Bafang Bpm, how many RPM?
d8veh   100 GW
Re: Bafang Bpm, how many RPM?
Post by d8veh » Mar 14 2012 5:20am
I built two bikes with the BPM motor in the front wheel. They are OK up to 25amps and 44v (about 1.25kw from the battery), but you must have torque arms to stop the axle breaking the forks. I made my own. torque arms.
Rear wheel installation can also give problems. This motor makes a lot of torque and can be dangerous at low speed with 40 amps. It's OK on a good road surface, but on grass and mud it's difficult to stop it spinning and you can high-side if not careful. At 25 to 30 amps it's better. If you fit a rear motor, you also need good torque arms.
casainho   10 GW
Post by casainho » Mar 14 2012 11:43am
I would like to go with a rear motor however all of them uses a thread for the changes/transmission and the lowest change have 14 teeth while my current have 11 teeth and I get now as maximum about 40km/h pedaling (the same maximum velocity of current Cute-85 motor). With 14 teeth I will get only about 30km/h while the Bafang will go up to the 50km/h... I want to pedal over all velocity of 50km/h... How are you guys doing with rear motors? Not pedaling?
About the controllers, mine for Bafang 48V 500W says over current = 30A, does it means it powers the Bafang at start with 1440W (48V*30A)???
- TSDZ2 OpenSource firmware
Developer of OpenSource knowledge and technology for ebikes: Wireless Ebike boar ANT+ and Bluetooth, Flexible OpenSource firmware for EBikes: TSDZ2 mid drive motor, KT motor controllers and displays: Bafang 850C color, SW102 Bluetooth and KT-LCD3.
If you like my work, please consider making a donation to help my developments: paypal.me/jorgecasa
rojitor   100 kW
Post by rojitor » Mar 14 2012 3:49pm
Yes 1440w your maths are right. I pedal only at low speeds, in the middle of the traffic i pedal all the time and between towns i go fast so i don't pedal at all.
d8veh   100 GW
Post by d8veh » Mar 15 2012 3:43am
I wouldn't take too much notice of that 30A written on the controller. The only way to be sure is with a meter. I had a KU123 that gave 40amps and a 25A controller that only gave 14A.
Your main problem is that the motor gives maximum torque at low speed, which makes it difficult to control. Look at some of the threads about smoothing the throttle.
Haste   100 W
Post by Haste » Mar 15 2012 9:41am
casainho, what kind of battery are you using with the bpm?
1997 Marin Hill Hawk. Bafang BPM 2 10T. KU123 30 amp controller. 12s LiPo.=32mph
casainho   10 GW
Post by casainho » Mar 15 2012 5:43pm
rojitor wrote:Yes 1440w your maths are right. I pedal only at low speeds, in the middle of the traffic i pedal all the time and between towns i go fast so i don't pedal at all.
Thank you for your info. I guess you don't pedal when you go fast because you don't have gear for that velocity, which is something I don't like to do. I want to exercise myself, it's good for my healthy. Because of that, I think I will need to go with front wheel motor since the rear motor only have gears of 14T instead of cassette type which have 11T (as my current setup).
About the 1440W, 30A at 48V, I think that I will buy and use a KU63 controller which powers the motor at 48V*20A = 960W at start.
d8veh wrote:I wouldn't take too much notice of that 30A written on the controller. The only way to be sure is with a meter. I had a KU123 that gave 40amps and a 25A controller that only gave 14A.
Yes, I was thinking in used a resistor divisor (only 2 resistors) to limit the maximum throttle/possible motor power. I came from a 250W motor and I just want a bit more power, maybe more 50 or 100W (mainly for days with wind) and a bit more velocity (~6km/h). 500W seems a lot to me and also I want to travel 68km with a battery(s) charge.
So yes, I think having a "soft start" would help me on safety and avoid strong torque forces on dropouts. Let's see if changing from KU123 to KU63 will also help me on that.
I am reading this and this threads about throttle control (I see a cheap Arduino/AVR board being used for that :-) )
Haste wrote:casainho, what kind of battery are you using with the bpm?
48V 10Ah Li-Ion Alloy Shell EBike Battery Pack.
Front VS Rear motor
I wanted to go and try a rear motor mainly because seems to be more safe to me however I see 2 main problems on using rear motor:
- I loose speed on the gears because of the 14T freewheel (now I have 11T cassette and I get about 40km/h while pedaling)
- maybe I would get wheelies and loose traction on front wheel due to bad weight distribution as explained here:
Assuming the battery is located at the rear of the bike, you get a better weight distribution (as opposed to a typical front wheel drive).
Also, practically you get a two wheel drive (rear wheel pedaling and front wheel motor assistance). A two wheel drive is better for use on slippery surface because you get better handling (Just like a four wheel drive automobile). Another thing is that the front wheel motor assistance won't cause any unintended wheelies on sudden acceleration.
d8veh   100 GW
Post by d8veh » Mar 16 2012 4:15am
The KU93 is the controller you want - not the KU63. The KU63 is for a 250W motor and won't be powerful enough.
You can get a 11T free-wheel from Ebikes.ca. You can also get your torque arms from there.
http://www.ebikes.ca/store/store_ezee.php
casainho   10 GW
Post by casainho » Mar 16 2012 4:31am
d8veh wrote:The KU93 is the controller you want - not the KU63. The KU63 is for a 250W motor and won't be powerful enough.
Yes, thank you.
d8veh wrote:You can get a 11T free-wheel from Ebikes.ca. You can also get your torque arms from there.
What is safe to ride (with battery on back side), the motor on front or rear side?
BMSBattery just started to sell torque arms. I sent them an e-mail explaning my accident and the dropouts broken and they told me they will offer me the torque arms.
miuan   10 kW
Post by miuan » Mar 16 2012 5:31am
casainho wrote:BMSBattery just started to sell torque arms
Wow. They have made some serious progress during recent 12 months. The price is great and the fact that these are specially made for 12mm axles is cool too. I hope they are at least 4mm stainless steel.
Go get the DNP 11 tooth freewheel, it's a must for every high speed ebike.
casainho   10 GW
Post by casainho » Mar 16 2012 6:08am
Let's ask them for the size of the torque arms.
I would like to get help on this question:
miuan   10 kW
Post by miuan » Mar 16 2012 9:59am
I tried front/rear motor and rear battery. Even with worse balance, rear is still a winner. Just be careful not to wash the front wheel out in corners. Lean forward if you corner hard.
casainho   10 GW
Post by casainho » Mar 16 2012 12:24pm
miuan wrote:I tried front/rear motor and rear battery. Even with worse balance, rear is still a winner. Just be careful not to wash the front wheel out in corners. Lean forward if you corner hard.
Thank you for sharing.
Could you please elaborate a list of the 3 main advantages and disadvantages of each one motor/setup?
Russell   10 MW
Post by Russell » Mar 18 2012 1:07am
IMO giving an RPM rating to a motor is bogus, it's much better to simply list the "RPM per Volts" then there's no second guessing. For example I just bought a Bafang BPM (from a board member here), the motor is marked "36V/500W 26(10)" and it spins at 8.3 RPM/V. At a nominal 36V therefore it spins at 299 RPM and at 48V nominal it spins at 398 RPM. Both measurements are no-load and calculated from speedo measurements so are bound to be off a bit. Still I'm left wondering when someone buys a "393 RPM" 48V motor is it the same exact motor as my 36V code 10?
-R
Jeep Comanche Trekking Bike w/YOUE geared motor, 42 lbs + 15 lb rear trunk bag w/12S 16Ah LiPo battery, tools, etc., 21A controller, 700 x 40C tires. 27 MPH.
My other E-Bikes: Nashbar Steel Flatbar
Scottyf   100 W
Post by Scottyf » Mar 18 2012 2:15am
Pretty much bang on russel. The winds are the same. The stamp on the outside changes. But the kv is the same. It would be better to have rpm per volt as you've said though.
But I guess it's more difficult for Joe public to perceive that as real world speed. It also doesn't give you any torque figures.
Marin kentfield FS - Unassisted
Haste   100 W
Post by Haste » Apr 02 2012 7:15pm
Im lacing 210mm spokes to a 26" wheel using bafang bpm2. Can anyone post pics of their complete wheel...having hard time lacing it.
Russell   10 MW
Post by Russell » Apr 02 2012 7:29pm
Haste wrote:Im lacing 210mm spokes to a 26" wheel using bafang bpm2. Can anyone post pics of their complete wheel...having hard time lacing it.
Sounds like you're doing a 2 cross. If that's right here's a couple pic's of my front motor laced 2X;
GM Motor 025.jpg (89.34 KiB) Viewed 6071 times
GM Motor 021.jpg (86.74 KiB) Viewed 6071 times
-R
Haste   100 W
Post by Haste » Apr 02 2012 7:35pm
thank you! its kinda hard to lace a wheel without a truing stand. These hub motors get heavy and make it semi difficult to lace. Ill lace both sides one time and the wheel has so much play, and every other spoke hangs out like 1/2" out of rim..
jateureka   10 kW
Post by jateureka » Apr 02 2012 8:10pm
The BPM motors are offset so you should really be using 2 different length spokes.
Did you use a spoke length calculator to determine the correct spoke lengths for the spoke lacing pattern you are using?
E-bikes: Bafang 8FUN; Mac; Ezee; FreeGo; Aprilia 7s LiPo; eLation V2; TerraTrike recumbent
E-motorbikes: ZEV 7100 LR scooter, 84V 60Ah LiFePO4.
ZERO 2011 S motorcycle, 51.8V 70Ah LiMno2, 2012 headlight, Kilovac EV-200 contactor
E-mower: EGO 56V mower & line trimmer
casainho   10 GW
Post by casainho » Apr 03 2012 1:06am
Please see my posts, I did shared a video and photos of my wheel.
jateureka   10 kW
Post by jateureka » Apr 03 2012 4:56pm
Haste wrote:... its kinda hard to lace a wheel without a truing stand. ....
Turn your bicycle upside down and use it as your 'truing stand' to mount the motor in.
Toby82   100 mW
Post by Toby82 » May 28 2012 8:16am
miuan wrote:motomech: I'm afraid you've got it all the other way round. Reality is, the lower the code number, the higher the speed. Actually, I'm pretty confident to say the code means number of copper turns, so assuming similar motor size to the MACs, the code 10 will be as fast as the 10 turn MAC etc. In my applications this has proven correct as I own and ride both of these motors.
More on the topic can be seen here:
http://endless-sphere.com/forums/viewto ... =3&t=12582
The numbers don't exactly copy what BMSBattery indicates, but it's in the ballpark.
When purchasing from BMSBattery:
393 @ 36V = code 8
393 @ 48V = code 10 (mine does 40mph in 700c rim for short periods at 74V)
201 @ 36V = code 13 (a friend of mine runs it at 74V and 26in, does about 30mph)
201 @ 48V = code 17? (I've ordered this one for my dad, will be able to confirm soon)
I know BMSBattery could do a better explanation of different wind speeds, but most should get it easily. Hell, one year ago, they had no speeds indicated online, and I had to spend almost an hour to see which code designation is in stock. So it's a huge step forward (for the chinese fwiw).
Hi Guys,
I just recieved my BPM motor from BMS Battery. I ordered the 36v 393 front motor. My motor code is 16(9). Having read this post prior to order I was expecting a code 8 motor. I emailed Bafang directly about the unloaded RPM of a code 16(9) motor and they responded with the following:
The unloaded RPM rating of motor code 16(9) at 36v is 330.
Any questions, please feel free to let me know.
I then emailed BMS battery to find out what their take on code 16(9) was and got the following response:
Hi sir,
The 393 is no-load RPM,and the 330 is normal RPM, thanks for your patronage.
I have now left the motor at my local bike mech to get laced into rim but when motor is returned I will test the unloaded RPM using a digital speed sensor I use at work for RPM calibration on test equipment. I'll then be able to confirm correct RPM rating.
casainho   10 GW
Post by casainho » May 28 2012 8:48am
I did abandon the idea to use the front wheel Bafang BPM because it is to strong for me:
Please read more here: Bafang BPM 500W broke again the aluminium fork dropouts
Russell   10 MW
Post by Russell » May 28 2012 9:23am
Toby82 wrote:Hi Guys,
Hi sir,
Yeah they continue to confuse the hell out of their customers AND themselves by referring to their motors by RPM when they should state the RPM/V. Frankly you can't be certain of what you're going to get because they only give you a choice of "201" or "393" RPM motors but the actual RPM is different depending whether it's a front or rear, 350 or 500W and of course the voltage you operate at. Customers also add to the confusion by reporting no-load RPM without reporting the voltage, which with a fully charged battery will be higher than a nominal 36/48V.
That said my 36V/500W BPM code 10 spins at 8.3 RPM/V (unloaded and calculated from speedometer) or 299 RPM @ 36V (398 RPM at 48V), so 330 RPM at 36V sounds about right for your code 9.
-R
d8veh   100 GW
Post by d8veh » May 28 2012 10:18am
It seems from the last two people that I spoke with, who recently ordered BPM motos, that BMSBattery are now shipping Code 13 as the 201rpm instead of code 15, which is the actual 201rpm version at 36v. The code 13 does about 20mph with a 36v battery.
phproomer   1 mW
Post by phproomer » Jul 11 2012 4:59am
hello
Just for reference I ordered 500 w 36v 393rpm from bms battery and I recieved , 36 volts 500 watts 16(10) which seems to go 300 rpm at 36 volts, not 393rpm.
