Really Dumb Question
evglobal19   100 mW
Post by evglobal19 » Jul 31 2020 12:09pm
Hello All,
on my DIY project have all components and donor frame assembled.
QS Motor QS273 72v 5kw hub
Sabvoton 72150 controller
20S12P 72V Panasonic 32BD 38.5ah with 100A BMS
Everything connected except the battery to the controller
Do I just connect battery and start programming? Do I need to connect to a computer first?
can anyone provide just the super simple idiot proof step by step so I don't fry anything :-)
Jonno   100 W
Re: Really Dumb Question
Post by Jonno » Jul 31 2020 12:12pm
Plug it in - what display is it?
Modified EEB frame, 888 forks, 280mm DNM pit bike shock, QS273 40h V3 , Nucular Electronics 24F controller 300a, 92V @ 36ah 26650 cells, 300a BMS, Hope V4 + Galfer223mm discs + Variable regen braking
evglobal19   100 mW
Post by evglobal19 » Jul 31 2020 1:19pm
the back of the display shows:
AP7
750C TFTV3GC85 NB 1.0
V1 30W 201905292018
Jonno   100 W
Post by Jonno » Aug 01 2020 1:56am
A picture would be good :)
HK12K   10 kW
Post by HK12K » Aug 01 2020 1:58pm
You should have a fuse or approximately rated dc breaker between the battery and the controller. Aside from that, light her up. (But keep the rear wheel off of the ground and yourself away from the pedals and other rotating bits until you're sure it's sorted and ready to ride!!)
999zip999   100 GW
Post by 999zip999 » Aug 01 2020 9:51pm
I use a pre resistor so no big spark and so that the controller caps and help them from overload from the voltage of a full battery. Clean that up.
