dogman said:
Cool Idea! I have one bike with old street slicks inside the tires as a liner. Cutting off the bead wire, the slicks really increased the thickness of the tire so thorns have to be longer to reach the tube. Heavy though. I wonder about other types of plastic liners, like your idea. 1 inch polyethylene pipe maybe?
Or use the ones Slime makes--they're dang near puncture proof; I did once manage to send a roofing nail thru one, but the many others did not make it thru the liner (truck in front of me spilled them out the bed/gate gap over most of the road, not possible to avoid them all).
http://www.slime.com/product/211/Slime-Tube-Protectors.html
That was on an early version of the DayGlo Avenger upright bike with 26" wheels.
When I emailed them to let them know they are not totally puncture proof, they not only replaced *both* liners, but also sent two tubes (with pre-slimed thorn-resistant ones), no charge at all. They do stand behind their products.
I rode that bike for over a year, probably closer to a year and a half, before I finished the CrazyBike2 and rode DayGloAvenger much less, and in all that time I did not have to fix a single flat, even when riding on the unpaved canal paths and in our never-ending road construction zones (which had taken out who knows how many tubes before I got those liners).
I'm actually using the *old* liners in my 24" tires on CrazyBike2 (with the new ones still in the DayGlo Avenger), and they've already stopped a couple of serious nails from ruining my day. None so far since switching from the knobbys to the slicks, but there will be, I'm sure.
That said, I might make up a front wheel to swap out for the one I have on there now, using an identical tire and similar tube, with these bottle-plastic liners. Only change I'll make is to melt the ends together for the strips, if I have to to make them long enough. When I cut them, I'll cut them off a 3-liter bottle in a spring-shape, to maximize the length of the strip I get out of each one.
