Speedict Ebike - Anybody seen/tried this?
knoxie   10 MW
Re: Speedict Ebike - Anybody seen/tried this?
Post by knoxie » Jun 19 2011 9:33am
I like the idea of this but dont want to bolt my expensive HTC mobile phone to my handle bars though? would have to find out what the cheapest phone is that you can run the software on and use that instead? seems an expensive way to check your battery status when all you really need is a simple volt meter on the bars like this.
http://endless-sphere.com/forums/viewto ... 14&t=29049
Sure I use a watt meter too but dont want to run the power cables to the handle bars, the extra logging ability of this is nice but how often are you going to use that feature? its a nice idea but when you factor in the phone and the dongle its a pretty expensive one, also my battery would be flat on my HTC with the screen on for a couple of hours so I would need a DC-DC converter too! starting to get complicated expensive and bulky :?
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
speedict   10 kW
Post by speedict » Jun 19 2011 10:54am
knoxie wrote:I like the idea of this but dont want to bolt my expensive HTC mobile phone to my handle bars though? would have to find out what the cheapest phone is that you can run the software on and use that instead? seems an expensive way to check your battery status when all you really need is a simple volt meter on the bars like this.
i see, some users use this kind of phone for simple features : cost eur 20-30 now ...
java phone.jpg (97.33 KiB) Viewed 3400 times
Speedict Technology - Drive . The . Future http://www.speedict.com | http://www.facebook.com/speedict.technology
jonathanm   10 kW
Post by jonathanm » Jun 19 2011 11:13am
Thanks Danny, that works and I can play with it - it works fine on my cheapo Samsung Intercept as well. I think this is going on the shopping list!
Knoxie, this is more like a CA than a simple battery level indicator. I don't think I would have it on my bars all the time, but I wouldn't want a CA on all the time either. I agree your LED meter is just what the doctor ordered for everyday use., though yours is a little big for my taste....looks great though, love the graphics!
speedict   10 kW
Post by speedict » Jun 19 2011 11:27am
jonathanm wrote:Thanks Danny, that works and I can play with it - it works fine on my cheapo Samsung Intercept as well. I think this is going on the shopping list!
hi jonathanm,
do one more test, get one java phone and try transfer file make sure your samsung intercept's bluetooth support file transfer because we use similar method to transfer data, of course i am pretty sure samsung's bluetooth is ok but i was told htc one model's rom has problem and waiting for patch to fix it.
knoxie   10 MW
Post by knoxie » Jun 19 2011 12:24pm
My little box is only 65mm by 35mm ? which is a heck of a lot smaller than a mobile phone :mrgreen: I also run a watts up meter as well its just that I dont want the watts up and the cables having to run up to the bars, this is a slick device and will no doubt have its followers but you really only ever need to see your volts? other data is pretty much irrelevant as the battery volts tells you pretty much all you need to know, the other data is nice but not essential :)
speedict   10 kW
Post by speedict » Jun 19 2011 12:42pm
you can do little more with a buzzer for low voltage alert by using dirt cheap $1 8 bit mcu even better than wattup watt meter, anyway good work !
gerrydesign   100 mW
Post by gerrydesign » Jun 20 2011 9:22pm
i'm new to ebike scene and just finish my conversion. I thinking of getting CA and I found this. Can you set a speed limiter through this app?
forever noob
Specialized Rockhopper
Xlyte HS3640
12 x 4110 MOSFET Extreme Modder Sensorless Controller LYEN Edition with custom 36-50 and 55-80 volt setting
http://www.gerrydesign.com
speedict   10 kW
Post by speedict » Jun 20 2011 9:32pm
gerrydesign wrote:i'm new to ebike scene and just finish my conversion. I thinking of getting CA and I found this. Can you set a speed limiter through this app?
we have designed external board or module for ebike device, call governor module provide speed and current limit, low voltage cutoff etc., but would like to delay a little bit because we would like to launch our speed controller first.
Kingfish   10 GW
Post by Kingfish » Jun 22 2011 4:48pm
Greetings Danny
I just received my Speedict device. :)
Upon cursory inspection I would like to offer a suggestion for the next version:
  • The wire gauge going into and out of the unit is 14-AWG. My battery bus is 8-AWG mainly because I have three packs spread across my bike and trailer. The stock gauge coming out of common controllers is 12-AWG, however I am upgrading this to 10-AWG from the PCB to the bus for performance. In addition, the stock gauge of the phase wiring coming out of my hub is 14-AWG, and that too is being upgraded to 12-AWG likewise. It seems to me that 14-AWG is not sufficient for 80V 100A continuous operation (not that I am using that much power, however it is the max specification). Granted my bus is larger than my need, and yet I want the least resistance possible from battery to controller.
    For independent comparison, I have a Castle 50V 110A ESC; the wire gauge into and out of the unit is 10-AWG which is reasonable and expected.
    Therefore I would ask that you make this adjustment in the next revision. :)
Thank you, KF
* My 2WD Garden Wall
* Kinaye MotorSports
* Epics: Going to California: 2011 8)
speedict   10 kW
Post by speedict » Jun 22 2011 11:53pm
Kingfish wrote:Greetings Danny
Thank you, KF
The answer is yes and no, the point is we have shunt resistor (for measuring current data) value 0.00025 ohms, when high current pass through most of the heats is generated there, therefore when handling high current we suggest to have good ventilation to avoid heat damage the PCB. For castle 50V 110A esc, yes because it is not ICE series, it has no shunt inside, therefore heat is generated on wire, use 10-AWG wire definitely can help !
kingfish, thanks for your comments, yes we are keep collecting market feedback, when high current demand is increased, next version we will use external shunt resistor approach !
speedict   10 kW
Post by speedict » Jun 23 2011 10:25am
Kingfish
see this log, the system climb up from 3A to 71A in just 1 second !
http://chart.speedict.com/?weblogid=40411w11FV151115
log netherlands 72A.jpg (222.4 KiB) Viewed 1098 times
Kingfish   10 GW
Post by Kingfish » Jun 23 2011 11:47pm
Hello Danny
That is an impressive application! Really very cool. 8)
With regards to the 14-AWG wires, I shall remain optimistic unless proven otherwise; it is the best that we can hope for.
Thank you for your kind support :)
Best, KF
Bazaki   10 kW
Post by Bazaki » Jun 24 2011 2:25am
100v 100a no problems with 14awg over that short distance of wire for a few seconds, the speedict survived it all 8)
Green Machine   100 kW
Post by Green Machine » Jun 24 2011 3:23am
Thanks for the Temp Sensors danny...just got them...speedy shipping!
This is really awesome company.
Hong Kong direct to the consumers.
Bazaki   10 kW
Post by Bazaki » Jun 24 2011 7:33am
Everything works great with Speedict and Danny :D
All we need is the Governerboard so we can limit our ebike with our phone, while stopped over by the Police after speeding, we adjust the speedict to 25km/h and max 250 watt ( europe )
I will build the speedict INSIDE my 18 fet controller and no cop will discover it, unless he will find this topic :P
speedict   10 kW
Post by speedict » Jun 25 2011 12:21am
Bazaki wrote:Everything works great with Speedict and Danny :D
let see if we can squeeze little bit time to complete the governor coding before speed controller project :)
yes this is very good idea !
jonathanm   10 kW
Post by jonathanm » Jun 25 2011 1:24am
speedict wrote:let see if we can squeeze little bit time to complete the governor coding before speed controller project :)
Cool, I was hoping you would do that :D
Can you tell us a little bit more about these two projects?
speedict   10 kW
Post by speedict » Jun 25 2011 1:40am
Governor board is the external module for Speedict eBike, featuring :
1. speed regulate - e.g. you set 25km as max speed, so when you apply full throttle we control your max speed to 25km, when apply half throttle speed will be ~ 12km
2. current regulate / current throttle - e.g. you set max current output to 30A, so when you apply full throttle we delivery only 30A max, when apply half throttle, current delivery only 15A so on ...
3. low voltage cut off
4. cruise control
all these setting can be done via android, so you can set up different profile for different conditions :)
by the way, we estimate the price for existing ebike users around eur 10 ... is it ok ?
jonathanm   10 kW
Post by jonathanm » Jun 25 2011 2:12am
speedict wrote: ... is it ok ?
hmmm for 10 euro? can you make it pedal for me as well please :D
sounds fantastic, actually....when do you think it will be available?
And please tell us about the controller too....
speedict   10 kW
Post by speedict » Jun 25 2011 2:20am
oh yes it is PAS as well ... when ? we did 95% but we are very busy on speed controller project in higher priority therefore we put it aside ... let me discuss with our team member next week to see if we can launch it first :)
adrian_sm   10 MW
Post by adrian_sm » Jun 25 2011 4:49pm
What are the specifications for the controller you are developing?
Is it just a rerelease of your 50amp model? Or something different?
- Adrian
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive
Build #??? ~21kg ~1500w Adrian's Bafang BPM Hardtail MTB Bafang BPM code12, 15s LiPo, ~40kph, ~30kms
speedict   10 kW
Post by speedict » Jun 25 2011 11:04pm
adrian_sm wrote:What are the specifications for the controller you are developing?
- Adrian
featuring bluetooth, governor, dynamic regenerative and pas ... will release more information here later ...
Hyena   100 GW
Post by Hyena » Jun 28 2011 1:30am
Once you have this add on govenor board it'll really make the speedict stand out Danny :)
It'd be great if you could make a "performance" model that can 100v, surely it wouldn't require too many changes to the existing board for future models ?
Brilliant as it is to be able to control everything from your phone it'd also be good if you could have a hard wired button that you could program to change current modes or limit speed etc.
Another cool feature would be to a tick box type option in the software that automatically engages the limited current mode when the temperature exceeds a defined maximum. A higher range temperature sensor (or re-calibration allowing such) would be great too. Many of us running hotted up hub motors routinely run internal temperatures of 100 degrees C so it'd be nice to have an upper limit of say 120-150 degrees for those who want to push their luck.
Any more news on cheap little stand alone screens to use ?
If you really want to rock our world, add in a chip for monitoring and displaying individual cell voltages. Offer this functionality and I'll happily cruise around with a 7" android tablet as a dashboard on my handlebars :lol:
www.HyenaElectricBikes.com
speedict   10 kW
Post by speedict » Jun 28 2011 2:00am
Hyena wrote:Brilliant as it is to be able to control everything from your phone it'd also be good if you could have a hard wired button that you could program to change current modes or limit speed etc.
don't want cop can trace the wire to the system, everything go wireless right ? :)
Hyena wrote:Another cool feature would be to a tick box type option in the software that automatically engages the limited current mode when the temperature exceeds a defined maximum. A higher range temperature sensor (or re-calibration allowing such) would be great too. Many of us running hotted up hub motors routinely run internal temperatures of 100 degrees C so it'd be nice to have an upper limit of say 120-150 degrees for those who want to push their luck.
yes sire, everything can be done by software !
Hyena wrote:Any more news on cheap little stand alone screens to use ?
we have sourced 4" china cheap android PMP, and we are working on to activate its bluetooth, the cost around eur25 !
Hyena wrote:If you really want to rock our world, add in a chip for monitoring and displaying individual cell voltages. Offer this
we have plan to do BSM and monitor every single cell !
Webbo   10 mW
Post by Webbo » Jun 30 2011 12:27pm
Deff needs to measure at least 100v. But very nice
