Hi,
If I was going to choose a new/cheapish bike to convert to an bike, what would be the basic requirements? (I mainly want upgrade from my existing old mountain bike (steel frame) as it doesn't have disc brake mount points on it and I'd like to go to disc brakes). For example / specifically:
thanks
Some additional notes/requirements:
- Aluminium Frame - Is this OK? I asked our local bike shop and they told me this would be stronger than the old steel frames (but strong/good in comparison with the lighter technology frames). Are there actually different grades of aluminium by the way
- Shock Absorbers - Are these OK for an ebike? or is there a reason to avoid these? (mine will be front hub motor and battery [10AH LiFePO4 on rear rack)
- Anything else? (I can't think of anything, just the frame would be the main thing I would have thought - it shouldn't matter the type/quality of gears etc)
thanks
- will be just a commuting ebike, so on-road, about 2 x 20km a day
- front hub motor is an eZee from ebikes.ca (they've said I probably don't need a torque arm for this one)
- battery on back is a 36V, LiFePO4 10AH, so about 3.5kg I think (7.7 pounds)
