Hailong 03 down tube battery - how to attach it appropriately?
Laissez   10 W
Post by Laissez » Feb 18 2021 9:58am
Hi,
I'll just ask everyone: how did you attach your HaiLong 03 down tube battery to the frame? The battery is quite heavy at 6.6 kg. Images etc. are appreciated. Thinking how to mount the battery to my new project.
Mclewis1   10 µW
10 µW
Re: Hailong 03 down tube battery - how to attach it appropriately?
Post by Mclewis1 » Feb 18 2021 10:35am
I saw from your posting on another forum that the Wolf Tooth components B-RAD mounting products were mentioned. To me those and the Grin Technologies BOB products are the best quality options for mounting heavy downtube batteries (but there are a few other simpler options). One characteristic of your frame that negates one of the really effective benefits of the Grin BOB products is the shape of your downtube. Not being a round tube the "outriggers" on the BOB mounts don't look like they'll come into play (but I might still try them, it will depend on how deep the sides or outriggers are and whether or not they will contact the downtube). This will put more side to side twisting force on the mounting points on the frame.
If I was mounting a big downtube battery on your style frame I'd want to use more than just two threaded frame mounting points. So I might consider adding a wrap around type of mounting for the stand off mounting points which I think are very beneficial on their own as they provide a flat and long/wide mounting surface for the bottom of the battery. Given that bottom piece is structurally plastic (with a thin steel reinforcement to keep the bolts from digging in) I think anything that spreads out the load and keeps it more stable is also beneficial.
https://www.wolftoothcomponents.com/col ... rad-system
https://ebikes.ca/shop/electric-bicycle ... ories.html
Laissez   10 W
Post by Laissez » Feb 18 2021 11:44am
Mclewis1 wrote:
Feb 18 2021 10:35am
Yes, I know about the bottle bobs, but the problem with those are shipping cost which is almost 50 dollars to Europe otherwise I would try them but +70 dollars is just too much. Also on my previous bike I had solution like wolftooth only problem with that it elevates battery quite high and it's not that good solution to bumpy offroads.
Some rubber padding/spacers between the mounting solution and frame could add some stability.
Laissez   10 W
Post by Laissez » Feb 18 2021 11:45am
Mclewis1 wrote:
Feb 18 2021 10:35am
Yes, I know about the bottle bobs, but the problem with those are shipping cost which is almost 50 dollars to Europe otherwise I would try them but +70 dollars is just too much. Also on my previous bike I had solution like wolftooth(https://www.aliexpress.com/item/4000453357310.html) only problem with that it elevates battery quite high and it's not that good solution to bumpy offroads and this is going to be my offroad bike with middrive.
Actually just found out that they do sell these bottle bobs, double bobs etc. on europe:
https://www.ebike-solutions.com/en/deta ... ticle/1098
Price is still a bit steep with shipping 44€ which makes it 54 usd.
99t4   100 W
Post by 99t4 » Feb 19 2021 1:24am
Add a few more rivet nuts (sometimes called "rivnuts") to the DT. Four should anchor it better than two, no? 5mm is standard but you could easily install 6mm.
If you feel you lack the skills (check YT for adding rivnuts to bicycle frame) most good bicycle shops do this routinely, no big deal.
ilu   100 W
Post by ilu » Feb 19 2021 5:48am
You could also use these if the tube diameter is max 5cm. But rivnuts might be better option, and cheaper unless you need to pay for the work.
In addition, for offroad I recommend using straps, I have these. Even with the base fixed with three bolts on a flat-top down tube, the plastic bends a bit and the battery wobbles sideways, but the straps make it solid. Taking the battery off is slightly more complicated though.
powrtrip   1 mW
Post by powrtrip » Feb 20 2021 4:09pm
installed threaded nuts to frame in 3 places... ground down the other ones flat.... https://www.harborfreight.com/45-piece- ... -1210.html
Laissez   10 W
Hailong battery a bit wobbly
Post by Laissez » Mar 10 2021 8:45am
I would like to have a bit more side support with the battery. Any tips to make my Hailong mounting a bit sturdier? Now It's bolted to both bottle bob holes and with zip ties. It's a bit wobbly at the bottom and I would like to stop that.
SlowCo   1 MW
Re: Hailong battery a bit wobbly
Post by SlowCo » Mar 10 2021 9:40am
Use more mounting holes by using threaded rivets and use glue/sealant to support the holder better. See this video at 5:38 and from 13:13:
99t4   100 W
Post by 99t4 » Mar 11 2021 12:32am
That one mounting screw I can see in your photo looks like it is deforming the plastic. A fender washer (wider washer with small hole) under the screw head might help spread the load and help stabelize.
Laissez   10 W
Post by Laissez » Mar 11 2021 3:25am
SlowCo wrote:
Mar 10 2021 9:40am
I don't want to drill additional holes to frame.
99t4 wrote:
Mar 11 2021 12:32am
Thanks for idea, I'll go to buy wider washers.
