Rear hub motor cassette removal tool??
paulstung   100 W
Post by paulstung » Jun 02 2021 6:47am
I want to swap out the included 7 speed cassette for a single speed, but the one I have hasn't got a big enough hole going through it to be able to fit over the axle, and from looking on Google they all basically look the same.
So what's my options?
Ebike specific or adapt the one I have?
Manbeer   100 W
Re: Rear hub motor cassette removal tool??
Post by Manbeer » Jun 02 2021 7:07am
is it a cassette or freewheel? if freewheel, i hear the DNP tool works well for hub motors but not sure of its availability in all areas
motomech   1.21 GW
1.21 GW
Post by motomech » Jun 02 2021 9:52pm
There are some that are big enough to go over an ebike axle or you can bore them out using a "pointy" grinding bit that fits in a drill motor. Don't try and use a drill bit as the tool is hardened.
'11 Motobecane Fathom team, Bafang SWX02-13T, 14S (54V) LiPoly, 9-FET 17A controller. Schwalbe Marathon's, 24 to 25 MPH.
Hobie Passport Kayak w/ Watersnake 18# motor, 12S LiPoly (46V) to golf cart 12V converter, 4 mph
E-HP   100 MW
Post by E-HP » Jun 02 2021 10:24pm
If it's a freewheel (not a cassette): https://www.amazon.com/dp/B01FI8WWZY/ref=emc_b_5_t
  • Fits freewheels with 12-spline, 22.6mm tool fittings including Shimano, Sachs Aris, SunRace, DNP Epoch and other 5–10 speed freewheels
  • Features enlarged 15mm pass-thru hole to accommodate 14mm solid axles
  • Thin wall construction allows use without removal of cones and locknuts
  • One inch hexagonal base fits wrench, socket or bench vise
  • Heat treated alloy tool steel
dogman dan   100 GW
Post by dogman dan » Jun 03 2021 6:52am
Just drill out the one you got. If you have the drill, and the big bit. Otherwise the new tool with a bigger hole may be cheaper than buying tools.
skeetab5780   10 MW
Post by skeetab5780 » Jun 03 2021 7:11am
ya put it in a vise and use a round file to enlarge the hole, way easier than drilling, harbor freight sells round files for like $2
docw009   100 kW
Post by docw009 » Jun 05 2021 9:37am
I like my Parke FR1-3. Cheaper than buying a hardened bit? I dunno. Get it in three business days.
https://www.ebay.com/itm/222153495484?e ... SwNrNdKotZ
Yeah. Cheaper than a good step drill bit, $19.99 at Home Depot. Of course, you can destroy q $6 bit from ebay and it might last long enough. I think they are for plastic,
https://www.homedepot.com/p/Milwaukee-1 ... /204312636
E-HP   100 MW
Post by E-HP » Jun 05 2021 9:54am
docw009 wrote:
Jun 05 2021 9:37am
1 day shipping but $1.50 more on Amazon. (but the OP never clarified freewheel or cassette)
Chalo   100 GW
Post by Chalo » Jun 05 2021 10:55am
You'll waste time and tools modifying the standard remover, even if you succeed. It's not worth it. Buy the right remover; it's easy to find anymore.
