JamieWlcox
- Joined
- Mar 5, 2018
- Messages
- 24
Hi,
I am a proud new owner of a 60v 30ah battery. I have upgraded from a 48/20.(both lifepo4)soft pack 1p.
I recieved the battery today and took reading of 67/22. That opened my eyes because that high of voltage should = higher amp on 60/30. Charger cut off is 73.5 and measures 24 amp no load. So come to my supprise amps are not the same as AH.
I put the battery on the charger and it topped off in less than 10 min at 72.6/24.1.
Immediately I felt disscuraged. But am i incorrect in thinking a 60/30AH lipo battery should measure 30 amp fully charged?
One other question for users out there,
What do you think 1750 watts will do to a 1000 watt hub motor with 1500 watt controller max is 84v/45 amp
I'm using 12 gauge wire and also replaced hub stock motor wire with rated 1500 watt to internal 3 phase windings
thanks for your help
