Who here rides with the Cow Horn style handlebars?
markz   100 GW
Post by markz » Sep 20 2019 12:10am
I have tried riding two bicycles that had that type of handlebar and I just did not like it one bit.
I like a 27-30" wide, with a 5" riser. Straight across on the stem but the grips and shifters with a slight bend.
Like the Wald 8038GB or the Sunlite.
Not much selection at all between 5.25" and 8.5", though I have been able to find 8" but they wanted to much $.
This is what I was riding today, and yesterday, and the day before that. Not that exact bike, same everything, except mine had a front rack, no rear rack, a nice springy Norco seat. Its a Norco Santiago. Slightly smaller then my ole Townie Electra. About 2" length difference on the top bar and down tube.
cow horn handlebars2.jpg (108.3 KiB) Viewed 549 times
Other examples of cow horn handlebars
cow horn handlebars.jpg (30.58 KiB) Viewed 549 times
cow horn handlebars1.jpg (46.03 KiB) Viewed 549 times
markz   100 GW
Re: Who here rides with the Cow Horn style handlebars?
Post by markz » Sep 20 2019 12:12am
Urrrgh
cow horn handlebars3.jpg (130.81 KiB) Viewed 547 times
Nooooooooooooooooooooooo!
cow horn handlebars4.jpg (99.93 KiB) Viewed 546 times
Soooooo un-natural Sooooo sooooooooooooo soooooooooooooooooo not right
cow horn handlebars5.jpg (120.07 KiB) Viewed 545 times
position de conduite française
cow horn handlebars6.jpg (125.68 KiB) Viewed 542 times
amberwolf   100 GW
Post by amberwolf » Sep 20 2019 12:27am
Looks like you're showing at least two, maybe three, completely different kinds of handlebars, but calling them the same thing.
The first ones you show are sometiems called "moon" bars these days, have previously just been called "cruiser" bars.
Those
that I don't recall the name of, are essentially what I use on SB Cruiser and CrazyBike2, but they are used in a completely different position, and work perfectly for these rides, except the grip area is more "vertical" (more parallel to the bike frame) on mine.
The set on CB2 came off a Schwinn postal bike from teh 1960s or 1950s, I forget which. IIRC, the set on SBC came off a similar-age bike, I think it was also a Schwinn, with a Sturmey Archer 3speed IGH (shifter was still on the bars, came with the wheel holding the IGH).
From front of trike, pretty much like it's now
Previous setup sort of from rider view
From underneath, just prior to presetn setup, while I was rewiring things
Should be pics of teh CB2 bars in that bike's thread.
E-HP   10 kW
Post by E-HP » Sep 20 2019 10:26am
Does this count?
Not as much sweep as your examples, but far from a straight bar. A couple degrees less sweep would be perfect for my wrists, but they're not too bad.
RunForTheHills   100 W
Post by RunForTheHills » Sep 20 2019 10:36am
I bought the Nitto Albatross bar for my build, but they swept back too far for me.
I ended up getting the Jones Loop SG 2.5. It only has 2.5" of rise, but I also used a lot of spacers on the stem to lift it up higher.
The On-One Mary bar might be a good fit for you with a tall stem to bring it up higher.
Post by RunForTheHills » Sep 20 2019 10:43am
If your bike uses a quill stem, the Nitto Dirt Drop will bring it up really high.
miro13car   1 MW
Post by miro13car » Sep 20 2019 11:00am
I am have two such handlebars in my spare parts storage,
I would call them grandpa cruise bicycle handlebars.
Well to much upright riding psition for me.
Eplus, Bionx
thundercamel   100 W
Post by thundercamel » Sep 20 2019 11:05am
amberwolf wrote:
Sep 20 2019 12:27am
Those
North Road bars?
My Ebike builds - Existing bikes, affordable motor kits, self built 14s6p batteries - Now with more recumbent!
markz   100 GW
Post by markz » Sep 20 2019 1:18pm
Its getting there, but probably not as I've ridden that style o handeebar. Not awkward for me to ride that style
To each their own.
I like a slight sweep back on my handlebars.
E-HP wrote:
Sep 20 2019 10:26am
Does this count?
Not sure what to call any style of handlebar, maybe cow horn style can also be called major sweep back. Sometimes it can hit the knees, othertimes I cant turn a lot because the grips hit my stomach. I also like to hang a bag off my handlebar, the one I am riding now I have to move the knee out of the way on every pedal.
Too bad Amazon doesnt have the one I want, have to wait until Oct 26. It is a 28" wide 5.25" riser with 8 degrees back sweep and a 1 degree upsweep.
MadRhino   100 GW
Post by MadRhino » Sep 20 2019 5:44pm
I like handlebars 800mm wide, 15mm rise, 8° back and 4° up. Very far from cow horn design, which I did ride on a vintage motorcycle long ago.
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
Post by RunForTheHills » Sep 20 2019 8:09pm
Maybe the Nitto Bosco:
amberwolf   100 GW
Post by amberwolf » Sep 20 2019 10:59pm
thundercamel wrote:
Sep 20 2019 11:05am
North Road bars?
Mine have much less outward angle to the grip section. (they're also much much older chromed steel).
MadRhino   100 GW
Post by MadRhino » Sep 21 2019 1:51pm
Well, cows are many, and their horns of all styles.
Mine handlebars that I ride on my actual bikes:
Thomson Ti
Race Face Atlas
Crank Brothers Iodine
Current bikes
markz   100 GW
Post by markz » Sep 21 2019 10:03pm
That is why I named it Cow Horn style.
I ride feet forward cruisers so I like an upright riding position.
The only upside for me, for cow horn handlebars, is I place my hands above the shifters and rest my fore arms on the grips. Sometimes I will put my elbow on the grip as I am riding and hold my head. :lol:
MadRhino wrote:
Sep 21 2019 1:51pm
MikeSSS   100 W
Post by MikeSSS » Sep 24 2019 1:48pm
This is a great thread, it will help a lot of people.
Thanks to all for the pics and names of the bars.
markz   100 GW
Post by markz » Sep 24 2019 6:00pm
Everyone has their preferences of handle bar styles. Sometimes I will place the handlebars too far forward, then the first curb they are all the way forward and down. Its happened a cpl times :oops:
MikeSSS wrote:
Sep 24 2019 1:48pm
E-HP   10 kW
Post by E-HP » Sep 24 2019 6:25pm
markz wrote:
Sep 24 2019 6:00pm
MikeSSS wrote:
Sep 24 2019 1:48pm
I agree, knowing the style names is helpful. I like the feel and grip angle of cafe style bars on motorcycles, so that's what I put in the search to find the ones I'm using now. Probably would have been difficult to find without that as the starting point.
Post by RunForTheHills » Sep 24 2019 8:56pm
Well if you want some more examples:
The Velo Orange Tourist is a nice set of bars that I used on my wife's and daughter's bikes.
Northroad style bars mentioned earlier sweep further back similar to the Albatross bars, but maybe not as much.
These are the Nitto Mustache bars. I don't understand them, but some people like them:
This is another strange one known as bull horn bars:
dogman dan   100 GW
Post by dogman dan » Sep 25 2019 6:01am
Much depends on your body position. This is greatly affected by the frame type, and how it fits your body.
I like the moon/cruiser bars on my cruiser a lot! Riding straight upright on that frame which is long in front, you need the cruiser bar just to reach the bars in an upright position.
Put those bars on most mtb's, and you will not be able to turn while pedaling. Whack your knee on it, unless you point then way up, forcing an un natural wrist position that will be bad for you on a long ride. Same thing happens to me with other types of bars that have similar sweep, but the problem is not so much the bars, as it is poor frame fit. I get lots of my height in the leg. So its a frame don't fit me issue, really.
On mtb's, it took me awhile to learn how to use a straight, or nearly straight bar with less sweep. You have to sit right, or you get wrist pain. The trick is riding with bent elbows. I had been used to riding with a straight elbow on road/racing bars. I had to learn a new way to sit the bike, to ride an mtb.
When I started commuting on mtb's, I first sought out bars with a bit more sweep that required a bit less elbow bend, and then finally settled on using BMX bars. I found those had a sweep I liked, and also had a lot of rise so I could ride even more upright.
Toorbough ULL-Zeveigh   10 MW
Post by Toorbough ULL-Zeveigh » Sep 25 2019 1:28pm
moo
Kick down the barricades Listen what the kids say.
From time to time people change their minds But the Frock is here to stay.
I've seen it all from the bottom to the top Everywhere I go the kids wanna Frock.
Around the world or around the block Everywhere I go the kids wanna Frock.
markz   100 GW
Post by markz » Sep 26 2019 2:32pm
I am digging the riding position of a 4" wide fatty, with my normal cruiser 5.25" rise handlebars. I just need it in black to match the bikes frame color.
I find, looking back, riding the cruiser style I tend to slouch. The normal frame geometry of a mtb or fatty with flat handlebars makes it too low, but with the 5" rise I feel its better. I may even go a little taller, perhaps 9" or 8" if I can find at a cheap price. I dont like ape hanger style handlebars that I've seen on my searches.
MadRhino   100 GW
Post by MadRhino » Sep 26 2019 5:15pm
markz wrote:
Sep 26 2019 2:32pm
... flat handlebars makes it too low, but with the 5" rise I feel its better...
Well, I would lower the hind, or fit a longer travel suspension on the front... or both
Current bikes
markz   100 GW
Post by markz » Sep 26 2019 5:26pm
Seats already pretty low. I like a flat foot on the ground when sitting in position on the bike. I wont ride with no flat handlebars anymore. I am not as old as some, but I am old enough.
MadRhino wrote:
Sep 26 2019 5:15pm
markz wrote:
Sep 26 2019 2:32pm
E-HP   10 kW
Post by E-HP » Sep 26 2019 6:27pm
Toorbough ULL-Zeveigh wrote:
Sep 25 2019 1:28pm
moo
Now you're really milking this thread. :lol:
E-HP   10 kW
Post by E-HP » Oct 01 2019 10:54am
Maybe I’m the only one with this issue. My current bars and back sweep feel great for riding. I can go a long way without discomfort, riding with PAS.
I’ve been practicing using throttle lately, negotiating right turns and hills or obstacles at slower speeds, etc. The problem is that for using the throttle, the sweep sucks and I quickly develop discomfort around my thumb and wrist area.
I suspect a slightly reduced back sweep would help, but maybe this is something that will always be a compromise. Never had the issue with motorcycles, but maybe I’m just old and crotchety now.
The half throttle diameter is slightly bigger than I’d prefer, but maybe changing that would alleviate the issue as well.
