New crystalyte motor - G series
ohzee   1 MW
Re: New crystalyte motor - G series
Post by ohzee » Jul 14 2012 10:17am
wow yea that's a great way to start my morning thanks for the laugh and nice mental picture
neptronix   100 GW
Post by neptronix » Jul 14 2012 12:07pm
Ypedal wrote:*wipes coffee spray from monitor....
:mrgreen: my thoughts exactly..
Farfle   1 MW
Post by Farfle » Jul 14 2012 12:33pm
Wait, luke, LFP luke. THE luke. On a 200w skinnybike? I would NOT have called that one.
Test Review Revise Repeat
liveforphysics   100 GW
Post by liveforphysics » Jul 14 2012 2:22pm
justin_le wrote:
liveforphysics wrote:Any chance of throwing the Tongxin/Cute motor into the simulator? I'm riding a light weight road bicycle now that could use a feather weight front hub helper. The lightest quiet hub that can do just 200w of output for 10minutes is what I'm looking for.
Luke, I was presuming that your tongue was firmly in cheek here. But indeed, post a picture here of yourself lycra clad on a skinny tire road bicycle and I will bend over to put anything up on the simulator for you!
-Justin
I don't own any lycra to wear for the picture, but just for you my friend, I will pick some up, squeeze into it, and take the photo for you. :-)
I actually enjoy the bike a lot. It's pretty amazing how well it works. I would say 1/5th the pedal effort of deathbike to cover the same distance unpowered. The only deficiency with the bike is the small gas tank capacity, clogged air filter, and tiny fuel-line diameter of the human engine driving the cranks. lol I figure a 200w hub will double what I'm able to contribute for any moderate amount of time.
It's just a couple orders of magnitude off the power output of my other bicycle. :-) Still fun! :-)
joss76   1 µW
Post by joss76 » Oct 14 2012 3:56pm
just à little question , have you an idea why I don't find the motor on the crystalyte website ? it's will stop ?
amberwolf   100 GW
Post by amberwolf » Oct 14 2012 11:41pm
Have you asked Crystalyte? They'd be the only ones that could tell you, since it's their site. ;)
The Mighty Volt   10 MW
Post by The Mighty Volt » Oct 15 2012 5:46am
€250 before postage. Meh. And their shitty 3 weeks of faffing about too before they send it. :evil:
cwah   10 GW
Post by cwah » Oct 15 2012 7:27am
Just wondering if a small DD motor makes any sense?
I mean, it's as heavy as a BPM. So if you get a BPM or a Mac you'll be more efficient and have much better acceleration.
If you want to go lightweight, you'll want to have a small geared motor such as a cute100 which would almost be half its weight...
The only advantages of this motor would be the silence, regen and maybe durability? But again, if you want a tough one, just get a BPM or a Mac....
So, why do you get this motor?
justin_le   10 MW
Post by justin_le » Oct 15 2012 8:52am
Hey Luke, OK so it's gonna be time for you to own up!
Post us your photo and I'll characterize and dyno test these Tongxin hub motors in various windings and put them up on the simulator to the benefit of aspiring weight weenies everywhere:
Tongxin Box.jpg (51.34 KiB) Viewed 2742 times
Previously competed in the Suntrip race on a back to back tandem solar powered row/cycle trike. 550 watt solar roof, dual Grin All Axle hub motors, dual Phaserunner controllers, 12 LiGo batteries, and a whole wack of gear.
Now back in Vancouver learning to be a dad with my Big Dummy Frame (yes This One, thanks ES!) with GMAC 10T rear hub motor, Phaserunner controller, and 52V 19Ah EM3EV pack
My website: http://www.ebikes.ca
Please contact via email, info@ebikes.ca, rather than PMs, which are disabled
docnjoj   100 GW
Post by docnjoj » Oct 15 2012 12:16pm
Wow! Tongxin roller gears! Are you, Justin, planning on selling any?. I had an old one and it did not last well but maybe these newer ones are more sturdy?
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
justin_le   10 MW
Post by justin_le » Mar 29 2013 11:26pm
Justin LE wrote:Post us your photo and I'll characterize and dyno test these Tongxin hub motors in various windings and put them up on the simulator to the benefit of aspiring weight weenies everywhere:
Right, how did I forget about this. Without finding any suitable Lycra to squeeze into, Luke went one step beyond and sent me this photo! :shock: :
Live for Freedom and Physics
Luke, as he be.jpg (15.01 KiB) Viewed 2084 times
Along with some more revealing frontal shots that I shall spare you. So thanks to his bearing it all for the team, I did the dyno tests of the two "Tongxin" hubs and the Cute 328rpm motors and got all that data on the simulator for everyone's benefit.
For the record, here is the actual test data for the higher RPM moor versus the fit with the simulator:
Tongin 24V 260rpm Dyno Data.gif (36.22 KiB) Viewed 2084 times
docnjoj wrote:Wow! Tongxin roller gears! Are you, Justin, planning on selling any?. I had an old one and it did not last well but maybe these newer ones are more sturdy?
So these motors seemed larger and heavier than I remembered from the last time we ordered from Tongxin, and in fact the name Tongxin didn't even appear in the company interactions, rather it ended up coming from Outrider Technology.
Tongxin Weight.jpg (52.21 KiB) Viewed 2084 times
I took one apart to have a look and sure enough,the internal construction is the same outrunner with a single toothed planetary gear reduction to the casing that we see in most geared hub motors, no friction roller drive to be seem.
Tongxin Open.jpg (39.96 KiB) Viewed 2084 times
However, the quality of the motor, tightness of the airgap etc. all look good, similar in caliber to the Bafang motors.
Tongxin Motor Guts.jpg (59.97 KiB) Viewed 2084 times
docnjoj   100 GW
Post by docnjoj » Mar 30 2013 8:48am
I just spotted this.That is a strange Lycra suit, Luke! Skin colored? Anyhoo, Justin thank you for theTongxin tests. Too bad they got rid of the rollers. If nothing else they had to be quieter than any gears. Is that motor quiet. I mean hub motor quiet? I may be weird but quiet motors are the most important thing to my ears. Thanks for the work.
otherDoc
nieles   10 kW
Post by nieles » Mar 30 2013 9:55am
docnjoj wrote:I just spotted this.That is a strange Lycra suit, Luke! Skin colored? Anyhoo, Justin thank you for theTongxin tests. Too bad they got rid of the rollers. If nothing else they had to be quieter than any gears. Is that motor quiet. I mean hub motor quiet? I may be weird but quiet motors are the most important thing to my ears. Thanks for the work.
otherDoc
looks more like a morphsuit to me :P
http://www.morphsuits.com/
docnjoj   100 GW
Post by docnjoj » Mar 31 2013 12:52pm
The pink one I would guess. :)
otherDoc
The Stig   100 kW
Post by The Stig » Jul 01 2013 4:21pm
So as anyone ACTUALLY tried overvolting these G series motors to the limit? (maybe with some cooling system, like oil cooling)
Anyone know how much power it would take to saturate the stator?
ambroseliao   100 kW
Post by ambroseliao » Jul 21 2013 8:20am
Well, I just bought one on eBay from ebikessf. It's in a 20" rim and with _a bad spoke job...
"Crystalyte G-Series brushless 800Watt rear hub motor in 20" rim.
Top speed 25mph @ 50V in 20" wheel
Voltage range: 24-100Volt
This motor works with sensored and sensorless controllers and accepts 7-9 speed cassettes.
Weight (without wheel): 8lb
The wheel was not built correctly by the factory, we recommend rebuilding the wheel, shortening the spokes and re-dishing."
Did I buy a lemon? The price and it being new pulled me in! Looks like I've got a project motor...
http://www.ebikes.ca/ is the best!
TidalForce M-750X, Tidalforce S-750 with Crystalyte HS3540, 1x TF iO-X Cruiser. E+ 1000W hybrid bike. ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. Bosch Fat Packs, 37V 10Ah LiPO pack. Turnigy Multistar batteries
My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
The Stig   100 kW
Post by The Stig » Jul 21 2013 12:27pm
pics? what kind of power you planning to run in it?
ambroseliao   100 kW
Post by ambroseliao » Jul 22 2013 12:06pm
Ilia has posted some photos of the 2 other G motors he has for sale. One is BIN and the other is open bidding.
http://www.ebay.com/itm/Crystalyte-G-Se ... 35c9dcd24d
2013-07-21 08.50.43.jpg (164.23 KiB) Viewed 1774 times
2013-07-21 08.50.51.jpg (160.84 KiB) Viewed 1774 times
2013-07-21 08.50.55.jpg (177.77 KiB) Viewed 1774 times
ambroseliao   100 kW
Post by ambroseliao » Jul 22 2013 12:22pm
The Stig wrote:what kind of power you planning to run in it?
Not much. Perhaps 350-500W for my wife's bike. The light weight and small size is what's important for her.
The Stig   100 kW
Post by The Stig » Jul 22 2013 1:10pm
I'm surpised the wheel build quality isnt that good. I thought Ilia did good stuff!
ambroseliao   100 kW
Post by ambroseliao » Jul 22 2013 1:16pm
It looks to me that Ilia is basically dumping these motors since they are not very popular in the USA. Hopefully, he's not taking a bath on these.
skeetab5780   10 MW
Post by skeetab5780 » Jul 23 2013 10:05am
I just bought one of those auctions today! it looked too good to be true, I figured it was a scam. price was right.
Lets hope she comes in the mail
ambroseliao   100 kW
Post by ambroseliao » Jul 23 2013 10:27am
It's not a scam. I've emailed Ilia and it's definitely real. It's expected to arrive this Friday.
skeetab5780   10 MW
Post by skeetab5780 » Jul 23 2013 11:21am
Ya I did a user name search here and found this post, also noticed he had 100% feedback rating on Ebay so I wasn't too worried. Good to hear they are real!
