bc_dc
I was pretty close to giving up on the idea of an ebike until I found this forum, so thank you for all the incredible information; I'm still digging through it and will be for some time.
I've been commuting mostly by bicycle for the last 10 years. I say mostly because, living in a hot and humid climate, there are a few months of the year where I haven't been able to ride to work without smelling/looking like something that should be on 4 legs rather than 2 (let alone 2 wheels). I've tried the various bathroom wipedown rituals without much success, and showers at work aren't going to happen. So, in order to extend my biking season to the full year, use less gas, and put less wear on my old car (really don't want to buy a new car, ever), I'd like to build an ebike.
My commute is pretty short (1.5-3 mi depending on route. mostly the 1.5) and couldn't really be any flatter. Parking is quite secure, so not much to worry about there (secured facility requiring company badge to enter, plenty of bike racks). I'm not looking to build a 50mph electro-rocket or go on extended tours. All I really want is something that can propel me at regular bike speeds with minimal pedal effort so that I don't sweat too much, an electric assisted bike if you will.
I'd like to keep this on the lower end of the cost spectrum since I'm not 100% sure that an ebike is the right thing for me. Reliability and convenience are important as well since poor reilability increases the expense and inconvenience decreases the frequency of use. With this in mind, I have been considering a low-medium power, rear-mounted, brushless direct drive system with some sort of lithium battery. The brushless direct drive motor should be very reliable and low-medium power should keep prices down. The rear mounted motor will be better concealed with a rack and panniers, granted, as I read the law here in Texas, it looks like if it weighs less thatn 100lbs and can't surpass 20mph on its own it is not considered a motor vehicleanyways (don't want to test that if I can avoid it). I have an old GT Karakoram steel mtb frame on its way which should be a solid platform and provide a good place for the battery in the triangle. I've found some members on some of the bike forums that make custom bike bags, so getting a good triangle bag for the battery and whatever is needed to house the controller shouldn't be an issue.
My main concern is the battery. From what I have read it is the most troublesome and most expensive part of an ebike. Ideally I want to be able to ride the bike to work, let it sit all day, and ride it back home without having to charge it; I also want it to last as long as it can. I could charge at work, but my volitile schedule means that I'm not always at my desk to monitor the charge. Also, I don't want people to get concerned with the massive battery pack plugged into the wall, which the facilities folks my not be happy with if they found out.
The maintenance of an SLA setup won't cut it, which brings me to lithium. I am willing to sacrice speed/range for something that will last longer and not need to be immediately charged. I hesitate with this build because this is where things seem to rapidly become expensive if not thorough researched (which is why I am here).
Looking at other build threads, http://endless-sphere.com/forums/viewtopic.php?f=3&t=33819 is similar, but a bit more, than the final product I'm aiming for. Looks like a great commuting machine and the Marin has been on my shortlist of replacements for my current commuter if the need arose.
So to summerize:
GT Karakoram steel frame w/26" wheels
rear mounted, brushless direct drive (I think)
moderately powered to travel assisted at normal bike speeds
some type of Lithium battery - again moderate power
reliable - want major components to last several seasons
robust - want a battery pack that can go a few miles and sit for the workday before needing a charge and without sacrifing a lot of life
moderately priced - not looking for an extreme machine, just a little boost that I can hopefully get for $7-800ish (not including the normal bike parts)
Any advice is appreciated on everything from battery type, motor type, different brands (that's a big one actually), the bike platform itself...really any guidance will be appreciated. Thanks!
So to summerize:
