unclejemima
Ok, so it’s not a ebike technically, but it appears to have an ebike style rear motor.
The motor is stamped 1200w-48v
I’m trying to understand the machine as it seems straight forward, but I’ve got some questions I don’t understand.
First question is the voltage. The motor is stamped 48v 1200w. The machine has 4x12v lead acid batteries. The included charger mentions a 58.7v output. This seems higher than I expected, or is this correct?
The actual voltage of the full charged batteries are supposed to be around 50.4 volts because they are lead acid. (12.6v per battery). The machines doesn’t get anywhere near the performance specs it’s supposed to. They claim 12km/h in 1st, 24km/h in 2nd and 36km/h in 3rd. I’m lucky to get 16km/h in 3rd with a fresh charged set of batteries.
Could I swap in a lithium battery for more performance, like 52v-60v or is that a bad idea? If my lithium battery has a bms I’d imagine it should be ok.
Here’s a link to the machine in question.
http://unclewiener.com/product/new-1200w-electric-go-cart-utv-buggy-hlw7182/
Thanks all for your time
