RVD
has anyone done a conversion on a folding bike? i did some searches and found a little bit of info but not really as much as i was hoping for.
i'm thinking of taking a dahon speed d7 (http://www.dahon.com/bikes/2011/speed-d7) to use as a base. this uses 20" wheels so i will likely get a 20" ebikekit geared rear hub motor and hook it up to a lyen 9 fet controller and run it on lipo (12s2p (44v) or 10s2p (37v)).
my goals are:
1) keep it somewhat lightweight since this is a folding bike after all. i believe i can just wheel the bike from place to place when i'm not riding but i would like to be able to lift it up short distances if needed (stairs, etc.).
2) decent range while maintaining usable weight. 15 miles would be great. 10 miles would be acceptable.
3) minimize cost since this isn't a primary bike but a secondary bike. i will probably just use a wattmeter instead of a CA, etc.
4) i chose the speed 7 instead of the boardwalk s1 because the boardwalk uses coaster brakes. i don't know much about coaster brakes but i believe the brakes are in the hub so replacing the rear wheel with a hub motor will force me to install V brakes? the speed also seems like a lighter bike.
my goals are:
