Need a replacement conversion kit
phytema   1 mW
Post by phytema » Nov 16 2019 9:24pm
My controller is probably at the end of its life and I might have to replace the rear wheel hub motor too. Could you recommend another conversion kit? (1500w hub motor, 60v sinewave controller (model KT60SVPRK-SLS02G), see attached pictures).
Thanks
controller 1.jpg (217.37 KiB) Viewed 1521 times
controller 2.jpg (215.43 KiB) Viewed 1521 times
Glens carzy ebike   10 mW
Re: Need a replacement conversion kit
Post by Glens carzy ebike » Nov 26 2019 4:59pm
Get a kit from this website mine runs good as https://www.leafbike.com/
world wide shipping
[F0]   100 µW
100 µW
Post by [F0] » Nov 26 2019 5:32pm
I have the 29" voilamart 1500w kit. It was $200 on ebay without the LED display, but I cant see any 29" kits for sale at the moment.
This is a 26" kit though for $193.
https://www.ebay.com/itm/Voilamart-Elec ... g&LH_BIN=1
Post by Glens carzy ebike » Nov 26 2019 6:52pm
ebay ones don't last that long
[F0]   100 µW
100 µW
Post by [F0] » Nov 27 2019 12:29am
Glens carzy ebike wrote:
Nov 26 2019 6:52pm
The controller maybe, but you can buy a replacement for $30-40. The motor is generic and won't get overworked with the ebay controller. Still more than half the cost of leafbike.
markz   100 GW
Post by markz » Nov 28 2019 11:25pm
Lots of ebay motors have lasted a very long time, its the controllers that dont last. I just buy sensorless from Greentime and call it a day, stock up on a few throttles, throw in a spare controller and call it a day.
wturber   10 MW
Post by wturber » Nov 29 2019 2:15pm
I don't see a clear reason why you need a new kit. In the one post you mention broken spokes. So get the wheel rebuilt. Make sure that they rebuild using a smaller gauge, high quality butted spoke. Go to someone who is known for doing good wheel re-builds, or do it yourself.
If there is other information that you've left out that argues for a new kit, then please include it.
As for ebay kits, I'm a few hundred miles from completing 10,000 miles on my kit. Everything appears to be working fine after a little more than two years - except that I too had the spoke breakage problem and had the wheel rebuilt.
"Commuter - DC Booster"
viewtopic.php?f=2&t=90369
wturber   10 MW
Post by wturber » Nov 29 2019 2:18pm
Nov 26 2019 6:52pm
Sure they do. Their major weakness is that they use 12 gauge spokes that will probably start breaking after a few thousand miles. But Leafbike's description says that they also use 12 gauge spokes. So those are likely to start breaking at a similar point as well.
E-HP   100 kW
Post by E-HP » Nov 29 2019 3:02pm
Nov 26 2019 6:52pm
How many have you worn out?
