Hi all, after a great first mid drive tsdz2 build I need to start my second ebike project. (Yes, I'm definitely infected by the diy ebike virus)
I need to build an ebike to commute 40k a day and I want to able to do it at not less than 40k/hr (25 mil/hr) on very flat terrain. I could do that speed on the 750w tsdz2, but it's not the optimal tool for the job (I now installed that motor it on my wife's bike).
Due the terrain is really flat so high torque situations will not happen often
With above goal in mind, I plan to buy a 500-750ish Watt rear hub drive motor, but I'm not sure about what type of motor and brand to buy.
- Would a direct drive be the best choice and make less long term problems? Or nowadays the geared hub motors work well enough?
- Seems a sinewave controller should be a must?
- I guess I should aim not less than 48v/20Ah controller?.
What would the experts recommend?
Important too, I don't want to break the bank and I live in Europe). Thanks!
