Looking for a 60V controller
Pegazus   10 mW
Post by Pegazus » Dec 04 2019 2:16am
Hi,
I already have a 48V 1kw Kunteng controller.
I'd like to upgrade my 13s battery to a 14s battery. The voltage will go up to 58.8V at full charge and I'm not sure that my controller will handle it, can you confirme that ?
On the other hand, I'm looking for a 60V controller compatible with Eggrider V2, I'd be very interested if you had any reference or model in mind for such controller.
Thanks for your enlightened opinion :)
john61ct   1 GW
1 GW
Re: Looking for a 60V controller
Post by john61ct » Dec 04 2019 3:00am
You should go up to 72+, less stress on the components, or why not 90V? so you have room for expansion
E-HP   100 kW
Post by E-HP » Dec 04 2019 6:12am
Pegazus wrote:
Dec 04 2019 2:16am
Hi,
My 1000w KT is labeled 36/48v. I've only run it at 52v.
MAXIMUM_AMPS   10 mW
Post by MAXIMUM_AMPS » Dec 04 2019 3:46pm
Pegazus wrote:
Dec 04 2019 2:16am
Hi,
You should be good to go:
63V is a common rating for the capacitors used in controllers. Generally you find passive components in the E-series of numbers, 10, 22, 47, 63, etc.
If it's a "48V" controller it's likely also using IRFB3077 or similar FETs which are rated for 75V maximum.
999zip999   100 GW
Post by 999zip999 » Dec 04 2019 4:02pm
Open it up a have look see. Does it have 63v or 75 v Caps or ? If 63v it should work. Just like a motor or battery you can melt down long hiills ect.
nomo81   100 µW
100 µW
Post by nomo81 » Dec 16 2019 5:43am
Hi Pegazus
dont know if it helps, but there is a realy nice guy Paul from "revelpropulsion" who has an eggrider compatible to an ASI BAC 500.
Im not an expert, but if it works with an BAC 800 you would be fine. Maybe you can ask.
Please let us know...
With kind regard from germany
john61ct   1 GW
1 GW
Post by john61ct » Dec 16 2019 1:46pm
Get a controller rated at higher voltage than what you will regularly use
you will have more margin against failure.
Pushing up against component limits will reduce reliability and lifespan.
dogman dan   100 GW
Post by dogman dan » Dec 17 2019 3:55pm
Yeah, could shorten life to five years or so. Seriously, open er up, and see if you see 63v on the little cans inside. If you do, its fine to run it on 14s.
I have one controller like that, a 36v 48v, that I still run today. Got it in 2010, and ran it on 14s the entire time. That one is a bit exceptional, other very good controllers I had lasted at least 6 years.
Think about it a bit,,, you will have 58v in that battery for what, a block or two? Then it will drop to 56 or so, and run there for miles. So that's 7v under the 63v limit on the caps.
Pegazus   10 mW
Post by Pegazus » Dec 22 2019 2:48am
Thanks for your support !
Will check the cap value and all other references.
