safety at 40mph
just read some post on this subject over in a different post
im new here (so my opinion dosent count for much) but have quite a bit of experience with bikes
i would "guess" most modern freeride / downhill bikes are designed with components that can cope with stresses
of regular 30-40mph speeds - but - on harsh terrain
what were talking in most cases is the same speeds on pretty flat smooth ground - not really demanding for such a bike
jumping off a mild 4ft drop on a freeride bike will probably be as stressful as dropping off a kerb with the same bike loaded up with
electric bike bits but these bikes are designed for that stress all day everyday for a good few years
as long as the frame can take the stress of the extra weight (which is the bit its not designed for)
and as long as you gradually ease in to driving faster so you understand the capability's of your machine
then its is exactly as safe / unsafe as a moped (30 - 80cc)
is a 40mph ebike safe? no
but is a gas scooter or moped - ill let you answer
i think its very important that components are chosen for the speed you are doing - for 40mph you need a tough downhill / freeride frame think welded 4130 cromoly or monocoque alloy you need 3inch tires and high quality disc brakes
someone in the other thread mentioned the high weight of moped components - the reason behind this is because 1) the bike is heavy anyway therefore there is little point in making light weight parts 2) parts need replacing - on a moped people don't want to spend $1000 on new shocks
but i think you will find the parts on a downhill/freeride bike are stronger lighter and work better than anything on a 50cc moped - because they have to be!
now if your converting a standard mtb rigid or a road frame (not a jump frame) frame then i think 30mph is max and you really need front disc and everything needs to be good
components - its not that they cant handle the speed but its the stresses on all the parts from the weight
for a supermarket full suspension or a hi-ten steel bike i think 20 - 25 is max as the parts are all poor and it will just fall to bits
