Zen_Shenron said:
The Bike is my Currie Ezip Trails as modified in my sig.
I need to build a new wheel for my bike, broke another spoke and I am looking for something a little stronger (I'm a really big guy: like 6'8" 350lbs).
I need to use the same hub, but I am looking for some recommendations for a rim and some spokes.
That's my size. I'm 6'8" and down to 340 lbs. from a high of about 415. I'm a veteran bike mechanic, and I have built plenty of bike wheels that hold up nicely for me. Good strong e-bike wheels are harder, but still feasible. I used to ride an e-bike that weighed over 500 lbs all-up, with 700c wheels.
The Alex DM24 is an excellent rim, especially for the price. With a careful and methodical build, it should be adequate for your use. Velocity's Psycho is stronger because it is heavier-- it's almost exactly the same shape and size as the Alex rim. Velocity's Chukker is a super strong rim, and the only one I know of that's narrow enough for skinny tires like 26x1.25" if you want that option. (For what it's worth, a fatter tire makes your wheel more durable, all else equal.)
If you can find a Sun Mammoth or BFR, try that. It's stronger than the DM24 and not expensive, but it seems to be out of production.
Surly's Large Marge is humongous and ungodly strong, but at 65mm wide, it does not fit in all frames. It's expensive-- over $150 retail. This one appears to be a clone of the Large Marge with a lower price tag:
http://www.choppersus.com/store/product/786/Rim-Only-26-x-2.5-Silver/
I seem to keep breaking them at the elbow. Any thoughts, or suggestions?
Should I use thicker gauge spokes, double butted spokes.
Spoke breakages at the elbow are most often from omitting important steps at the time the wheel is built. A skillful professional wheelbuilder can make a more reliable wheel, given the same components, than a manufacturer can. You can too, if you get yourself a copy of Jobst Brant's
The Bicycle Wheel, read it, and follow the directions closely. A spoke tensiometer helps. In your case, you want up to about 150kg of tension on each spoke.
13-14ga single-butted spokes from Wheelsmith, Sapim, or Phil Wood are a little more resistant to elbow breaks than straight gauge 14ga spokes, but there's more benefit to be had in a careful build than in thicker spokes. As long as you use lots of tension, 13ga straight gauge spokes (those from ebikes.ca for instance) are likely to be reliable, but thicker spokes than that will give you chronic problems with loosening. They don't have enough elasticity to stay tight at tensions bicycle rims can withstand.
That elasticity is the point of double-butted spokes. A 14-15ga spoke, for instance, has the break resistance of a 14ga spoke because that's the thickness of its elbow and thread. But it has the stretch of a 15ga spoke because that's the diameter for most of its length. By the same token, a 13-14ga spoke is as strong as a straight 13ga spoke, but with the elasticity of a 14ga spoke. The more elastic a spoke is, the longer it can continue to support the rim as load is increased.
48 spoke lacing makes a wheel that is more reliable and easier to true up after some beating, but the wheel's strength is mainly in the rim. Don't bother with 48 spokes if you can find a stronger rim in 36 hole (and these days, you probably can). Your rear hub has only 36 holes in it, so that one choice is made for you already.
Best of luck with your project.
Chalo
