Not sure I'm buying that one. Mostly not sure a half an amp difference is enough to feel, or for the motor to care about in terms of time to overheat. It may be true though, that a big controller wastes less amps into heat, than a tiny one running full out or something, causing that too small to matter difference you see on the sim.
I'm not saying these small differences don't exist, i'm saying they are small, and pretty insignificant out on the road.
In all the testing I did for Ebikekit, what REALLY matters is the load on the motor. You make that load big enough, the motor needs to be bigger, and amps higher, to make it rotate with any efficiency. To clarify what I mean by all this, a half amp difference in draw at the controller is meaningless, vs a a motor overloaded running at less than 50% efficiency. All that really matters in that situation is that you need a bigger motor, if you overload it enough.
Rule of thumb used by the warranty of EBK, is 300 pounds total weight for bike, kit, battery, luggage and rider could be warranted. It would climb 10% without overheating motors for miles, It would climb 15% for half a mile. Hell yes its running very inefficient if you are climbing 10% and the load is 300, but it would make it. At 400 pound load, 7% would kill it.
To beat it to death, what matters most with system efficiency is how much you are overloading the motor. If you want better efficiency with more weight than 300 pounds, power up till you fly up that hill at efficient rpms, and better still use smaller wheel diameter. (hub motors)
Best efficiency not overloaded is even simpler, slow to 15-20 mph, where you can put 25% of the energy needed for that speed into it by pedaling, and use 25% less battery too. Result, double the range from your setup.
All that other shit, micro differences in efficiency by changing controllers, changing windings, Its all stuff you can make up with a block or two of just pedal with the motor off. Or actually pedal hard up the hills. Yeah, its a difference, but not significant at all compared to whatever speed you ride, slow down 2 mph. Or stop overloading, get the big motor if you are that big.
