Jerome Daoust
We know the Bomber is heavy: 116 lb (53 kg) for a 2011 model, and somewhere around 94 lb (43 kg) without its battery.
If you want to transport it to your favorite riding location, no worries if you have a van or a pick-up truck. But if your only option if to find a bike (or motorcycle) rack to fit a 2" hitch receiver, what would you do?
I have a Thule 916 XTR T2 which can be extended to carry 4 bike of 60 lb (27 kg) each so the overall weight capacity is sufficient, but I worry about it limit of 60 lb (27 kg) per bike location. Maybe a bomber could distort/break its plastic wheel receivers, as that could be the weak point (instead of the metal bars)?
I have a roof rack, from which I could attach straps to the bike rack to help pick up some of the bounce loads and/or prevent twisting (when you hit a bump on one side) but like I said above this rack is already designed to for a total of 240 lb (109 kg) of bikes, so the main backbone strength is OK. Limiting factors that possibly remain:
Another thing to consider: Dropping/damaging your expensive bike(s) on the road is one concern. But sending a bike sliding onto a freeway can result in other people's accidents and injuries. A person injured due to your inadequate transport method could have a valid legal claim.
Let me know how you do it. Thanks,
Jerome
Same topics:
Google groups: Stealth Electric Bikes: Stealth Bomber: What is a good hitch-mounted rack for it?
Google groups: Stealth Electric Bikes: how do you transport your bomber Options
- Transverse bar to backbone clamps.
- Transverse bar itself.
- Plastic wheel well.
- Base of the clamping arm lever, which could receive excessive bending loads from a heavier bike jolted front/back during acceleration/braking.
Jerome
Same topics:
