juniper motor from ASI
goatman   100 MW
Post by goatman » May 05 2021 5:03pm
anyone have experience with them?
https://www.acceleratedsystems.com/prod ... ric-motors
looks perfect for a phaserunner, rated for 95 phase amps
neptronix   100 GW
Re: juniper motor from ASI
Post by neptronix » May 13 2021 11:06pm
No but i want one.
All those poles make it a torque monster. The very tight wound stator means you don't pay an efficiency penalty .
I would bet that the laminations are razor thin which is an improvement over everything else on the market.
It would probably rip in a 20 inch wheel... just add ferrofluid :shock:
I've sent an inquiry about the price.
Attached is the spec sheet.
asi_juniper_motor_spec_sheet.pdf
(1.72 MiB) Downloaded 20 times
My first major build: 1.6kW 8T MAC motor on a Trek 4500 MTB.
Monster MTB: Leafmotor 1500w @ 4kW on a Turner O2 full suspension.
The monster scooter: Heavy duty Cannondale semi recumbent - under construction.
Blue Dream: Maxaraya FS semi recumbent and high efficiency mid-drive - under construction.
larsb   10 MW
Post by larsb » May 14 2021 7:21am
Now that’s a nicely wound motor! Doesn’t get much better than that.
Looks to be 0.5mm laminations
The Toecutter   10 kW
Post by The Toecutter » May 14 2021 7:59am
I wonder if they have different windings available. The one in the spec sheet would reach ~36 mph @ 48V with a 26" wheel, ~28 mph with a 20" wheel. This is good for a street legal setup, but if one wants to go faster, they'll need to run a higher voltage pack. If one could get away with running 96V, it would be ideal for a velomobile, and probably make 3-5 kW peak power.
Custom electric velomobile, 1500W: viewtopic.php?f=6&t=110298
neptronix   100 GW
Post by neptronix » May 14 2021 9:45am
If they're achieving such high efficiency from 0.5mm lams, i'm legitimately stunned.
Those laminations look finer than that to my eye, but the caliper doesn't lie.
I'll call them today.
neptronix   100 GW
Post by neptronix » May 14 2021 12:39pm
Okay. Talked to an engineer over there.
Couldn't get a stator lamination spec out of them, sadly.
Stated peak efficiency figure of 92% seems unclear; the motor graph shows peaking at 85% efficiency or so.
85% efficiency would mean larsb's thought of 0.5mm lams is true.
The high pole count means low end torque will be consistently impressive and i get the impression this is a motor designed to squeeze the most power out of a ~500w limitation. The weight is exceptionally low for a DD of this size, so there's some good materials choices or design choices that aren't apparent from the pictures.
I think it could be a good motor in some use cases, but doesn't strike me as an exceptional motor.
I suggested some design changes, but it seems that production of the motor is halted for the time being, so who knows what lies in the future for ASI's hub motors.
Voltron   1 GW
1 GW
Post by Voltron » May 14 2021 1:18pm
It actually looks quite a bit like later gen Stromer motors, that had a similar circular plug with the flip out metal pull handle, and four bolt brake rotor... Not an easy replacement item to find btw, I think it's a Magura thing?
