2012 is Trike year.. What do i want ?
Ypedal   100 GW
Post by Ypedal » Mar 06 2012 5:48pm
Ok.. so i know a bunch of you guys have KMX's and i'm done being jealous, what i want to knwo is this, What model should i get ?..
I'm 5ft 7" , 190 lbs ( actually 185 atm, working on 180 ).. I plan to do mostly road, occasional off-road.
Plan is to run about 5kw, either hub or RC motor, i happen to have an Agni 95r in my hands needing a home.. but that's a bit over the hill and certainly over 5kw..
Aaaanyways.. to those of you who have done this, what did you start with and what did you change that i should just skip ahead and get right from the start.
edit :
And where do i get it from ?.. if i go RC, obviously i get it right from the source.. knock knock recumpence.... but if i go hub, the savings of buying locally or as close as possible to save on shipping factor in..
ES site status page:
Rassy   1 MW
Re: 2012 is Trike year.. What do i want ?
Post by Rassy » Mar 06 2012 6:16pm
Good decision. You will love the recumbent comfort and trike stability. As far as what type motor, I would recommend the mid-drive over the hub if you have many hills. The downsides of the mid-drive include more complexity and the need for stronger components at your anticipated power level.
Good luck with your build, we'll all enjoy seeing it on the road. :D
-Rassy-
One Tadpole Trike equipped with a Bafang BBS02
https://endless-sphere.com/forums/viewt ... 28&t=69419
One Delta Trike equipped with a Bafang BBS02
https://endless-sphere.com/forums/viewt ... 0#p1291260
bgnome   10 mW
Post by bgnome » Mar 06 2012 8:57pm
Have you looked at FFR Trikes?
http://www.ffrtrikes.com/default.asp
They have a very nice bolt-on system for the kmx trikes, which you can get as a package deal or DIY. If you are ordering a new KMX, I would reccommend giving these guys serious consideration.
docnjoj   100 GW
Post by docnjoj » Mar 07 2012 8:36am
Hey ypedal!
Varna in Canada has a tilting trike. It's a delta and it ain't cheep, but they seem to have got it right. Just a thought.
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
Ypedal   100 GW
Post by Ypedal » Mar 07 2012 9:19am
Hmnm..
http://www.varnahandcycles.com/index.htm
there is a whole lineup of hand-cycles.. cool.. but i'm looking for leg power types..
Planky   10 W
Post by Planky » Mar 07 2012 10:03am
Hi Ypedal,
I have an X-Class (old) KMX that I purchased second hand.
I went hub motor (HS3540) with a Lyen controller because I wanted stealth and RC setups are too noisy for me. :shock:
The only change I made was just recently I went from the standard 16" front wheels to 20".
The ride is much smoother and the ground clearance is better but I will now have to upgrade the front brakes. :(
Ypedal   100 GW
Post by Ypedal » Mar 07 2012 10:15am
that's what i'm looking to know....
http://www.kmxus.com/
looking at the different models... 24" rear and 20" fronts.. ?
Doctorbass   100 GW
Post by Doctorbass » Mar 07 2012 10:37am
KMX all the way!!!
The typhoon or the cobra nothing else!!
The typhoon is the same as the cobra except that teh cobra is 20 and 24 while the typhoon is 20'' and 16'' wheels.
Also the cobra have 3 gears on the pedalier and the typhoon have one.
Otherwise no reall difference, same frame.. etc.
If you wnat to avoid fliping over, go with the typhoon! it is 2 inch lower to the ground compare to the Cobra..
Even if you want to upgrade for the wheel size it is possible just to replace the 3 wheels :wink:
but if that can help you, the upgrade i would make on mine is to get larger rims for the front wheel!... it will help to avoid the front tire to torsion when cornering. The stockl tires on the typhoon are more for street road and are lightweight.
It is easy to do 7Wh per km at 32kmh with those Something also i wouldlike to do is to install a rear suspension on mine.. by cuting the frame square steel tube just before the "Y" and to install a pivot and a good quality shock.
Hitting a puthole with a no suspension trike is.. something a little special :lol:
After all I found mine pretty strong! The KMX frame are well engineered ! steel at teh right place and aluminum at the right place.
Also the rear drop out can accept perfectly my ultimate torque arms!.. it just fit like a charm!
You will really love the push feeling on acceleration thru the seat!! it is way different than being pulled by the handle bar! Way more impressive... at least with my 5304 on a 20" and 250A burst :twisted:
I love the drift too!.. but i would say it's only fesable with the typhoon wheel size due to the lower center of gravity.
I have a contact here in Victoriab=ville that is selling KMXs. His name is Dave and is a pretty good guy. I bought mine from him and paid with paypal.
http://fr-fr.facebook.com/pages/Quebec- ... 5596388375
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
Brentis   10 kW
Post by Brentis » Mar 07 2012 10:41am
Ypedal wrote:Hmnm..
No affiliation.
When I searched "Varna Bikes" I got
http://www.varnahandcycles.com/cycles.htm
Pedal power.
Seems that the KMX is the top choice around here, though.
Good luck on your laid back journey.
:mrgreen:
chroot   100 kW
Post by chroot » Mar 07 2012 1:14pm
Doctorbass - How do you handle the rough road (bumpy) and did your butt gets sore on your KMX?
I rode Eric's (GreenMachine) Cobra KMX equiped recumpence's dual Astro 3220 gearbox. This thing darn rocket motors and lot bumpy on road at San Francisco. It was short time like less 200-300 feet then that's all. Yet, complete experience with the kmx.
Lastly, Does typhoon 16" wheel have 2.5" wide hookworm tires?
Let me know thanks.
Thank you Justin Lemire-Elmore - You are a HERO!
Tidalforce, Yuba Mundo V4 Cargo bike, Juiced Riders ODK V1 Cargo bike
English is my secondary language - ASL (American Sign Language) is my primary.
docnjoj   100 GW
Post by docnjoj » Mar 07 2012 1:22pm
Hey ypedal
This trike is for feet!
otherDoc
Ypedal   100 GW
Post by Ypedal » Mar 07 2012 2:00pm
sorry doc, all those are a bit too flimsy for my needs.. i'm going KMX unless someone knows of an even more robust/tough rig..
thx for the feedback guys. keep it comming.. by end of march i'm ordering..
ohzee   1 MW
Post by ohzee » Mar 07 2012 2:25pm
I am investing in some new bikes this year.. I am still considering a trike - after watching some of the videos
they look soooo fun.. hope you get something you enjoy I like following the thread as you think it out.
migueralliart   10 kW
Post by migueralliart » Mar 07 2012 3:01pm
Ypedal
I also was considering a trike, to me the KMX Tornado F8 is the sweet spot. I am a bit hesitant because I wouldn't want to get on the bike lake here in Florida on a trike. Anyone here has a daily driver trike? I'd like to hear your thoughts as well.
MattyCiii   100 kW
Post by MattyCiii » Mar 07 2012 3:45pm
Some day I hope to be a "trike guy". When I do, it'll be a leaning trike, full suspension would be a bonus. Sadly that narrows the field and up's the price considerably. Two options that fit the bill are http://fn-trike.de/ and http://tripendo.com/EDEFAULT.htm
Of course if I have the time, tools and skills, there's always DIY. This one is inspirational: http://www.recumbents.com/wisil/wianeck ... _trike.htm
The thing about leaning trikes is (from what I've read), the heels don't need to be as robust because the leaning compensates for the lateral forces.
Just some thoughts...
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 32mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 39mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike. Based on a common power module using a NuVinci left side freewheel.
corkscrew   100 W
Post by corkscrew » Mar 07 2012 4:00pm
I ride my recumbent trike in the bike lanes here in Boise ID. Doesn't worry me any more than riding a diamond frame bike, as I actually feel the "WTF is THAT" factor gets me seen more often than not.
Mine is a cheap actionbent, but before I bought it used, I was drooling over the suspended ICE trikes.
I have heard good things about Terratrikes, Greenspeeds, and Catrikes too.
http://www.icetrikes.co/
http://www.terratrike.com/
http://www.catrike.com/
http://www.greenspeed.com.au/
Actionbent T1 Tadpole Trike - 2806 9C Motor in a 700C wheel. 12S 15AH Lipo pack.
--Build thread: http://endless-sphere.com/forums/viewto ... =3&t=26520
Lessss   10 MW
Post by Lessss » Mar 07 2012 4:05pm
Recumbent trikes to me seem to be a great ride but also statistically the most likely to get killed driving. When a car passes you, you disappear.
Give me nuclear batteries I say!! Ripped off by Joshua Goldberg to the tune of almost $900 re headway groupbuy for batteries, no $ no batteries
http://www.openoffice.org/ or https://www.libreoffice.org/
http://distrowatch.com/dwres.php?resource=major
Ypedal   100 GW
Post by Ypedal » Mar 07 2012 4:07pm
I have every intention of lighting this thing up like a christmas tree.. orange whips and all..
and 2nd.. i dont plan to be passed very often ! :twisted:
edit : I actually have lots of trike friendly roads all around my house, dedicated bike lanes, a CN Rail service rd , but it might become a winter machine as my job is moving across the city and this makes busses a nightmare and financially impossible via taxi..
Doctorbass   100 GW
Post by Doctorbass » Mar 07 2012 8:13pm
The best trick is to install a 6" tall stick with reflective flag and also led strip!.. just like i did!
While you drive, the flag dance with the wind and led move fast anc get alot of attention.. not only by the fly ! :mrgreen:
Doc
Pretty visible!!
MattyCiii   100 kW
Post by MattyCiii » Mar 07 2012 9:18pm
Ypedal wrote:I have every intention of lighting this thing up like a christmas tree.. orange whips and all..
I'm definitely a believer in having an abundance of lights http://endless-sphere.com/forums/viewto ... =3&t=37528. I was harassed recently by some college kids in a car. Called the cops, they sent an officer over to take a statement. He took one look at my bike and said "Oh, you're the guy with the lights". Started to lecture me on his opinion about lights. I asked him to tell me what he knew about state bike laws, he just had to hang his hed in shame. Point is: you, not the drivers, not the cops, have the most control over your safety. Burning someone's retina is a great way to get drivers off your A$$.
Green Machine   100 kW
Post by Green Machine » Mar 07 2012 9:43pm
Just to keep in mind...
One sensation i get when riding my trike on public roads is an incredible sense of danger. You really feel invisible to traffic and you really can get run over. On a bike you get hit and you are atleast seen..on the trike you get run over.
Skateboarders, bicyclists, joggers get hit by cars....trike riders, go kart riders, get run over by cars. Big difference.
I do agree with lights flags etc..
Also if you dont widen your trike its really susceptible to flipping if you dont lean into every turn at high speeds. Flipping on a turn and sliding on your side into oncoming traffic would also count as being "run over".
WHenever i ride on the trike in traffic i feel like it is the most dangerous thing i have done all year. And i fly a plane drive a motorcycle etc..
Sacman   10 kW
Post by Sacman » Mar 07 2012 9:56pm
Doctorbass wrote:The best trick is to install a 6" tall stick with reflective flag and also led strip!.. just like i did!
Doc
Pretty visible!!
Got any video of this Doc? :mrgreen:
Doctorbass   100 GW
Post by Doctorbass » Mar 08 2012 12:28am
Doc
Pretty visible!!
Yeah!
look at 1:25 and 2:58 of this video :mrgreen:
Doc
MattyCiii   100 kW
Post by MattyCiii » Mar 08 2012 6:39am
One thing the KMX has going for it are the RC electric bike parts FFR makes http://endless-sphere.com/forums/viewto ... 28&t=32349.
FFR is an excellent company to work with. I bought one of their disk-brake-to-chainring adapters, but found its pocket was too deep. Not only did they gladly accept it in return, but on their next run of parts they CNC'd an adapter that was "shallow" enough for my purposes. Not that is what I call excellent customer service.
Xanda2260   100 W
Post by Xanda2260 » Mar 08 2012 9:56am
If you can weld you could always build one!! Strong as you like then!! Farfle's is nice, and mines in the photos section if you fancy a look-see (White Warrior).
The White Warrior - http://endless-sphere.com/forums/viewto ... =6&t=33918
Homebuilt 40mph+ tadpole!
