Reports from Eurobike 2011
full-throttle   10 MW
Re: Reports from Eurobike 2011
Post by full-throttle » Sep 03 2011 5:43pm
panurge wrote:Expected Specs for the future pinion motorGB
Thanks for that!
800W, 8 gears, 4.6kg is actually very good. Wonder if the crank arms are included in the weight.
panurge   10 kW
Post by panurge » Sep 04 2011 11:38am
Thanks for that!
Not, Crank arms are not included and they are 364g, the shifter is 115g, only the 24t/30t sprocket is included in the 2700/4600grams. (normal/motorised) :)
Jules
JulesL.
Forsan et haec olim meminisse iuvabit
Onion MP6 - recumpence drives - CAV3 - CC HV160ESC - Astro 32204t
Miles   100 GW
Post by Miles » Sep 08 2011 12:59am
Extracts from "Show daily" reports:
http://www.electricbikemag.net/showStor ... torynum=91
gogo   10 MW
Post by gogo » Sep 08 2011 5:08am
Miles wrote:Extracts from "Show daily" reports:
I'm starting to catch on to bike terminology. Cargo = bikes for fat arses.
"A conclusion is the place where you got tired of thinking." -Steven Wright
Lock   10 GW
Post by Lock » Sep 10 2011 5:45am
Quite strange...
panurge wrote:Last tranche.....
These folks:
http://hettlagedrive.de/
http://www.youtube.com/watch?v=eWXxiXvfBjg
If you like this message feel free to donate BeerCoins (BTC) to:
1LxAXWmbjY6SeMf8r9HHhSKt6pWyPvWg6L
Toronto Electric Riders Association:
http://www.ebikeriders.com/
Canada, eh?
JennyB   1 kW
Post by JennyB » Sep 10 2011 6:35am
Lock wrote:Quite strange...
Hagen infinitely variable chain wheel.
A transmission for bicycles and the like which includes a plurality of radially displaceable sprocket members with means for controlling the radial position of these sprockets members which positioning means includes a pair of plate members having reversed, identically curved paths thereon with the sprocket members mounted at the junction of the paths with means for controlling the relative speed between the two plates whereby the paths will be shifted with respect to one another and their junction point will increase or decrease radially thus moving the sprocket radially inwardly or outwardly.
Discussed in Bicycling Science Whitt & Wilson 1974 page 147.
No doubt Miles can find a 19th Century example! :)
Miles   100 GW
Post by Miles » Sep 10 2011 7:15am
JennyB wrote:No doubt Miles can find a 19th Century example! :)
There was the "Protean" expanding chainwheel of 1894.
Or the "Paradox" by WD Wansbrough, which appeared in 1901. This could be expanded or contracted in one tooth segments, from 20t to 26t (1" chain...).
Wansbrough patent:
Wansbrough GB190117153A.pdf
(657.7 KiB) Downloaded 40 times
Miles   100 GW
Post by Miles » Sep 11 2011 7:01am
Samd   1.21 GW
1.21 GW
Post by Samd » Sep 11 2011 8:52pm
Looks like lots of knockoffs of the Bosch knockoff of the Aprilia Enjoy there. :P
http://ballaratebikes.com/
Miles   100 GW
Post by Miles » Sep 11 2011 9:16pm
Why "knockoff"?
sk8norcal   100 MW
Post by sk8norcal » Sep 11 2011 11:12pm
interesting article...
"speed pedelecs" for 500w and above...
A discussion on 'fast pedelecs', a category of e-bike not yet permitted in the UK:
sk8norcal   100 MW
Post by sk8norcal » Sep 12 2011 2:41am
gogo   10 MW
Post by gogo » Sep 12 2011 4:33am
^I wonder if the throttles are available separately. Wow, a Rolhoff hub. $$$$
adrian_sm   10 MW
Post by adrian_sm » Sep 12 2011 4:48am
Don't know about the throttle but the LCD display can be found here:
http://www.aliexpress.com/product-gs/38 ... alers.html
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive
Build #??? ~21kg ~1500w Adrian's Bafang BPM Hardtail MTB Bafang BPM code12, 15s LiPo, ~40kph, ~30kms
Samd   1.21 GW
1.21 GW
Post by Samd » Sep 14 2011 1:25am
Knockoff = copy.
Miles   100 GW
Post by Miles » Sep 14 2011 1:36am
Samd wrote:Knockoff = copy.
Errrrrr... Thanks. :roll: :)
I don't see any evidence of copying, even.
Do you think Aprilia were the first to drive the bottom bracket?
Samd   1.21 GW
1.21 GW
Post by Samd » Sep 14 2011 4:37am
Why do I get the feeling you are about to tell me what you think?
Miles   100 GW
Post by Miles » Sep 14 2011 5:21am
Well, I'm not sure it matters very much but, TGA in the UK were making bikes and trikes with a BB drive before Aprilia. I should imagine there are other examples, it's a pretty obvious direction.
I would have thought that it was better to reserve the word "knockoff" for more specific cases, where there is genuine plagiarism? The Bosch and Aprilia examples have little in common, beyond the base concept.
Hillhater   100 GW
Post by Hillhater » Sep 14 2011 5:59am
I am sure there were others too , but Aprilia were one of the first to design and manufacture a dedicated custom Integrated powered B Bracket drive. to say nothing of a custom bike frame and control system package ( Pedelec, torque sensing, speed sensing, pre set power levels etc)
Few other Ebikes of that period were purpose designed, most were "adapted" conventional bikes ( like the Electrobike which used a "Cyclone" type add on drive)
Considering the Aprilia design was conceived in the mid '90's ( best part of 20 yrs ago !), it was extremely advanced for the time, its major limitations even today being only its Brushed motor system and the Nmh battery technology.
I suspect the bike was a commercial failure for Aprilia ( sales were not huge) but it was a very good design.
Are you aware of any other "integrated" powered BBracket bikes available pre 2000?.. Miles ?
Miles   100 GW
Post by Miles » Sep 14 2011 6:14am
Hillhater wrote:Are you aware of any other "integrated" powered BBracket bikes available pre 2000?.. Miles ?
Nothing commercially available comes to mind. I recall several patents, though. Development of the Optibike started in 1998.
Would you say the Bosch was a "knockoff" of the Aprilia? That the Daum et al are "knockoffs" of the Bosch?
[Samd, I realise you were just responding to Lebowski....]
Samd   1.21 GW
1.21 GW
Post by Samd » Sep 14 2011 5:24pm
Yeah, I was. But I was wondering if you could help yourself or not. I got my answer. :P
Silliness aside, I get frustrated when there are so many media reports lately of expensive over engineered bottom bracket drive bikes. I find the pics from Eurobike inspiring in an engineering sense, but not the product positioning within a society that needs to get out of cars.
(I think) The future existed ten years ago. I just bought yet another Aprilia Enjoy on ebay this week. A quick retrofit of controller and LiPos and I have a good looking, quiet, dependable, reasonably fast 1100W bike for well under a grand. And it invites lots of inquiry. It also has a bit of brand heritage in the Aprilia name.
Plenty of money left over for a solar grid and batteries by recycling an Aprilia, compared to the Bosch offerings.
Being a dutchman I guess I see cycling for the denim wearing masses, not for the carbon fibre and lycra clad niches. Not a dig at anyone in particular - just a social comment.
Miles   100 GW
Post by Miles » Sep 14 2011 6:46pm
Samd wrote:Yeah, I was. But I was wondering if you could help yourself or not. I got my answer. :P
:mrgreen:
How much would the Enjoy be if it were available now, I wonder?
The Bosch drive unit seems a pretty mundane bit of engineering with a hefty price premium.
I bet buyers will also be encouraged to take out an extended warranty, service contract etc....
Hillhater   100 GW
Post by Hillhater » Sep 14 2011 8:13pm
Miles wrote::mrgreen:
How much would the Enjoy be if it were available now, I wonder?....
I believe the Aprilia has more "engineering" cost in it than the Optibike !..
... but they were produced on a larger volume basis, so retail cost is tricky to place ?
Actually , you can still sometimes buy new, boxed , Enjoys, from "Alibaba" sources ..?? old stock, "knock off's" ???
http://www.asia.ru/en/ProductInfo/1422840.html
Toorbough ULL-Zeveigh   100 MW
Post by Toorbough ULL-Zeveigh » Sep 14 2011 10:21pm
Miles wrote:The Bosch drive unit seems a pretty mundane bit of engineering with a hefty price premium.
that's the result of the optibike halo effect why i rail on about it.
take something otherwise ordinary, dress it up with rhinestones & glitter then present as if it's the greatest thing since pneumatic tyres.
the cherry on top is an obscene price tag deliberately crafted to tap into the typical consumer's erroneous thought process of "gee, if it costs that much it just gots to be really good."
this hasn't gone unnoticed by the new ebike players who surely must say to themselves "well ours is waay better than that" and price accordingly to this optibike 'benchmark'.
so now we all get to reap the benefit of paying thru the nose.
oh yeah, don't overlook they also knocked-off aprilias pneu-fangled pneumatic tyres. :roll:
aprilia must have forgot to apply for a patent.
here's the one tru religion original patent-holder for bb drive. :mrgreen:
espacenetDocument.pdf
(37.11 KiB) Downloaded 80 times
