Shunt comparison pics
ebike11   100 kW
Post by ebike11 » Aug 01 2020 12:18pm
Hi guys..i know it may not be a big deal. Plan on removing my grin shunt for one that can handle more power.
First ordered a 150A then thought to go for a 200A.
They are cheap so not expecting anything fancy but its weird that the 150A one is so much bigger and heavier.
E-HP   100 kW
Re: Shunt comparison pics
Post by E-HP » Aug 01 2020 12:39pm
The shunt(s) are the black part(s) in you pics. Looking at your second and third pics, the 200A shunts are wider than the 150A, in order to pass more current.
ebike11   100 kW
Post by ebike11 » Aug 01 2020 1:04pm
E-HP wrote:
Aug 01 2020 12:39pm
Oh I see. So the "bodies" of the shunt makes no difference?
E-HP   100 kW
Post by E-HP » Aug 01 2020 1:15pm
ebike11 wrote:
Aug 01 2020 1:04pm
E-HP wrote:
Aug 01 2020 12:39pm
Pretty much. The additional contribution to the resistance from the lug sections should be minimal, when comparing the large cross sectional area of the chunky body parts relative to the very small cross section of the thin shunts.
ebike11   100 kW
Post by ebike11 » Aug 02 2020 4:23pm
E-HP wrote:
Aug 01 2020 1:15pm
ebike11 wrote:
Aug 01 2020 1:04pm
E-HP wrote:
Aug 01 2020 12:39pm
Thanks for your advice!!
Im guessing then that under the rubber coating on the grin shunt is just 2 small pieces of metal?
E-HP   100 kW
Post by E-HP » Aug 02 2020 4:59pm
ebike11 wrote:
Aug 02 2020 4:23pm
E-HP wrote:
Aug 01 2020 1:15pm
ebike11 wrote:
Aug 01 2020 1:04pm
E-HP wrote:
Aug 01 2020 12:39pm
Could be any number. The metal is a specific alloy, and just needs to be sized/calibrated to have a known voltage drop with a known current, within an operating range (and temperature).
ebike11   100 kW
Post by ebike11 » Aug 02 2020 7:07pm
E-HP wrote:
Aug 02 2020 4:59pm
ebike11 wrote:
Aug 02 2020 4:23pm
E-HP wrote:
Aug 01 2020 1:15pm
ebike11 wrote:
Aug 01 2020 1:04pm
I see thanks!!
