goatman
im playing with my torque arms. I cant fasten them to the outside of the drop outs with out the motor falling off. I was able to mount one on the chain side in between the freewheel and bolted to the drop out area. disc brake side I need to file the axle so the torque arm goes toward the motor 1/4 inch and then it will bolt to drop out. on that side I just might make a torque plate instead because I keep flaring out torque arms. has anyone jb welded the arms or plates to the axles.
basically I want to jb weld the torque arms or plates to the axle, bolt everything solidly to the swing arm and let the jb weld cure
