Assistance with Rear Hub Motor, Speed Control and Battery Selection for a High Speed World Record Attempt Ebike
Andy@MiRider   1 mW
Post by Andy@MiRider » Nov 15 2019 5:46am
Guys,
My company are looking into building a one-off version of our folding electric bike in order to set a top speed world record, verified by the Guinness Book of World Records.
Our bike is compact and has 16" Diameter wheels.......this therefore does sound madness I realise.
I am as the companies Technical manager going to modify and strengthen the frame to accommodate the required rear wheel hub motor. I can go to a maximum of a 20" rear wheel although would love to stick to a 16" rear wheel :-)
As this is going to be a high speed run only, battery duration is not important.
Is 120KPH possible? and what wil I need hardware wise?
All and any help gratefully received guys.
Cheers
Andy
E-HP   100 kW
Re: Assistance with Rear Hub Motor, Speed Control and Battery Selection for a High Speed World Record Attempt Ebike
Post by E-HP » Nov 15 2019 9:38am
Andy@MiRider wrote:
Nov 15 2019 5:46am
The Guinness record for an ebike is 165mph, so you need to more than double your velocity target. What frame geometry are you planning on to remain stable at those speeds?
Andy@MiRider   1 mW
Post by Andy@MiRider » Nov 15 2019 11:19am
Hi, we want to set a speed record for a FOLDING Electric bike....at present there is no world record for this particular category Our company manufacture a folding bike with a magnesium die cast frame which i intend to use as part of the build. I will replace the rear suspension arms with a steel unit, manufactured to fit the motor that is to be used.
Thanks, Andy
Jonno   10 W
Post by Jonno » Nov 15 2019 11:25am
Hi Andy,
Easily achievable you just need lots of volts - 120V a apt96600 controller and QS hub motor
EEB frame, 888 forks, QS273 40h V3 , Nucular Electronics 24F controller, 84V @ 36ah 26650 cells, Vortecks 300a BMS, Hope 203mm + Regen braking
Andy@MiRider   1 mW
Post by Andy@MiRider » Nov 15 2019 11:26am
I have searched the Guinness Book of World Records just now and there is no record with them for the worlds fastest electric bike.... :bigthumb:
Andy@MiRider   1 mW
Jonno,
Which QS Motor do you recommend my friend?
Cheers,
Andy
Jonno   10 W
Post by Jonno » Nov 15 2019 11:31am
danielrlee   10 kW
Post by danielrlee » Nov 15 2019 11:33am
Hi again Andy. How long is the wheelbase of the frame in question? I'm willing to bet you'll have to double it to make the bike stable at those sort of speeds.
https://TorqueTech.co.uk : Electric bike spares, parts & accessories : 10% discount code ’ENDLESS10
john61ct   1 GW
1 GW
Post by john61ct » Nov 15 2019 2:07pm
Why not the 273 v3 version, rated 4000W?
Apparently a newer 275 exists too.
j bjork   1 kW
Post by j bjork » Nov 15 2019 2:41pm
Is there a reason to limit the choices to e-bike motors?
I am thinking motorcycle hub, I dont know what size rim would be similar to 16" bike. Maybe 13-14"?
Something like this 8kw: http://www.cnqsmotor.com/en/article_rea ... r/617.html
j bjork   1 kW
Post by j bjork » Nov 15 2019 2:47pm
Jonno wrote:
Nov 15 2019 11:25am
Hi Andy,
There should be a 1000A version available too, look at lars B:s post.
High voltage, high amps, big hub and small folding bike.
I don't think I would dare to ride it :lol:
Where is that clip of lifeforfysics deathbike flipping over when you need it :mrgreen:
E-HP   100 kW
Post by E-HP » Nov 15 2019 3:33pm
Andy@MiRider wrote:
Nov 15 2019 11:19am
if there's no record, then you can set a record with your stock bicycle, unless there's some special rule against it. That would be better advertising for your company's bike.
