mikhogl said:
Ok, sounds like i have to go for the crystalyte ht3525, but its over 7kg. Almost twice the weight of the bmc, the bike is going to be less fun... any other options? Mac? Or should i settle with less power? So hard to deside
A BMC V2-S will meet your design requirements just fine. It can handle 1500w, it will give you the speed at voltage you are asking for, and it is lightweight. It is a good, durable, commuter motor, and the gears are much stronger now. The 1st gen gears sucked but they are long gone, the 2nd/3rd/4th gen gears are great. Get a V2 with the 4th gen gears because they are the strongest, but there are folks here who have run the 2nd/3rd gen gears for a long time without problem.
You did not ask to build an 8000w wheelie-happy hotrod, which as itselectric points out, the BMC is not a good candidate for. However, if you do want to hotrod the motor up a little, you can increase volts not amps to get more watts (W=V*A). Increasing amps increases heat, which the WINDINGS (not the phase wires) cannot handle as well as a DD (direct drive) motor. In addition, increasing volts decreases back-EMF at a given rpms, so you can get more watts into the motor at higher RPM and achieve higher speeds. I always seek to maximize Volts and minimize Amps.
Here is a build with a BMC V2T that moves 300+lb through very hilly territory, @28mph on 60v nominal:
http://www.endless-sphere.com/forums/viewtopic.php?f=6&t=24329&start=15#p413920
-JD
PS - I'm not sure that the 'V4' exists. The V4 I know of was a Direct-Drive motor, and "Betterbike$" is the only place I see listing them.
