New here so Thanks for all the info I've been reading non-stop for hrs on past post.
Ok so I'm mechanically inclined can rebuild fix anything on a combustion engine & wiring but electric is a new world I'm fascinated in but there's tons to learn.
So with that said I'm want to spend 3k to 4k on Used or build one from parts. I ride on 4000+ acres of private land In Montana from mountains tight single track to prairie grass checking livestock.
Wants. Enduro style frame as light as possible but not carbon (if it breaks I need to tig weld to fix)
Rear or mid drive? I want Sur Ron type power 5000w ish but the ability to tone it down to 1000w when im tooling around the house or I take it to our small town for a parts run & be able to pedal if needed. If the Sur Ron had pedal ability & didn't look like a dirt bike I'd probably buy it.
Would like to stay with fat tires for soft ground or snow so I can air down.
Battery volts & AH? Would like to get aprox 30 miles of range
Is regenerative braking worth it or out of my price range?
Sorry for the post being so long winded I'm sure allot of this has been covered here & there in post so thanks for the help.
