Page 5 of 10
Re: I need help, as i dont have anywhere to ask, and no one to help me
Posted: Jul 26 2020 3:47am
by Balmorhea
Davidcroatia wrote:
Jul 25 2020 12:21pm
Are you satisfied with it ? Do you brake your fork ? How much km per hour do you go ? Do you have an okay range ?
I like the Leaf motor and I'm satisfied with its performance and construction quality. I have powerful, reliable and low-maintenance linear-pull brakes front and rear. My top speed so far on level ground is about 52 kph, but I usually cruise at 30-35 kph with the assist level turned down to 2 or 3 (out of 5).
I don't expect very good range because I'm tall and heavy, over 2 m and about 200 kg total including the bike. Riding as I usually do, in city conditions with lots of stops, I use close to 25 Wh per km.
I have the 6 turn winding, but its rpm/volt is a little too high for 29" wheels. For a bike without suspension, like mine, I think the 8 turn version would be a better match.
Posted: Jul 26 2020 1:22pm
by markz
That seems to be about average, I dont know for sure what my wh/km is but I just use 20wh/km yet I do not pedal much so 25wh/km is more likely. 6'5" 190kg with Leaf 1500W 5T. Do you use your H-brake with its one wire? I hooked up the Low Brake to a Wuxing brake lever and it just turns off the power to the throttle only setup I have when I use the lever. I am hoping the Hbrake on the Leaf 1500W will give me some motor braking.
On the 1500W I like the fact the wire cable coming out of the axle has a bit of protection with a spring wrapped around the wire cable. Hooking up a temp gauge to the windings would be helpful. I noticed near the end of my ride, right after a hill climb that wasnt anything spectacular, the cover plate was very hot. I am more careful now and doing the touch test on the cover plate more often to get a feel for how much it heats up after certain hills.
Balmorhea wrote:
Jul 26 2020 3:47am
Davidcroatia wrote:
Jul 25 2020 12:21pm
Posted: Jul 26 2020 1:27pm
by Balmorhea
markz wrote:
Jul 26 2020 1:22pm
I don't use any kind of electrical brake. My torque arm only works for forward drive. And my rim brakes are really good.
Posted: Jul 26 2020 1:34pm
by markz
Balmorhea wrote:
Jul 26 2020 1:27pm
markz wrote:
Jul 26 2020 1:22pm
Yeah I prefer rim brakes myself, can't beat $4 pads! Cheapest disc pads are $21 cdn here, such a ripoff.
Posted: Jul 26 2020 1:39pm
by Davidcroatia
markz wrote:
Jul 26 2020 1:34pm
Balmorhea wrote:
Jul 26 2020 1:27pm
markz wrote:
Jul 26 2020 1:22pm
Used shimano hidraulic brakes are 30$ , brake pads 1.5$ on aliexpress 25 days arrive
Posted: Jul 26 2020 1:45pm
by Balmorhea
markz wrote:
Jul 26 2020 1:34pm
Balmorhea wrote:
Jul 26 2020 1:27pm
markz wrote:
Jul 26 2020 1:22pm
At the moment, my front rim brake pads are a really expensive kind, $20 retail. They work great, they're lasting very well, but I can't say they're twice as good as $10 pads.
Posted: Jul 26 2020 1:52pm
by markz
I have not used Koolstop pads yet, here they are about $20cdn, or $15usd. Just far too expensive for my liking, there is a set I buy from Chain Reaction Cycle that seems to last, Jagwire or Clarks, others seem to disintegrate too easily. Thats what makes me wonder about Aliexpress disc pads, are they using Asbesto's in the pad mix, who knows right.
Posted: Jul 26 2020 1:55pm
by Balmorhea
Davidcroatia wrote:
Jul 26 2020 1:39pm
Good V-brakes cost $20 brand new, and don't need to be bled like used hydraulics. Where I live, a single brake bleed costs more than $30 by itself.
My own rim brakes are stronger, with more natural feel, than any bicycle disc brake I'm aware of (though many aren't).
Disc brakes are something I use when there is a good reason not to use a rim brake. Because there are already good reasons not to use discs, or hydraulics.
Posted: Jul 26 2020 2:01pm
by Balmorhea
markz wrote:
Jul 26 2020 1:52pm
Jagwire V-brake pads have been our default option at the shop for years. Before that, we sold Avid pads, but I like the Jagwire ones better.
Kool Stop salmon compound pads have higher friction coefficient and last longer. At my shop, they're $12-14 versus $8 for generics, and that's a better bargain per mile.
Posted: Jul 26 2020 5:22pm
by Davidcroatia
Im using 7 years already brake pads from aliexpress and ebay , used shimano brakes are 30$ to 40$ , brake bleed kit is around 10$ , lhm+ citroen hidraulics oil is great for shimano brakes , removing air from shimano brakes is 5 minutes , youtube video , and is very easy. Using vbrakes on ebike seems dangerous to me, i also tried hidraulics brakes 10 years ago, considering i tried it i will never go back, just make sure you use shimano or tektro brakes, as other use dot 4 or 5.1 oil and seals get wasted quickly
Posted: Jul 27 2020 4:52am
by markz
So are you riding now with electrons?
Davidcroatia wrote:
Jul 26 2020 5:22pm
Posted: Jul 27 2020 3:35pm
by Davidcroatia
Yes but there is much to the story, im gonna write all soon
Posted: Jul 27 2020 6:47pm
by markz
Davidcroatia wrote:
Jul 27 2020 3:35pm
Oh we just can't hardly wait, I will start popping the popcorn and someone will bring the Dill seasoning salts.
Posted: Jul 28 2020 2:40am
by Davidcroatia
Yeah thanks :) . Well... I went to s guy to make a c clip. He used existing clip to weld, then he used electronic rotating tool to shim it to fit the qxle. Now on 2 places rubber coating is gone because of bolts from 6 bolt disc, but that happened before c clips, and one phase wire has missing insulation, and wire can be seen, i have put insulation tape over it, but the problem is its on a place deep inside where it bends so yeah. The cable is in opposite direction of the frame and it sticks out, because if it goes along the frame there is no place to put the wire. Day before yesterday i had a flat and bought schwslbe marathon 26x2.00 and they are really narrow so im worried a little bit but its okay, i have put a shortened chain but its very saggy, not even chain tentioner would help, now i go to work :)
Posted: Jul 29 2020 12:43pm
by Davidcroatia
My phone wont charge from the lcd connector. It just charges a little bit then it wont
Posted: Jul 29 2020 12:59pm
by E-HP
Davidcroatia wrote:
Jul 29 2020 12:43pm
Would that be a normal "pissed off", a "so pissed off", or a "very pissed off"? :)
Posted: Jul 29 2020 5:23pm
by Davidcroatia
Normal pissed off because wolt delivery app wastes all 4000mah in pocophone in 2 hours
by Davidcroatia
Why is that happening ?
Posted: Jul 29 2020 6:40pm
by markz
E-HP wrote:
Jul 29 2020 12:59pm
Probably can't connect to Facebook to update status, or Tweet about something. In today's society it has really come down to that. I am in nature, riding the trails with electrons and you got people staring at their phones instead of looking at the butterflies and birds and tree leafs and branches and ridges and clouds and airplanes and squirrels and rabbits and deer, no no gotta look at the cell phone.
Posted: Jul 29 2020 6:53pm
by E-HP
markz wrote:
Jul 29 2020 6:40pm
I saw these three bucks on the trail the other day. My bike it pretty silent, and these guys were big enough that they didn't feel threatened, and just looked at me as I rode by. The one on top had 6 points, and all were in "velvet", with fuzzy antlers...took the picture with my cell phone :lol:
3 bucks s.jpg (146.06 KiB) Viewed 897 times
Posted: Jul 30 2020 9:03am
by Davidcroatia
I have to dissapoint you i only use whatsupp in my life :))) nnoow can someone tell me why it only charges for 1 minute
Posted: Jul 30 2020 9:23am
by E-HP
Davidcroatia wrote:
Jul 30 2020 9:03am
Well you have a 5 page thread with no details about the equipment you are using except the motor, and this is the first time you mentioned you have an LCD. So based on the information you provided so far, sounds like something is wrong. :roll:
Posted: Jul 30 2020 1:37pm
by markz
E-HP wrote:
Jul 30 2020 9:23am
Davidcroatia wrote:
Jul 30 2020 9:03am
Very informative E-HP
:thumb:
:wink:
Posted: Jul 30 2020 10:30pm
by Davidcroatia
Oh im sorry if you havent watched a vide in the FIRST post that i have posted on this thread. I know my english sound a little bit russian, but its managable
Posted: Jul 30 2020 10:32pm
by Davidcroatia
Davidcroatia wrote:
Jul 13 2020 1:58pm
Hello, this is my first ebike build and i dont have a clue what could be rhe problem, im adding throttle but almost nothing helps . https://imgur.com/a/4zvbfoy
https://youtu.be/lXGZ-mxtYY8
https://youtu.be/feRsy8ailhM
Nothing here doesnt give away i dont posses a lcd screen except the whole video that i shot, 40% of the video happens on an lcd i own
