Sprocket Ratio = Pedal Assist MPH
DrkAngel   100 GW
Post by DrkAngel » Jan 28 2012 7:37am
Note: Since investigating musical BPM, (Beats Per Minute), and discovering that, for training purposes, a musical BPM of double the crank-pedal RPM is recommended, I will revise my BPMs as RPMs.
For most builds, people should take into consideration the pedal assist capability of the bike.
(RPM - crank-pedal Revolutions Per Minute - pedal rate)
60 rpm is considered a casual-sustainable rate
90 rpm is, a more, top sustainable rate
Figured - rpm x ratio x wheel size" / inches per mile = mph
(rpm x 60min) x (Front T / Rear T) x (Wheel " x 3.14) /((12" x 5280' =) 63360) = mph
26" wheels - My EZip Trailz (OEM)
(60rpm x 60min) x (44T/14T) x (26" x 3.14) / (12" x 5280') = 14.57mph
(90rpm x 60min) x (44T/14T) x (26" x 3.14) / (12" x 5280') = 21.86mph
26" wheels - My EZip Trailz (w/32-11T upgrade)
(60rpm x 60min) x (44T/11T) x (26" x 3.14) / (12" x 5280') = 18.55mph
(90rpm x 60min) x (44T/11T) x (26" x 3.14) / (12" x 5280') = 27.83mph
26" wheels - My Black Widow (Upgraded 34-11T)
(60rpm x 60min) x (48T/11T) x (26" x 3.14) / (12" x 5280') = 20.24mph
(90rpm x 60min) x (48T/11T) x (26" x 3.14) / (12" x 5280') = 30.35mph
27" Wheels - My old 12 speed
(60rpm x 60min) x (52T/12T) x (27" x 3.14) / (12" x 5280') = 20.87mph
(90rpm x 60min) x (52T/12T) x (27" x 3.14) / (12" x 5280') = 31.31mph
700c = 28" wheels - My Haro Express Deluxe
(60rpm x 60min) x (48T/11T) x (28" x 3.14) / (12" x 5280') = 21.80mph
(90rpm x 60min) x (48T/11T) x (28" x 3.14) / (12" x 5280') = 32.69mph
29'er Wheels
(60rpm x 60min) x (48T/11T) x (29" x 3.14) / (12" x 5280') = 22.58mph
(90rpm x 60min) x (48T/11T) x (29" x 3.14) / (12" x 5280') = 33.86mph
Index - Homemade Battery Packs - Updated - December 2019
EBike Toolbox - Bargains! $
Endless Sphere Wiki - Lost?
SoSauty   1 kW
Re: Sprocket Ratio = Pedal Assist MPH
Post by SoSauty » Jan 29 2012 6:03pm
http://www.ebikes.ca/index.shtml No.#1 Trusted E-bike online sales!
3 hardtail MTBs:
-48V Lith-ion 10.5amp hr-408 C-lyte
-BPM 8FUN[*STOLEN]
-run Century rides w/Q100 mini
3 folders:
-20" wife's BaFang,
-20" TurnigyMax50cc airline suitcase folder,
-24" Stewart/Hass 9C; 3.5K/40mph fun racer
LI-ghtcycle   1.21 GW
1.21 GW
Post by LI-ghtcycle » Jan 29 2012 8:27pm
DrkAngel wrote:For most builds, people should take into consideration the pedal assist capability of the bike.
(BPM - Beats Per Minute - pedal rate)
60 bpm is considered a casual-sustainable rate
90 bpm is, a more, top sustainable rate
Figured - bpm x ratio x wheel size = mph
(bpm x 60min) x (Front T / Rear T) x (Wheel " x 3.14) / 63360 = mph
(60bpm x 60min) x (44T/14T) x (26" x 3.14) / (12" x 5280') = 14.57mph
(90bpm x 60min) x (44T/14T) x (26" x 3.14) / (12" x 5280') = 21.86mph
(60bpm x 60min) x (44T/11T) x (26" x 3.14) / (12" x 5280') = 18.55mph
(90bpm x 60min) x (44T/11T) x (26" x 3.14) / (12" x 5280') = 27.83mph
(60bpm x 60min) x (48T/11T) x (26" x 3.14) / (12" x 5280') = 20.24mph
(90bpm x 60min) x (48T/11T) x (26" x 3.14) / (12" x 5280') = 30.35mph
(60bpm x 60min) x (52T/12T) x (27" x 3.14) / (12" x 5280') = 20.87mph
(90bpm x 60min) x (52T/12T) x (27" x 3.14) / (12" x 5280') = 31.31mph
(60bpm x 60min) x (48T/11T) x (28" x 3.14) / (12" x 5280') = 21.80mph
(90bpm x 60min) x (48T/11T) x (28" x 3.14) / (12" x 5280') = 32.69mph
29'er Wheels
(60bpm x 60min) x (48T/11T) x (29" x 3.14) / (12" x 5280') = 22.58mph
(90bpm x 60min) x (48T/11T) x (29" x 3.14) / (12" x 5280') = 33.86mph
Good info, however, does it also take into account the extra torque needed for the higher speeds? The legs/motor still need to be able to maintain that kind of sustained power, and then there are the aerodynamic considerations, going from 20 MPH with X watts, isn't going to make 30 MPH with the same wattage even though you have mechanical advantage with gearing. :wink:
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
Back on track E-Bronco! Now with Cro Motor Mid-Drive Goodness!
https://endless-sphere.com/forums/viewt ... 28&t=44997
Vision R40 w/3000w MXUS as mid-drive, NuVinci N171B rear wheel as transmission, Silent yet powerful, running 72v 11.6 ah (20s 18650 Li-Ion) to climb hills, tow trailer with zero pedaling when needed!
https://endless-sphere.com/forums/viewt ... 28&t=75247[/size]
DrkAngel   100 GW
Post by DrkAngel » Jan 29 2012 8:57pm
Yeah, I found a nice program, too ... after I did the figuring ...
Bicycle gear size and cadence/speed calculator
DrkAngel   100 GW
Post by DrkAngel » Jan 30 2012 8:12am
No, just pedal speed capability.
However ... variations of motor and gearings show the following, (real world), motor only top speeds, for my mountain bike style:
450 watt = 21-22 mph
675 watt = 27 mph
750 watt (1HP) = 30 mph
832 watt = 32 mph? (estimated from 44.4V pack)
(based on Li-ion batteries w/full charge)
"watts" are motors output watts ... not input watts.
I, of course, would like to keep my pedal assist capability, at noticeably past , motor only speed.
There is still motor assist applied, past the motor only speed ... it's just waiting ... for a little help, from me!
I can push my 675 watt, (27mph), EZips, past 30 mph, even to 35mph ... with a tailwind, or drafting.
DrkAngel   100 GW
Post by DrkAngel » Feb 02 2012 4:06pm
DrkAngel wrote: No, just pedal speed capability.
675 watt = 27 mph
One of my earlier graphs:
Demonstrates 24V(450w) & 36V(675w) and various gearing.
"Road Load-Wind Resistance" - green line - can be used to project, similar build, capability-speeds.
(48V(900w) 20T or 44.4V(832w) 16T = +30mph motor only)
DrkAngel   100 GW
Post by DrkAngel » Feb 02 2012 11:45pm
DrkAngel wrote: One of my earlier graphs:
Most DC motor, Watt output (HP) graphs show highest output at 40-50% of no load speed.
Substantial assist plummets near 85% of no load speed
For example, the 36V w/16T mod, no load, speeds at 34mph.
WOT, level travel, motor only, provides, approximately, 27mph which figures at 80% of no load speed.
Which indicates max possible speed from the 675w output motor.
This motor is optimally geared for highest motor only speed.
Gearing for higher speed would decrease motor only speed, but increase, combined, motor & pedal assist, speed.
DrkAngel   100 GW
Human power - watts/duration
Post by DrkAngel » Feb 10 2012 7:44am
Human power. Healthy male vs trained athlete.
Possible power output (watts), for various durations.
A nice guide, towards estimating, pedal assist contribution.
Very revealing, to me, was that a "Healthy Male", was capable of 200w output, for 30 minutes, while the "First Class Athlete" was capable of the same 200w output ... for 20 hours!
Architectonic   1 kW
Re: Human power - watts/duration
Post by Architectonic » Feb 12 2012 5:29am
DrkAngel wrote:A nice guide, towards estimating, pedal assist contribution.
Wow, where did you find this image?
DrkAngel   100 GW
Post by DrkAngel » Feb 12 2012 8:34am
Pulled it from an independent, eMotorcycle developer, site.
Kraig Schultz’s Opinions on Aerodynamics and Electric Motorcycles
Much more too ...
All the reason, I needed, to consider a modest fairing-windscreen ...
Drag , via bicycle type - 22mph
Click on picture, then "+" sign to obtain readable chart!
This site has been a major inspiration, for my eMotorcycle build!
Yes, eventually, I "must" add a shroud-fairing!
