i am considering building a trike using a bike trike conversion kit like
https://www.bicycledesigner.com/trike-parts/hollow-hub-trike-conversion-kit.html
this will solve many problems.
1. broken kickstands as the 3rd wheel will act as a kickstand
2. stability i will be building it as a lowrider and stretching it an additional foot or 2 using square steel tubing
http://www.bing.com/search?q=square+punched+tubing&form=APMCS1
3. spoke breakage the minimum size wheel that will support more than 36 spokes is 16 inch with 72 spokes.
4. chainsuck jams and broken shifter parts (derailer and hanger and bent chain) because i intend on having 3 motors.
1 for the speed limit of 20 mph or 32kph for you metric users
second for power (separate chain and cogs)
3rd for regen or dynamic braking witch will just be a super brute hub from electricrider.com.
i know the law limits to 750 watts but having 2 drives may make it 1500 but the catch is both drives can not be used at the same time it is physically impossible in the same way that you cant have both rear wheels drive without differential .
would the law have any problems with this setup?
i can see the police could say something if they see multiple motors but other than multiple motors would the officer only be able to go by the speed or aggressiveness of the take off i.e burning donuts or wheelieing so i should be safe then.
seeing the such wide range of travel on the adjustability of the rear cogs i see room for 3 maybe 4 cogs.
the hub motor just for regen i was wondering how regen is activated.
is it start working when you pull the break lever or does the throttle have to be pushed too?
i do scrap metal recycling and the only scrap yard that can pay me more and take electronics as tin is 30 miles away over some very steep hills that would destroy the derailer and the hanger otherwise
the only scrap yard locally does not take electronics as tin and even recently cracked down on stuff with excessive plastic, wood and glass and i suspect it is because the owner operates out of new york thereby making it federal jurisdiction
so the power would be needed to go up the steep hills and the regen or dynamic braking is to prevent burning up the brakes coming down the hills.
