Speedict Ebike - Anybody seen/tried this?
rosich   100 mW
Re: Speedict Ebike - Anybody seen/tried this?
Post by rosich » Feb 20 2015 12:24am
Speedict has launched new product, which is BMS ? able to live view 13 multi-chemistry battery cells + balance, support both iOS and Android now ...
mfj197   10 W
Post by mfj197 » Feb 20 2015 2:12am
rosich wrote:Speedict has launched new product, which is BMS ? able to live view 13 multi-chemistry battery cells + balance, support both iOS and Android now ...
Good find! Speedict do some good products and this could be another one of them.
Racer_X   1 kW
Post by Racer_X » Feb 21 2015 6:32am
The key word here is 10s or 13s. Shame because for me 12s or 18s LiPo balance, support would be much more attractive.
http://speedict.com/
Cannondale F8 MTB, 9c 9x7, Regen,ThreeSpeed Cruise. with torque plates. 12s3p or 18s2p depending on mood.Maxxis Holy Roller in the summer and Schwalbe Ice Spiker in winter.
Backup bike Schwinn Heavy Duti Beach Cruiser, 9c 9x7 front Regen,ThreeSpeed Cruise. with clamping dropouts, Maxxis Holy Roller in the summer and Schwalbe Ice Spiker in winter.
megacycle   100 kW
Post by megacycle » Feb 21 2015 8:11am
Can 2x BMS be seriesed, for 20S?
Gokart A123 80V
300A Kelly Controller
PM72301 motor
15S lipo
mongoose frame
mini monster controller
500W funboy
Speedict Mecury
speedict   10 kW
Post by speedict » Feb 28 2015 8:33pm
megacycle wrote:Can 2x BMS be seriesed, for 20S?
it is not with stacking feature, when connect 20s with 2 x neptunes, you only able to live view 10s group at a time.
Speedict Technology - Drive . The . Future http://www.speedict.com | http://www.facebook.com/speedict.technology
speedict   10 kW
Post by speedict » Feb 28 2015 8:34pm
while our website is being updated, herewith the NEPTUNE connection diagram ...
NEPTUNE Diagram.png (56.26 KiB) Viewed 1347 times
megacycle   100 kW
Post by megacycle » Mar 01 2015 4:20am
That would be okay for me if the 2 neptunes screens can be viewed alternately.
What is the maximum through current?
and the maximum cell balancing current?
are the cell voltages programmable, eg like 3.60V instead of 3.65V for Lifepo4 ?
Gokart A123 80V
PM72301 motor
15S lipo
mongoose frame
500W funboy
Speedict Mecury
d8veh   100 GW
Post by d8veh » Mar 02 2015 5:23am
I'm going to give one a try. It's really good timing because I've just ordered a load of cells to build my next battery, which will be 13S. I'll give a full report when I get it.
Who's going to be first to get one up and running?
mfj197   10 W
Post by mfj197 » Mar 02 2015 6:59am
d8veh wrote:I'm going to give one a try. It's really good timing because I've just ordered a load of cells to build my next battery, which will be 13S. I'll give a full report when I get it.
Despite my post over on Pedelecs I might well give it a go, but I don't know if you can order the Neptune Guard board yet. The price on the website is just for the Neptune cell monitor / balancer, the Neptune Guard will be roughly €49. I see from this thread that the Neptune Guard board includes a Coulomb counter and soft switch, both of which would be useful.
D8veh, you've used a lot of their things. The Neptune website states the connector to the balance wires is via a PH 2.0 connector, i.e. 2mm pitch. Is this usual for them? It would be a little annoying as I've just put on an 11-way JST-XH (2.5mm pitch) plug onto my pack for balance charging!
Michael
d8veh   100 GW
Post by d8veh » Mar 02 2015 9:05am
I'm building my battery from scratch, so I can use the correct connector. The old standard was 2.5mm pitch for the pins, but I'm seeing more and more 2mm ones on OEM batteries now. I've had to change over a few, which is a bit tedious. I just cut the wires, solder and heatshrink them.
speedict   10 kW
Post by speedict » Mar 04 2015 5:58am
mfj197 wrote: Despite my post over on Pedelecs I might well give it a go, but I don't know if you can order the Neptune Guard board yet. The price on the website is just for the Neptune cell monitor / balancer, the Neptune Guard will be roughly €49. I see from this thread that the Neptune Guard board includes a Coulomb counter and soft switch, both of which would be useful.
Michael
don't worry we can provide 2.5mm to 2.0 mm converter board for free !
megacycle   100 kW
Post by megacycle » Mar 04 2015 2:50pm
Any chance of answering these questions-
Is there an operating manual?
Gokart A123 80V
PM72301 motor
15S lipo
mongoose frame
500W funboy
Speedict Mecury
DaDo.Bzz   100 W
Post by DaDo.Bzz » Mar 31 2015 3:12am
Hello Speedict
I would like to buy your new product. Have few questions
1. When you starting to ship?
2. I dont see energy consumption per km also no estimated range. How come? I think this is the most usefull info for mist users. Will you plan to implement also these function? (Is it possible to attach speed sensor to Neptune, to have it accurate also when phone and gps is off. You can implement also autocalibration.) Would be nice to have chart like in Lexus of kilometer consumption per last 10 km.
3. I dont see Neptun Guard on your page. Or am I blind? ;))
Cheers
LMX 81, 16S6P 60A
Dengfu E10, M600, 840Wh, 48V
CTM Scroll, BBSHD, 700Wh, 52V
Slovakia, Bratislava
cycborg   1 kW
Post by cycborg » May 06 2015 11:34am
I've been using my Mercury for a few weeks now. My usage is pretty limited, just datalogging of volts, amps, and GPS. I'll probably get around to wiring up speed and temperature sensors but I don't anticipate using any throttle limiting, PAS, etc. And I keep my phone in my bag, so I'm not looking at real-time data. A handlebar mount is something else I might get around to, but the logging is my primary need for this device.
For the first couple weeks I was frustrated because I couldn't get consistent logging - about half of my data was lost in some way, and for the GPS data it was an even higher percentage. I think this was mainly due to two things - buffered data not being written when disconnecting power, and memory filling up. I've been successful in getting complete data if I consistently observe the following guidelines:
(1) Download data or force a new data record before disconnecting power
(2) Disconnect power when not riding or charging
(3) Erase data records after every few hours of use
At this point there's only one aspect of datalogging that I'm not happy about, namely timestamping. The first column in the log file is just a set of incrementing integers, which appears to be seconds elapsed. There are time stamp on the data records screen in the app, but they're not always accurate. For example, I have two consecutive records from last week, the first of which is stamped 8:19:02 and is 38m31s long, and the next record is stamped 8:20:40, which is obviously inconsistent.
I'm guessing how this works is that there's no real-time clock on the Speedict and the time stamps come from the clock on the Android device. So maybe the key to this is to always force a new record via the app, rather than relying on records started when power is connected?
Does anyone have a consistent way to do get reliable timestamps, or at least understand how this works better than I do?
rolf_w   100 W
Post by rolf_w » May 08 2015 12:21pm
It shouldn't be too difficult to combine the data arriving from 2 Neptune's on the same smart phone display !? I'd love to see such a feature (just software changes required, I guess)
rosich   100 mW
Post by rosich » May 08 2015 10:12pm
megacycle wrote:Any chance of answering these questions-
I don't think danny has time to answer here, as per their information they are going to launch 5 products in coming month.
have few emails from danny my understanding of NEPTUNE is based on IC's internal balance circuit therefore the resistive balance current is limited to ~3mA to 5mA, which is small ? i think ...
danny explained to me even the balance current is tiny but i can leave the balance work overnight or even longer time !
no current pass through it, imagine it is CELL LOG, up to this moment i don't have Neptune Guard information
~3mA to 5mA
yes
rosich   100 mW
Post by rosich » May 08 2015 11:02pm
DaDo.Bzz wrote:Hello Speedict
Cheers
i think next month because they also have product (code name JUPITER ? or NEPTUNE 2) similar to NEPTUNE and you can compare 2 models.
you should wait for them to release more information on NEPTUNE 2 or JUPITER ? it has built-in speed, current, temperature sensor, on-off switch and larger resistive balance current ~60mA, unlike current speedict product, new NEPTUNE 2 use HALL type current sensing, that's mean you don't need to calibrate, also the resistance of current sensor is 1m Ohm.
the new NEPTUNE 2 built-in discharge and charge circuit (mosfet and gate driver) / control for BMS replacement, you can imagine with speed sensor built-in, it can provide speed kill feature although it is not regulate throttle signal but in case you need road limit like PANIC feature on Mercury / Venus its just turn off the discharge mosfet as under-voltage protection.
with on-off switch, it can prevent inrush / spike when connect to speed controller, according to danny information it can support max current of 40A or even higher because it keep monitor on discharge mosfet temperature to prevent over-temperature meltdown, based on the data sheet the mosfet they use is limited to 100A ...
they don't have solid plan on NEPTUNE Guard, so wait and see the total price on NEPTUNE + GUARD vs NEPTUNE 2
knutselmaaster   1 kW
Post by knutselmaaster » May 09 2015 4:06pm
Hello Danny.
I have just finished reading this whole thread.
Also I've been very busy trying out my Mercury since about a week.
I have a lot of problems with the Android app crashing.
I have a Sony Xperia Z2 and I tried the official 5.01 and 5.02 android versions.
The most annoying problem is that when I try to change the dashboard settings, like min and max battery gauge, the app crashes and all settings that I changed since the last start of the app are lost.
When I set battery lvl alarm it starts screaming without any reason and it won't stop.
And often, it just crashes without any significant reason...
Also, when I change the settings of the pas mode I currently use, reading and writing settings sometimes take ages or don't happen at all. Only rebooting the Speedict (power off/on) seems to make it work again.
I got enormous spikes in the amp reading.
I have 36v and about 10a on a geared (non regen) motor.
My max amp is often over 5000A
5000A!
And I have similar spikes in regen.
Is there an update coming for the app?
Are the false readings because of a faulty Speedict ?
Thank you
megacycle   100 kW
Post by megacycle » May 10 2015 12:25am
rosich wrote: >>>> and the maximum cell balancing current?
~3mA to 5mA
yes
Thanks for the info.
It sounds likes it's not suitable for my kW fast charging requirements, where balancing currents could be much higher.
Gokart A123 80V
PM72301 motor
15S lipo
mongoose frame
500W funboy
Speedict Mecury
rosich   100 mW
Post by rosich » May 11 2015 12:59am
~3mA to 5mA
yes
as per danny's information, to compare Speedict NEPTUNE's balance feature, you should to check with your BMS make sure it is "TRUE" balance feature ?
my understanding is although NEPTUNE's balance current (passive resistive balance) is small but it can make sure cells can be balanced compared to market so called Battery Management System without MCU it just discharge cell voltage when cell reached it pre-determined voltage e.g. 4.2v without compare the rest cell in the pack, e.g. 10s pack, when #1 reached 4.2+ v it will immediate shorted with #2 with resistor so that it can discharge its cell voltage while charger is still on CC stage to prevent over-charge, unless charging current is > cell discharge current it will not send disconnect charger circuit ....
see below one of the popular BMS solution (90% of chinese bms) use this solution to prevent cell over-charge.
knutselmaaster   1 kW
Post by knutselmaaster » May 15 2015 2:57pm
I wouldn't let a Speedict product manage my battery charge.
The readings are often totally off, imagine it doesn't cut off at full/empty....
Look what it reads from a 36v system with a 14A controllercontroller and no regen (geared hub):
cycborg   1 kW
Post by cycborg » May 15 2015 3:21pm
knutselmaaster wrote:I wouldn't let a Speedict product manage my battery charge.
I often get a half-dozen or so spurious high or low readings in a 30 minute trip. This results in meaningless max and min values but it doesn't affect average values and integrated values (Ah and Wh) since the're such a small proportion of the total. When I look at the plots of V and I vs time, it all looks right except for these rare spikes.
This could be a big problem for a BMS, though, as a single spurious measurement could cause it to shut down a system that's actually functioning properly.
d8veh   100 GW
Post by d8veh » May 16 2015 3:56am
That's the same for any BMS. The logic isn't based on instantaneous values.
knutselmaaster   1 kW
Post by knutselmaaster » May 23 2015 4:11am
The support is as good as the product....
I removed the Speedict from the bike, and used it on another.
Other motor, other controller, different sensors and a different mode (was on pas mode, now on road legal 2)
I have the same troubles:
-Speedict stops controlling (no accelerator output) every now and then
-When I try to change the Speedict settings, it bugs and the connection stalls, and all settings are lost. (have fun setting min and max throttle in the middle of the street, lifting the bike)
-Data are useless (6000w on 36v system etc)
-The Android app is totally unstable (tried 3 different phones, 6 android versions)
-There is no support
And the price has just been raised by 20%!
I am so deceived about this product.
I wanted to integrate it in the bikes I sell but that just is not possible.
Besides the bugs and problems, the settings are so difficult to understand and unexplained that even an experienced technician like me has to use trial and error to get it to react as I want, it will be impossible to give proper customer support as there are no clear instructions that I could give them.
It is a shame as the product has a lot of potential.
Arduino here I come....
IHatePedalling   1 mW
Post by IHatePedalling » May 25 2015 9:59am
Well Knutsemaaster, I totally agree with your conclusion. Speedict mercury is utter crap. I have only experienced a lot of trouble at the end of the day. The product looked promising especially for the high powerbikes in Europe because of the roadlegal2 function. But as I have concluded before: it is a hopeless product.
MAY THIS BE A WARNING FOR PEOPLE WHO CAN'T WAIT TO BUY THE LATEST SPEEDICT PRODUCTS.
