Geared Hub Motor for 135MM FRONT dropouts
wozzlegummich   100 µW
100 µW
Post by wozzlegummich » Oct 06 2020 2:48am
I've got a MATE X E-Bike powered by a Shengyi 500w hub motor. In the interests of staying reasonably stealthy, I would like to fit a 500W small, black geared hub motor. Trouble is a 48V 500W hub motor for a front wheel with 135MM dropouts are like hen's teeth if not impossible to find. My fingers are sore from all the Googling.
My question is, can a REAR 48V 500W 135mm Geared hub motor be used in a front wheel setup? I have been told that maybe a freewheel type of hub (as opposed to cassette type) may be able to fit but I really wasn't sure of the advice.
Tommm   100 kW
Re: Geared Hub Motor for 135MM FRONT dropouts
Post by Tommm » Oct 06 2020 3:09am
yes.
qwerkus   10 kW
Post by qwerkus » Oct 06 2020 4:47am
wozzlegummich wrote:
Oct 06 2020 2:48am
Get a rear hub motor with freewheel threading. They are usually better centered.
2 things though:
- setting up a disc brake will be a pain. Distance rotor - caliper is different on the front wheel (only 10mm vs 15 rear). You'll need a spacer.
- use at least on torque arm: forks are even more prone to bending / outright braking than rear dropouts
markz   100 GW
Post by markz » Oct 06 2020 12:58pm
Use atleast one torque arm, but two is better.
I have used my rear leaf hub motor on the front fork of a fat bike without any problems. My torque arms were 1/4"x1"x4" steel plate with notches ground out with a angle grinder for the axle, and notches to hold in place the hose clamp.
leisesturm   100 W
Post by leisesturm » Oct 06 2020 11:28pm
It's expensive, but I think the Grin "All Axle Motor" would work here. Grin also has pre-fabricated 1/4" steel torque arms.
Bigwheel   100 W
Post by Bigwheel » Oct 07 2020 12:46am
leisesturm wrote:
Oct 06 2020 11:28pm
All Axle motors are 100mm.
markz   100 GW
Post by markz » Oct 07 2020 2:28pm
Bigwheel wrote:
Oct 07 2020 12:46am
leisesturm wrote:
Oct 06 2020 11:28pm
https://ebikes.ca/product-info/grin-pro ... motor.html
The All Axle motor is a direct-drive front hub that we designed to be universally compatible with all the variety of quick release and thru-axle front fork standards that exist in the bike world these days, as well as many single side mounts for trike and quad vehicles. The round hollow axle means that the motor produces no spreading forces on slotted dropouts, and instead is able to transfer all the torque safely to the fork blade via a built-in torque arm.
edit - The [...quote]
I didnt notice the wheel misaligned to the top tube with a rear freewheel hub placed on the front of my Costco fat bike. I will have to check that once I can get into the garage. I have been stuck in the basement for the last 2 months and shouldnt be long before I'm 100%.
dogman dan   100 GW
Post by dogman dan » Oct 07 2020 2:50pm
Any geared motor made for rear 135 mm dropouts works fine in front on 135 mm front forks. Typical application is a fat bike.
Just remove the freewheel, or cassette. No need at all to buy anything exotic.
If its a disc fork, it should line up fine.
Bigwheel   100 W
Post by Bigwheel » Oct 08 2020 2:44pm
markz wrote:
Oct 07 2020 2:28pm
Bigwheel wrote:
Oct 07 2020 12:46am
leisesturm wrote:
Oct 06 2020 11:28pm
I stand corrected. I've had one since the beta phase and hadn't looked at the new wording. It does make sense that adapters could be made but I can't figure out how they work due to disc caliper to rotor alignment other than the wheel would have to sit offset in the fork with a long adapter on the other side? I'm sure they have it figured out and I'm not in the market anyway. Winter is for skiing.
