot part.
To get to the config menu is tricky and has to be done right after lcd power on. You use two buttons, not three. Not sure about lcd6, I only have lcd5 https://www.youtube.com/watch?v=RlMZTA3 ... ture=share
Power settings in lcd menu do not adjust power of motor. The motor power level is hard coded preprogrammed. You can however increase the max speed to 45km/hr
tomkut   100 µW
100 µW
Post by tomkut » Sep 04 2019 6:47pm
i have the magnet aligned and it does work above 11km/h. The problem is below 11km/h, when I get erratic readings.
I used the following instructions to access all options but the power: https://drive.google.com/open?id=1ZiNNZ ... tNR-QwFUNB
You stated that the power is hardcoded, but in the video power is being adjusted.
James Broadhurst   100 W
Post by James Broadhurst » Sep 05 2019 3:05am
1, 2 and 3 are all due to the same problem: the gap between the speed sensor and the wheel magnet is too close. Ignore what the manual says; it was written for the original speed sensor which was fine and then it was replaced some years ago with one which was claimed by someone on here as being more sensitive. He was right about that!
tomkut   100 µW
100 µW
Post by tomkut » Sep 05 2019 4:38pm
thank you james and wpenner. Indeed, the magnet was too close. Issues 1-3 resolved. It's great to have power from the start! and correct readings from the computer.
