I need help, as i dont have anywhere to ask, and no one to help me
Davidcroatia   100 W
Re: I need help, as i dont have anywhere to ask, and no one to help me
Post by Davidcroatia » Sep 13 2020 2:40am
I know for them, and i know for Mate yrimac, but the price id steep, remember when i needed hall and phase combo? I paid 60 euros for that, other guy over the phone said hey come to my store thats 20km away, i dont mean to be rude, or judge people, but 15 euros would be fair price for that 1 minute work
Davidcroatia   100 W
Post by Davidcroatia » Sep 13 2020 3:46am
Sorry, this is not ordinary multimeter, where do i put the probes and what do i turn on ?
Davidcroatia   100 W
Post by Davidcroatia » Sep 13 2020 3:53am
I put the probes like on google, but the posibilities are not the same as volmeters in videos for hall testing, what do i turn on ?
Davidcroatia   100 W
Post by Davidcroatia » Sep 13 2020 4:06am
I put it on 2. Option, all is saying like 0.036 to 0.040 , and im spinnig the wheel nothing really happens, it could be that the multi is bad, i know its cheap. I put the black wire and black probe
Davidcroatia   100 W
Post by Davidcroatia » Sep 13 2020 4:51am
This is with power on, the voltage is 0 on all https://youtu.be/eQ7WoPQhoOs
Davidcroatia   100 W
Post by Davidcroatia » Sep 13 2020 5:35am
This is the newest video https://youtu.be/yyXnLuCCWFk
Davidcroatia   100 W
Post by Davidcroatia » Sep 13 2020 6:12am
I got a reccomendatiom that this will fit ? https://m.conrad.hr/hall-senzor-infineo ... id=02-aa-m
MadRhino   100 GW
Post by MadRhino » Sep 13 2020 7:51am
It is very unlikely that you fried 3 hall sensors at once. Don’t test them plugged to the controller. You want to know if halls and wiring are good in the motor. If they are OK, then it will be time to identify the cause on controller side. If they are not, it will be time to open the motor to see if the cause is in the wiring or hall sensor. Only then you can shop for Honeywell hall sensors replacement.
Current bikes
Street:
Dirt:
Santa Cruz V10. 50mph
Davidcroatia   100 W
Post by Davidcroatia » Sep 13 2020 11:37am
MadRhino wrote:
Sep 13 2020 7:51am
This test is made without connected to cont
Davidcroatia   100 W
Post by Davidcroatia » Sep 13 2020 11:38am
Davidcroatia wrote:
Sep 13 2020 11:37am
MadRhino wrote:
Sep 13 2020 7:51am
https://youtu.be/V8q0gIbgS3M
Davidcroatia   100 W
Because shipping time is enormus 5 days
MadRhino   100 GW
Post by MadRhino » Sep 13 2020 12:19pm
If you have no return signal on the three of them, the problem is probably in the 5v circuit (red/black wires). One of them might have been damaged, or cut.
We see nothing of your test procedure on the vid. What source did you supply the 5v circuit with?
Current bikes
Street:
Dirt:
Davidcroatia   100 W
Post by Davidcroatia » Sep 13 2020 1:00pm
Here i didnt used any voltage, should i use one ? 5v red is plus , black is minus ? 5v 2amp can !
MadRhino   100 GW
Post by MadRhino » Sep 13 2020 2:36pm
Yes. You need to supply the halls with 5v and rotate the wheel to test. Each hall sensor does return a signal for one phase. It doesn’t need to be 5v but not too high of course. The test can be done with a 9v smoke alarm battery without any damage.
https://electricbike.com/forum/forum/kn ... controller
Current bikes
Street:
Dirt:
Davidcroatia   100 W
Post by Davidcroatia » Sep 13 2020 4:39pm
In europe we dont have smoke alarms , also i seem to be failing tripping the charging on my phone charger so i cant connect it
MadRhino   100 GW
Post by MadRhino » Sep 13 2020 7:03pm
Davidcroatia wrote:
Sep 13 2020 4:39pm
Ah! They are in every house here, and 9v batteries are very common.
Yet, if you don’t have a 9v battery, use any other combination of batteries to make 5+ v
Current bikes
Street:
Dirt:
Davidcroatia   100 W
Post by Davidcroatia » Sep 14 2020 4:13pm
Can someone say are they dead
MadRhino   100 GW
Post by MadRhino » Sep 14 2020 9:01pm
From the video, I can’t tell nothing. I am far from home and only use a cell phone.
Post the test procedure and result.
Then, while you are at it, test the phases too. Test each against the axle, then each against each other while rotating the wheel.
Current bikes
Street:
Dirt:
Davidcroatia   100 W
Post by Davidcroatia » Sep 17 2020 5:55am
This came today but i will connect it tommorow
