hello
Anyone used this for their ebike?
https://s.click.aliexpress.com/e/AvtwcITKj
I think it's possible to stack as many as needed but no idea on reliability on ebike with all vibration
Stackable power wall kit with 18650 on ebike
Re: Stackable power wall kit with 18650 on ebike
possibilities in that design outer case to clamp physically with padding to absorb shock/vibration
but would want parallel at the bottom level, then treat each group as a single cell.
allowing for flexible xPyS grouping using jumpers maybe
imagine
if you add resistance all those contacts ...
vibration even with padding is going to loosen those contacts sooner or later.
Eplus, Bionx
That company has 10s 36v, 13s 48v, and 14s 52v battery holders for 18650 cells.
The battery holders can stack up to make 2p, 3p, 4p, etc batteries.
That is a very interesting concept. If a cell goes bad in say a 13s stack, you just replace the one cell, no spot welding.
I did a 15.3 mile ride the other day and averaged 2.7 amps, using my 13s 4p battery, each series group would be providing about 0.7 amps. That should be well within the capabilities of these battery holders. The holders use a 15A fuse and charge is recommended to be limited to 2A when charging the holder as a unit.
There would be no BMS, occasional balancing would be done by individually charging each battery holder unit.
For low power applications this should work, but it might not be cheaper than buying a pre-made ebike battery on ebay or Amazon.
- dogman dan 100 GW
Hmm, interesting. Little disc of lead in each contact, tightening the spring pressure and improving the resistance?
Maybe solder blob on each spring?
Seems like it could be a great thing for those with a pallet of laptop packs.
Frankenbike longtail
http://endless-sphere.com/forums/viewto ... cing+betty.
bolt on longtail https://endless-sphere.com/forums/viewt ... =6&t=74584
The mixte long tail. https://endless-sphere.com/forums/viewt ... =6&t=74384
Beach cruiser converted to long tail. https://endless-sphere.com/forums/viewt ... r#p1045572
Battery building the easy way.
Model railroaders use a conductive grease on track connections. That might be just the thing.
Some 18650s have a small dome on the positive end, those made for single cell flashlights and stuff. Cells made for spot welding don't have that dome, they might be shorter than the dome cells.
Perhaps the cell holders have enough room and spring travel enough to work with both kinds of cells, hope so.
- MAXIMUM_AMPS 10 mW
I've seen those, they're primarily made for powerwalls, and other low-current stuff. Performance is similar to the Vruzend V1.5 kits.cwah wrote: ↑Nov 24 2019 6:16amhello
They could work on an ebike for sure, but when you start asking for >5A per cell, you need spot welded connections.
